Well I finally found a distributor for the rear side quarter glass on the 74 Trailduster project...but have a quick question for anyone who has done this type of glass install....do you use any type of adhesive in the channel where the glass goes, or just on the frame lip of the removable top? Don't want any leaks, and I have the early style which does not use the lockstrip on the gasket. I have the gasket installed on the window, but if it needs some adhesive in there, I will remove it. Any tips would be appreciated.
Dave in Colorado
All you can do is install the glass the way you have started. Then if needed you can get a pump gun and pull the seal back and lay a bead between the seal and the body or the seal and the glass. If you try to use any sealer prior to lpulling the glass in place you will just make a mess and possibly still mess the sealing part. They were a pain when new so no different now.
