'68 Fury street/strip project thread - new goal of 10.0's
#2969430
10/01/21 08:56 PM
10/01/21 08:56 PM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
I've made a couple posts about my car already. It's a '68 Fury III (4500 pounds with me in it!!) that has an old school built 440 in it. Ported 906's, 30 over 6 pack pistons, LY rods, 590 mopar cam, TM7 intake, 850 Holley DP and 1 3/4" headers with 3.5" exhaust and flowmasters. I ran 12.40's with it last month and am going to try to get it to the track one more time this year before the season is up. I'm thinking I can maybe get another tenth or two out of it. It's also got an Ultimate converter that seems to flash around 4500, and 4.30 gears with 295 M/T drag radials. Have spent some time messing with timing and squirters, it runs pretty good at this point and at the track it hooked fine launching from 3000-ish, but it just has air shocks in the back so I assume I'm going to need caltracs and adjustable shocks if I put any more power to it.
The goal is to run 11.50's in any conditions, so probably 11.30's in good air. That needs a minimum of an 150 hp bump over where I'm at now. Whatever I do with it, I also want it to be reliable, as the goal is to run one of the drag and drive events next year. Drag Week, Midwest Drags, or Rocky Mountain Race Week.
The initial thought was to put a 200 hp plate kit on it, that should get it to where I need to be. I'll need to upgrade the fuel system, but other than that it might be ready to go. I worry a bit about durability with spraying it, but it should at least get me to the ET goal.
The other option is to spend some money on the motor and make that difference up n/a. I think the heads are the biggest restriction currently. Trick Flows look like there really is no ETA on them due to supply issues - every time I look on Summit's site the expected ship date keeps slipping. I think Indy 440 EZ's are available, but don't know if they would get me to where I need to be out of the box compared to the TF's.
The other concern is I'm not sure the small-ish headers, cam, and honestly the rotating assembly, is going to be ok to get a 446 to the 600 hp range without being suspect. I'm not an expert by any means but I'm thinking to get 600 hp out of an n/a stock displacement RB is going to require more rpm than the pistons and rods are safe to.
What are everyone's thoughts? Will a head swap get me there? Or do I really need to dive into the shortblock to get to where I need to be?
Thanks, Nick
Last edited by Blusmbl; 12/08/23 11:26 PM. Reason: beat original goals, continuing thread!
Re: Thoughts on what to change to run mid 11's?
[Re: Scully]
#2969448
10/01/21 09:43 PM
10/01/21 09:43 PM
Blusmbl
Plymouth, MI
It went 12.46 @ a little over 108 at Norwalk last month, I don't know what the DA was but it was a normal early fall midwest day, thinking low 60's for temp in the evening. The Wallace Racing calculators show between 440-460 hp based on the weight. The motor went 11.90's in a B body, 2 owners ago. It has a mechanical fan and power steering, which certainly isn't helping it.
I set the lash at 28/32 based on the original specs for the 590, and timing is at 38* with a Mr. Gasket light spring kit so it's pretty much all in at idle. I wanted to see if there was anything on the table with jetting but ran out of time, only got 2 runs in during a 5 hour T&T. Hoping for a few more and really wanted to see if jetting it up helped any.
[Re: Blusmbl]
#2969457
10/01/21 10:03 PM
10/01/21 10:03 PM
Posts: 4,673 On the parachute mount
n20mstr
Wow I had the same exact combination . But I had hyperutectic pistons . Any way my car ran 11.30’s and weighed 3500 , so honestly I think your running pretty well for what you have . I would have no problem spraying that combo . It won’t take 150 either . All your going to need is a .052 nitrous jet and I can almost guarantee your going to drop a second or more like nothing .
Get your self a Saturday night special plate and your set
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2969464
10/01/21 10:30 PM
10/01/21 10:30 PM
Posts: 11,708 Portage,michigan
B3422W5
Portage,michigan
I would buy a lighter, more modern rotating assembly, then update the heads. Even ported Eddies would have way more potential than what you have, they go over 300 easily with modest work. Then if the above doesn't get you there, you are way better equipped to maybe spray a more modest amount( onto better parts) to reach your goal. To me, a good shortblock is the foundation to any attempt to make even half way serious power.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: DrCharles]
#2969498
10/02/21 06:15 AM
10/02/21 06:15 AM
Posts: 3,159 Md.
carnut68
Md.
Nothing wrong with the EZ heads. I bought through Fast [Porter Racing heads] and gained 6mph and 4 tenths by just a head swap over ported 906s. Minor bowl work back cut valves standard port. Same 590 cam as you. 446. As said b/4 eliminate weight.
America First!
[Re: Blusmbl]
#2969580
10/02/21 11:15 AM
10/02/21 11:15 AM
Posts: 570 UK
rb446
UK
Thanks, Nick
My mate ran a 3150lb Dart to 10.1'@132 best with a 12.7:1 440 with LY rods I believe, had the .590 cam and MCH ported Eddy heads (320cfm), a Victor Intake and a 1050 Dom, just barely made the 600fwhp mark on Wallace with weight/mph. The block was well built in the US by the guy that raced it and he bought it over to the UK so I would think it had well prepped rods/bolts but who knows for sure. He used to turn near 6800rpm in the traps with it with his chassis combo. Lasted for approx 4 seasons here of hard racing before it blew. So I personally don't think just a head swap would get you another 150hp with your in theory 10:1CR and that cam. I ran a similar motor to what you have in 1990 with 6pk rods/pistons, a Team G intake, 850DP, 2" f/well hdrs, ported BV 906's (260cfm) and a .650"/290@.050 SFT cam@around 9.8:1 and made 530fwhp according to Wallace for weight/mph. I turned that to 66>6700 in the traps NA and 7400 with a 175 b/shot N20 system,=660hp. I had a single external oiling system to handle the rpm. Pistons are no problem, its the rod bolts you may have that are the weak link as we know. I think if TF heads or similar 300+cfm heads were about then apart from B1's which I couldn't afford to pull the motor and replace everything I could've got close to around 570>580hp at that low CR mainly cos of the cam. I would go with a 150 shot and see where you end up you would in theory be pulling 63>6400rpm max in the traps with your parts. So unless you want to pull the motor and go through it completely with ally heads and more comp NA that 600 no. ain't gonna happen the way I see it in reality.......my 2c's.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rb446]
#2969582
10/02/21 11:23 AM
10/02/21 11:23 AM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Sell the complete long block, build a 50X” with good heads.
Or...... spray it.
The thing the spray does besides the extra HP........ is you also get a giant boost in TQ, that you won’t get by hopping up the stock stroke engine by traditional means. With the normal NA mods, you’ll get a little boost in TQ, but the big HP gains will be made by extending the upper part of the power curve(carry the TQ to a higher rpm).
[Re: carnut68]
#2969583
10/02/21 11:24 AM
10/02/21 11:24 AM
Blusmbl
Plymouth, MI
Thanks guys!
Definitely agree the shortblock could use an upgrade. I worry that it'll turn into a "might as well" situation, if I'm buying pistons and rods I may as well toss a stroker crank in there too. I did have the pan off a couple months ago and checked a couple rod bearings, it looked great inside, so I'm struggling to take it apart since it's a perfectly good running motor. Maybe I start buying rotating stuff now and then if I ever hurt a piston or something it gets a full rebuild.
I will have to look for spots to take weight out of it, it's a street car but I should be able to do something. Nobody makes fiberglass parts for Furies and the hood is ridiculously heavy. It has discs now but has power brakes, along with an accumulator and a vacuum pump to run them. I could ditch some weight there if I find a manual brake setup, and maybe switch it to manual steering. The subframe on C bodies looks really beefy too, not sure if I can take a holesaw to it, or maybe some interior panels or something. I did plan on pulling the hvac box. It also has 2 layers of carpet so I'll pull one of those out.
4 tenths and 6 mph from swapping to EZ's on a 446 makes sense and is encouraging but also highlights I'm definitely not going to get to 11.50's with just the head swap. Maybe I go that route and try to get some weight out of it, that'll put it into the high 11's at least, and then make up the difference with spray?
EZ's have stock plug location and exhaust ports, right? If they've got similar potential to Trick Flows, and they're available now, that might be a winner. What kind of rpm are you turning with them and the 590 cam, carnut?
Edit: 2 more responses since I started typing. Thank you. That matched my gut feeling, getting to 11.50's at the cars weight likely isn't happening without changing the rotating assembly. Or spraying it.
Dumb question, but if they're the weak link, can rod bolts be changed without getting the rods remachined, or is that asking for trouble?
[Re: merpar]
#2969598
10/02/21 11:50 AM
10/02/21 11:50 AM
Blusmbl
Plymouth, MI
Thanks again. The torque should help it with the car being so heavy too, so that really says it either needs some nitrous or a stroker kit. The power I'd need to get there n/a at 446" likely needs a rotating assembly that will handle more rpm than what mine is safe to.
The heads were ported in the 80's I believe and have a bunch of work done to them, they supposedly flow 263 cfm.
I only want to buy things once, so maybe a plate kit for now and then start saving up to build a completely new longblock with a 505/512 with Trick Flows or EZ's.
[Re: GomangoCuda]
#2969718
10/02/21 07:24 PM
10/02/21 07:24 PM
Posts: 1,030 ohio
67mprfan
ohio
As mentioned already don't start spending yet get a plan then go hog wild. Good luck whichever direction you go
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2969752
10/02/21 08:32 PM
10/02/21 08:32 PM
Blusmbl
Plymouth, MI
Thanks, definitely still in the planning stages, and agree- definitely only want to buy stuff once. For now I think a small plate kit is the winner, it will get me to where I want to be and shouldn't hurt anything... except maybe the trans or rearend. lol
I love the car too much to try going fast with something else.
[Re: Blusmbl]
#2969851
10/03/21 05:58 AM
10/03/21 05:58 AM
Posts: 3,159 Md.
carnut68
Md.
Thanks guys!
I shift at 6500. 391 gears 5200 convertor. A body. EZs are angle plug stock port location. Mine flow from 295@ 500 to 323@700. With more potential by opening to larger ports.
America First!
[Re: carnut68]
#2969885
10/03/21 08:28 AM
10/03/21 08:28 AM
Posts: 2,255 IL
furious70
IL
I know there are NO2 cars on drag week, but I'd think it would be a pain to keep up with bottle supply all week. Of course a full out turbo/supercharger deal that needs ice every one is a pain too. But would a 'simple' supercharger and air to air intercooler be an option? Obv it costs more than the bottle. I've still got your 4.15 crank and the EZ heads sitting over here. I do plan to use them in the Charger at some point though.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2970004
10/03/21 02:59 PM
10/03/21 02:59 PM
Blusmbl
Plymouth, MI
Thanks everybody. 451, it definitely sounds like you could benefit from more tire and some suspension work. 120 mph is hauling!
I've definitely considered other power adders. If I win the lotto, or at the very least get out of other hobbies, turboing it would be a stretch goal. But...I can't fabricate a project like that and I'd want to do it right (multiport efi, e85, turbo friendly cam, rear gear and converter, rollbar, trans brake etc), and at that point the goal would be 9.50's instead of 11.50's. lol
I do remember Monte (rip) used to fill everybody's nitrous bottles on drag week. I don't know if any other vendors do that now on the drag and drive events, but I also would expect that 2 bottles would last a whole event, with only a pass or two per day.
[Re: Blusmbl]
#2970076
10/03/21 07:41 PM
10/03/21 07:41 PM
Posts: 3,138 Central NC
gch
Central NC
Nitrous will get you there if that is all you want. I will go against the grain and say get the heads you need to support the number/power you want. They will still be there and not a bottleneck if you do a serious shortblock later.
[Re: Blusmbl]
#2970085
10/03/21 08:12 PM
10/03/21 08:12 PM
Posts: 2,255 IL
furious70
IL
Holley was filling bottles still. I meant more in the rush of trying to decide if you need to make another pass or waiting FOREVER for your turn depending on how many oil downs there are it would be harder to manage. I imagine, as I've never had a bottle.
I built the turbo setup for my fury in my house garage, I'm sure you could do it!
[Re: furious70]
#2970220
10/04/21 08:48 AM
10/04/21 08:48 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
Why not buy some heads that will work on a 500" stroker, but put them on the current 440, and let it run what it runs. If it isn't enough for you, build another stroker shortblock while you spray the old one.
[Re: Blusmbl]
#2970511
10/04/21 06:21 PM
10/04/21 06:21 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
"I worry that it'll turn into a "might as well" situation, if I'm buying pistons and rods I may as well toss a stroker crank in there too." If we can assume around a 60 CI increase for a cost of between $700 and $950 for a typical stroker crank, then a guy would just need to decide if 60CI is really worth it for this application. It kind of seems like a bargain "Dumb question, but if they're the weak link, can rod bolts be changed without getting the rods remachined, or is that asking for trouble?" It's kind of a bad idea. I did that in the late '80s to the mule 440/still together in the Polara. The reason I got away with it was....back then, Mancini was selling production/I believe SPS rod bolts in bulk, without the direct connection blister packaging. I ended up with exactly the same bolt as stock, but new. I don't think I would attempt this today with an ARP 8740 etc without having the rods resized....and by then you're about halfway to some middle of the road aftermarket rods. Maybe I am showing a tendency to repeat past mistakes, but to me the easy/fun approach is enjoy it the way it is for now and start working on the next combination. Then when the new big bad engine is done, if everything goes well you will end up with a spare 440 to either use, sell, part out, etc.
Rich H.
Esse Quam Videri
[Re: Mr.Yuck]
#2970815
10/05/21 10:52 AM
10/05/21 10:52 AM
Posts: 9,985 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Have you tried tighter lash? I would start by going 18 and 22 and see if the car likes it. If it doesn't like it reset the intakes and see if it just needs more on the exhaust side. What is the cam in at? Very heavy car might want the cam advanced. I would definately look for some better aluminum heads, and try and set the motor up for the max compression you want to buy fuel for. Look for ways to lighten the car. A disc brake conversion will drop 35 lb I believe, plus it should stop better.
[Re: gregsdart]
#2970834
10/05/21 11:09 AM
10/05/21 11:09 AM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
Very good point about changing the front end and brake components to lighter stuff. What front spindle does a c body use in those years? IIRC the rotor is thicker than a b body.
I agree that building a better/bigger short block should be on the list. If you played your cards right and bought parts off season, took advantage of sales etc. you can screw together a 15-20k engine for 10-12k. That would be starting from scratch; new water pump housing etc. You could save a few thousand reusing some of the 440 parts if needed. Whatever you do it will need a decent fuel system so maybe think of starting there.
Experiment with lash settings Converter - I would think there are some local members that could help you out there. Is that a J converter? Fuel system Nitrous Kit New engine on the cheap (accomplished by way of 50% off sales, PB&J for lunch in 2022, and brewing your own beer)
That seems easy enough : D
[Re: Jeremiah]
#2970859
10/05/21 11:55 AM
10/05/21 11:55 AM
Blusmbl
Plymouth, MI
Thanks everybody. Lots of confirmations of what I already figured but didn't want to admit, lol.
I don't think I'm going to touch the shortblock now, especially if changing rod bolts without getting the rods resized is a bad idea. I'll just keep this motor together as is and start planning a new build, but in the meantime put a small plate kit on it to get me to where I'd like it to run. Think I'm going the Jeremiah and MoparBilly route of just y-ing the fuel solenoid off the main feed and tossing a regulator on the nitrous supply side.
Will start collecting parts for a 50x" stroker, and it seems like the Trick Flows are the way to go for heads at the 600-700 hp power level. Once they're available I'll pick up a set. Beyond that it sounds like stock blocks are suspect anyway.
The converter in the car is a 9.5" Ultimate. It flashes to ~4500 from what I've seen. The rear tires on it are just under 30" tall, to me it doesn't seem over-geared. I'm well under 6k crossing the finish line and I'm shifting a little over 6k. It sorta feels like it noses over past 6k regardless of gear. I have a 1" open spacer I want to try and also was going to go up and down with jetting the next time I get it to the track.
I do not know where the cam was installed, but I am guessing it was already advanced a couple degrees. I can ask the old owner.
I haven't considered tightening up the lash at all- can definitely experiment with that. I figured I'd just put it where the cam card suggested and run it, but will try tighter for sure.
I have put Wilwoods on the front of it already, I did that before Roadkill Nights. I can try to maybe swap the booster and vacuum pump + reservoir out for a manual brake setup but will need to find a manual brake C body to get the parts from. It has 2 layers of carpet in it, will pull one of those out along with the HVAC box. It doesn't have tailpipes. I'll have to start looking for brackets and things that can be removed or have holes drilled into, but also not be obvious about it.
Thanks, Nick
[Re: Locomotion]
#2970895
10/05/21 12:39 PM
10/05/21 12:39 PM
Blusmbl
Plymouth, MI
It's an 8 3/4 with Moser axles, and I also upgraded to a 3.5" Dynotech driveshaft with 1350 u-joints over the summer. I suspect the ring and pinion might be the next to go, at which point it'll either get an aftermarket 9" or a Dana 60. It will definitely be the next weak link in the drivetrain. I know at this weight and HP it is marginal, especially on radials. For the brakes, Wilwood didn't have a weight specification and it's a kit designed for C bodies. I have a set of '73 C body disc spindles I could've used but I can't find caliper brackets. The trans is a 727 with a Cheetah reverse manual valve body (no low band apply) that I shift on the column. I don't ever get off and back on the gas in 1st gear, and also know if I break the rearend I'll have to pull the trans to check the sprag.
[Re: FastmOp]
#2971177
10/05/21 10:31 PM
10/05/21 10:31 PM
Posts: 2,255 IL
furious70
IL
FWIW, several 'mild' engines we've had in cars that we took to a bunch of T&T sessions always seemed to like spacers. I had just a magnum 383 in my Coronet at one point and I had 2" of spacer on top of a torker intake and that was faster and if I had had any more spacers and longer bolts I still think it wanted more. It's cheap to experiment with. I whittled 1.25 seconds off the ET on that combo doing little stuff like that - biggest thing I did to it was put the torker on vs the OEM HP intake.
[Re: furious70]
#2971238
10/06/21 08:14 AM
10/06/21 08:14 AM
an8sec70cuda
FWIW, several 'mild' engines we've had in cars that we took to a bunch of T&T sessions always seemed to like spacers. I had just a magnum 383 in my Coronet at one point and I had 2" of spacer on top of a torker intake and that was faster and if I had had any more spacers and longer bolts I still think it wanted more. It's cheap to experiment with. I whittled 1.25 seconds off the ET on that combo doing little stuff like that - biggest thing I did to it was put the torker on vs the OEM HP intake. It shocked me just how much difference there is b/t a stock style intake and a decent aftermarket one on even a mild motor. Years ago I was trying to sort out some fitment issues and swapped an Edelbrock Performer RPM intake for a MP M1 dual plane (an aluminum version of the factory HP intake). That motor was neutered after that swap! Completely done before 5k rpm. It was just a flattop 440 w/ 906s and a 509 cam. Sorry...I know this doesn't help the OP. Just made me think of it when I read the previous post.
[Re: an8sec70cuda]
#2971406
10/06/21 04:16 PM
10/06/21 04:16 PM
Jeremiah
Rogue River, OR
I just swapped a Holley SD in place of the DP4B on my 68 GTS and it made a noticable difference in the top end. Thanks to Mr. Porter for that recommendation; I didn't realize how short that and a torker were compared to the RPM. Plenum volume is king above 5k RPM from what I am learning.
As a word of caution with the spacers make sure that the one you place on using is big enough for the throttle blades on your carb to clear. I have seen a few bent butterflies from guys not checking and just hopping in and smashing the pedal to the floor.
You should post more picture of that thing for us. I didn't realize (or forgot) it had that tall of a tire on it.
Also, I'd start looking around for a rear end housing too Again, something you car slowly put together on a budget. With the superstock theme of the car it would be awesome to have a Dana with a chrome cover sticking out underneath.
[Re: Mr.Yuck]
#2971407
10/06/21 04:20 PM
10/06/21 04:20 PM
Jeremiah
Rogue River, OR
You need to get some weight out of the car. As mentioned, if you can get Aluminum heads I'd go for it, add a newer cam design, call and have one custom ground for you car. What are you shifting at right now? You might have too much gear. Speaking of updates, we need some current pics on your car too mister!
[Re: Jeremiah]
#2971453
10/06/21 06:29 PM
10/06/21 06:29 PM
Blusmbl
Plymouth, MI
It currently has a TM7 for an intake on it right now. It feels super strong from ~3500 to around 6k. I'm hoping adding some spacer will pick up the upper end some, it starts to feel flat above 6 and the cam should be good to 6500. Is there any danger in home porting the intake to give it more volume? I'm definitely not afraid of a die grinder and have lots of carbides, but also don't know where I should be grinding. lol
It definitely sits high in the rear but some of it is due to tire clearance. I might have to remake the wheelhouses to get it to sit lower without rubbing with the 295's on it, or maybe go down to a 275. I love how it looks now though. Agree, it would be sweet with a chrome cover on a Dana 60 out back!
[Re: Blusmbl]
#2971514
10/06/21 08:52 PM
10/06/21 08:52 PM
Posts: 1,030 ohio
67mprfan
ohio
When I was trying to decide between the 295's or 315's I picked the 315's because they are shorter and a little wider, I drive a 67 B-Body and space is limited on those cars. In case you wanted a different tire to drop the back some
[Re: 67mprfan]
#3047031
06/01/22 11:46 AM
06/01/22 11:46 AM
Blusmbl
Plymouth, MI
Figure I'd update this. I got a deal on a plate kit so I installed that over the winter, and also picked up an AEM wideband, an MSD timing retard box, and a NOS mini progressive controller. It shouldn't need the controller but I figured it can't hurt if I ever do pour your own puddle/no prep type racing with it. Going to be super conservative on timing, have the box configured to pull 8* out when the nitrous is activated, it's all automated through the progressive.
Right now the fuel side is teed off the carter mechanical pump. I know MoparBilly and others used to run plate kits on a ton of 440's with that Carter pump, we'll see how this goes. I'm going to be watching the wideband like a hawk and if it is running out of fuel on the top end I'll swap over to a dedicated fuel supply for the nitrous but for now I'll try it as is. I'm going to stick to 73 jets as the highest, really don't want to put a rollbar in the car and honestly I'm not sure the trans will live with it if it goes much faster than mid 11's either.
Excited for Milan to finally open!
[Re: Blusmbl]
#3047088
06/01/22 01:49 PM
06/01/22 01:49 PM
Posts: 4,669 Wichita
GY3
Wichita
Nice! I know someone else that put the solenoids in that area... A JAZ 1 gallon Jr. Dragster fuel cell and a small 5 psi electric pump make for a cheap supplemental if you are so inclined.
[Re: Blusmbl]
#3047090
06/01/22 01:51 PM
06/01/22 01:51 PM
an8sec70cuda
Nice, I like it!
[Re: Blusmbl]
#3047108
06/01/22 02:30 PM
06/01/22 02:30 PM
ZIPPY
S.E. Michigan
Cool beans! Any preliminary test hits on the street yet?
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3047124
06/01/22 03:49 PM
06/01/22 03:49 PM
Blusmbl
Plymouth, MI
Thanks guys!
GY3, I definitely copied the idea from you, although if I remember right you also painted your solenoids engine color so it's even less obvious! I like how it's semi-concealed, somebody just glancing at it won't see that it obviously has nitrous. The progressive screen is on a spare switch blank plate that I can swap in and out, so it can be hidden in the ashtray, and the arm switch is under the dash and behind the wideband so it isn't noticeable when you look in the car. That is a great idea for a secondary fuel system too, I can probably fit it up by the battery in the massive front fender if needed.
Rich- not yet. I just have to put the colder plugs in it, the bottle is filled and I've tested everything, but I wanted to at least get a timeslip out of it if I'm going to risk hurting the rearend or trans, lol.
Edit: the fuel line looped over the top of the upper radiator hose drives me nuts, but I haven't found a C body upper hose yet that is higher so I could route the fuel line underneath it. If the motor ever has to come out I'm going to ceramic coat the headers and repaint it too.
[Re: Blusmbl]
#3047142
06/01/22 04:27 PM
06/01/22 04:27 PM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Thanks guys!
Edit: the fuel line looped over the top of the upper radiator hose drives me nuts, but I haven't found a C body upper hose yet that is higher so I could route the fuel line underneath it. If the motor ever has to come out I'm going to ceramic coat the headers and repaint it too. You could move the outlet on the rad to the center or use straight hose sections and metal elbows to make the hose pass further forward of the engine. 11's in a C will make you large and in charge. Kevin
[Re: Blusmbl]
#3048253
06/06/22 11:38 AM
06/06/22 11:38 AM
GY3
Wichita
I’ll be happy with an 11 anything out of it for sure!
My plan, a few years back, was to just break into the 10's with a baby 150 shot. It surprised the heck out ofme when it ran a 10.69 on a really hot Summer night
[Re: GY3]
#3048517
06/07/22 08:05 AM
06/07/22 08:05 AM
Blusmbl
Plymouth, MI
Thanks guys. I'd be ecstatic if I could jet it up and get it into the high 10's, but think it would need a supplemental fuel system for the nitrous and probably a converter swap to do it. It's also still running around on a stock blown out bench seat and original lap belts so it isn't exactly the safest idea to make it much quicker.
If it runs better than I expect maybe I'll take the plunge and put a rollbar in it.
[Re: GY3]
#3048576
06/07/22 11:42 AM
06/07/22 11:42 AM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
My plan, a few years back, was to just break into the 10's with a baby 150 shot. It surprised the heck out ofme when it ran a 10.69 on a really hot Summer night A buddy had a 67 mustang with a mild 428 ran 12.20s. He put a 250 shot Comp-U-car on it, wow 10.57 3 times n a row, never heard it shift just one loud roar down the track. I raced it a few times using it just in third. I blew the engine after a solenoid stuck while dry hopping behind the line. Engine died so after shutting the bottle off and cranking over for 30 seconds figgered it was cleared. Wrong, pow, bent rod, cracked block and head, blew out the head gasket and jacked the head bolts. Won’t use that stuff again!!
[Re: Blusmbl]
#3048586
06/07/22 12:13 PM
06/07/22 12:13 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Thanks guys!
Look at you all grown up and not immediately cashing the first bottle out on the street!
68 Barracuda Formula S 340
[Re: Bad340fish]
#3048651
06/07/22 03:08 PM
06/07/22 03:08 PM
GY3
Wichita
Thanks guys!
Look at you all grown up and not immediately cashing the first bottle out on the street! I always test on the street first so I don't oil down the track! ...in front of a crowd.
[Re: GY3]
#3050087
06/13/22 07:50 AM
06/13/22 07:50 AM
Blusmbl
Plymouth, MI
Look at you all grown up and not immediately cashing the first bottle out on the street! I always test on the street first so I don't oil down the track! ...in front of a crowd. Ok, since you guys both called me out for being old and lame, the wideband bungs are going in this weekend and it will get a couple 2nd and 3rd gear hits on the street first before heading to the track.
[Re: JERICOGTX]
#3050146
06/13/22 10:45 AM
06/13/22 10:45 AM
ZIPPY
S.E. Michigan
I approve of this message.
Rich H.
Esse Quam Videri
[Re: Blusmbl]
#3050220
06/13/22 02:37 PM
06/13/22 02:37 PM
Bad340fish
Tulsa OK
Look at you all grown up and not immediately cashing the first bottle out on the street! I always test on the street first so I don't oil down the track! ...in front of a crowd. Ok, since you guys both called me out for being old and lame, the wideband bungs are going in this weekend and it will get a couple 2nd and 3rd gear hits on the street first before heading to the track. I cringe to think about what AFR numbers I might have ran on my old 360 when it had nitrous. It seems in our 20s my friends and I got a free pass on nitrous for awhile. Way to much nitrous on way to much pump gas lol.
[Re: Bad340fish]
#3050236
06/13/22 03:20 PM
06/13/22 03:20 PM
Blusmbl
Plymouth, MI
I don't have aluminum block 572 money! But... if I ever hurt this one I will build a TF headed 512 stroker for sure. I cringe to think about what AFR numbers I might have ran on my old 360 when it had nitrous. It seems in our 20s my friends and I got a free pass on nitrous for awhile. Way to much nitrous on way to much pump gas lol.
I know Monte always said that timing is what kills them so I am hopefully OK with the timing retard box set to 8*, but... I really want to monitor it to see how close the tune is on the fuel side, especially running it off the mechanical Carter pump with no regulator, lol How much were you spraying on your old 360?
[Re: Blusmbl]
#3050244
06/13/22 03:55 PM
06/13/22 03:55 PM
Bad340fish
Tulsa OK
It saw 225 for awhile on 91 octane...yikes! It was just junk thrown together to have something to race. It ran 12.90s NA and it was way out of gear on the nitrous.
[Re: Bad340fish]
#3071269
08/25/22 07:02 AM
08/25/22 07:02 AM
Blusmbl
Plymouth, MI
Quick update on this one. I ran it at Roadkill Nights a couple weekends ago, it did great there and I did spray it for 2 of those passes but I had a mild ramp in the progressive, and it also was on the street so I didn't get any times. I drove it the 40 miles to Milan Dragway last night and got 3 passes in. 1st all motor pass was a 12.58 @ 107, the air was much worse (3000' DA, 80+ degrees out) than when I ran a 12.46 at Norwalk last year, so I was happy the car was performing like usual. Tried to make a nitrous pass for my second one. Purge worked, but the WOT switch didn't make contact and it slowed down to a 12.64. Whoops! Third pass, we fixed the WOT switch, and I was rewarded with a 11.37 @ 118.5!!! Straight up stoked it picked up 1.2 seconds with a 180 shot, I wasn't expecting it to run that well, I was going to be happy with an 11.80 or better due to the weather conditions, and I think I startled the timeslip lady when she handed it over. I was watching the wideband in the car and it was not going lean going through the traps, so that gives me hope that the mechanical pump is keeping up with the fuel demand, and I have some margin to jet it up just a smidge more. Now I'm already thinking about what I can do to get just one 10.9x timeslip out of it. Figure that's plenty quick for no rollbar, stock lap belts, a column shifter, and 4300 pounds!!
[Re: Jerry]
#3071275
08/25/22 07:39 AM
08/25/22 07:39 AM
n20mstr
NICE ! Congrats So happy you hit that goal.....AND almost exceeded it !! By the looks of that mph and 60foot , there is plenty left in it What was the wideband reading?? Looks like that nitrous bug got you now
[Re: n20mstr]
#3071280
08/25/22 08:09 AM
08/25/22 08:09 AM
Blusmbl
Plymouth, MI
Thanks Jerry! NICE ! Congrats So happy you hit that goal.....AND almost exceeded it !! By the looks of that mph and 60foot , there is plenty left in it What was the wideband reading?? Looks like that nitrous bug got you now Totally hooked!!! Thank you so much for the advice both here and in PM's, and the congrats. I couldn't be happier with it, although I'll say that again when I get it in the 10's, lol It's so heavy I think it still needs more gear to get off the line. I might step down to a 275 pro to shorten the final drive up some and help it out. It didn't really spin and I don't have a trans brake so I'm not sure how I can get it to launch any harder besides giving it more gear ratio or swapping the converter. I have the wideband reading in lambda so it was 0.80-0.82 when I looked at it at in 3rd, so 12.05-ish to 1 air fuel. I was so happy I packed up and didn't bother to check plugs after the pass, but I did at Roadkill Nights after a nitrous pass and they looked great, the timing mark was about where it needed to be. I ran Roadkill on straight 93. Timing is 38* on motor, and then I had the timing retard pull 9* when the nitrous is activated. It's got a 73 jet in the plate and to be safe I ran it on a 50/50 mix of 93 and 100. I'm guessing I could've pulled a degree or two less timing on the race gas and it would've still been ok.
[Re: tboomer]
#3071294
08/25/22 09:00 AM
08/25/22 09:00 AM
Posts: 10,021 MN
JERICOGTX
MN
Nice job Nick! Looks like the car lost some weight behind the steering wheel.
69 GTX
68 Road Runner
[Re: Blusmbl]
#3071298
08/25/22 09:13 AM
08/25/22 09:13 AM
n20mstr
Thanks Jerry! NICE ! Congrats So happy you hit that goal.....AND almost exceeded it !! By the looks of that mph and 60foot , there is plenty left in it What was the wideband reading?? Looks like that nitrous bug got you now Totally hooked!!! Thank you so much for the advice both here and in PM's, and the congrats. I couldn't be happier with it, although I'll say that again when I get it in the 10's, lol It's so heavy I think it still needs more gear to get off the line. I might step down to a 275 pro to shorten the final drive up some and help it out. It didn't really spin and I don't have a trans brake so I'm not sure how I can get it to launch any harder besides giving it more gear ratio or swapping the converter. I have the wideband reading in lambda so it was 0.80-0.82 when I looked at it at in 3rd, so 12.05-ish to 1 air fuel. I was so happy I packed up and didn't bother to check plugs after the pass, but I did at Roadkill Nights after a nitrous pass and they looked great, the timing mark was about where it needed to be. I ran Roadkill on straight 93. Timing is 38* on motor, and then I had the timing retard pull 9* when the nitrous is activated. It's got a 73 jet in the plate and to be safe I ran it on a 50/50 mix of 93 and 100. I'm guessing I could've pulled a degree or two less timing on the race gas and it would've still been ok. Remember to approach your tuning in baby steps, easy to get greedy and hurt it Optimize what you have before going to a bigger jet, then you know what A/F and timing the engine likes so you close when going to a larger jet First thing i would look at is the AF, 12.0 is a tad rich im sure. Leave the timing low and lean it out 1/2lb at a time ( Induction Solutions has flow gauge on sale right now) Or just reduce the fuel jet .02 or so at a time Once you get the AF good , what to look for, drop in fuel and it picks up MPH, you went the right way Once the AF is good, add a .5 degree or 1.0 degree at a time, Again if it picks up...its good, if not go back. Check a plug or two, at least look for heat on the straps. On a BB mopar no heat is good, or just on the edge of the strap thats it you will be surprised how much these two things will pick the car up, i bet you can go over 120mph. As far as that 60 foot....have you been purging before a pass?? IF not you will see a big difference for sure. Even if you bang it through the engine it will help a lot. Happy ET hunting
[Re: HardcoreB]
#3071304
08/25/22 09:35 AM
08/25/22 09:35 AM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Excellent! Congrats, Nick! Car looks cool, and would hurt some feelings as a legit street car LOL
"Any fool can know. The point is to understand"
- A. Einstein
[Re: EvilB1Dart]
#3071323
08/25/22 10:38 AM
08/25/22 10:38 AM
an8sec70cuda
That's awesome!
[Re: an8sec70cuda]
#3071347
08/25/22 12:00 PM
08/25/22 12:00 PM
GY3
Wichita
Sweet! 10's are just around the corner!
[Re: GY3]
#3071349
08/25/22 12:02 PM
08/25/22 12:02 PM
Bad340fish
Tulsa OK
Sweet! 10's are just around the corner! Its a slippery slope!
[Re: n20mstr]
#3071440
08/25/22 07:38 PM
08/25/22 07:38 PM
Posts: 2,070 CA
crackedback
CA
Thanks Jerry! NICE ! Congrats So happy you hit that goal.....AND almost exceeded it !! By the looks of that mph and 60foot , there is plenty left in it What was the wideband reading?? Looks like that nitrous bug got you now Totally hooked!!! Thank you so much for the advice both here and in PM's, and the congrats. I couldn't be happier with it, although I'll say that again when I get it in the 10's, lol It's so heavy I think it still needs more gear to get off the line. I might step down to a 275 pro to shorten the final drive up some and help it out. It didn't really spin and I don't have a trans brake so I'm not sure how I can get it to launch any harder besides giving it more gear ratio or swapping the converter. I have the wideband reading in lambda so it was 0.80-0.82 when I looked at it at in 3rd, so 12.05-ish to 1 air fuel. I was so happy I packed up and didn't bother to check plugs after the pass, but I did at Roadkill Nights after a nitrous pass and they looked great, the timing mark was about where it needed to be. I ran Roadkill on straight 93. Timing is 38* on motor, and then I had the timing retard pull 9* when the nitrous is activated. It's got a 73 jet in the plate and to be safe I ran it on a 50/50 mix of 93 and 100. I'm guessing I could've pulled a degree or two less timing on the race gas and it would've still been ok. Remember to approach your tuning in baby steps, easy to get greedy and hurt it Optimize what you have before going to a bigger jet, then you know what A/F and timing the engine likes so you close when going to a larger jet First thing i would look at is the AF, 12.0 is a tad rich im sure. Leave the timing low and lean it out 1/2lb at a time ( Induction Solutions has flow gauge on sale right now) Or just reduce the fuel jet .02 or so at a time Once you get the AF good , what to look for, drop in fuel and it picks up MPH, you went the right way Once the AF is good, add a .5 degree or 1.0 degree at a time, Again if it picks up...its good, if not go back. Check a plug or two, at least look for heat on the straps. On a BB mopar no heat is good, or just on the edge of the strap thats it you will be surprised how much these two things will pick the car up, i bet you can go over 120mph. As far as that 60 foot....have you been purging before a pass?? IF not you will see a big difference for sure. Even if you bang it through the engine it will help a lot. Happy ET hunting Nice tuning tips. Always sneak up on it. If you knew what AFR it liked best on motor, likely it will be very close to those numbers on juice. Have fun!
[Re: n20mstr]
#3071458
08/25/22 08:57 PM
08/25/22 08:57 PM
Blusmbl
Plymouth, MI
Happy ET hunting
Thank you Tony! I need to print this off and paste it in my track toolbox as a reminder how to not hurt it. This is great info, especially about the timing. It makes total sense to not bother advancing it if it doesn't pick up any mph. I did purge before that pass. I was originally going to just bang it through the motor but with how the mini progressive is set up I would've had to add a few diodes to the circuit I wired in, and figured it was easier to just put a purge solenoid on it. I drilled out the antenna and ran the line through the antenna hole. Thinking about the launch further, I could've left a little further up against the converter. I was only at 2500 or so when I left, my car is heavy enough it probably will benefit from it. I have the nitrous set up on a window switch from 3500 to 6500 plus the WOT switch, so it shouldn't be a big deal if I get it to 3500 footbraking. I've watched the video of my car a few times and I'm thinking I need to ditch my air shocks for sure as well, I don't think they're controlling the rear well enough. Thanks to you guys I have a few things to try next time out, and I hope I can get a couple more tenths and 1-2 more mph out of it without upping the nitrous jet yet. Jeff - it's just a good angle, lol. It would pick up 1.5 tenths just with you driving it, but I think your head would explode at my shifter setup! Wes, thank you, really appreciate that. I've put about a thousand miles on it this year. It's just a fun car to cruise, and I'm having even more fun with it now that it's getting to be decently quick. I really hope 10's are just around the corner!
[Re: Blusmbl]
#3071562
08/26/22 10:14 AM
08/26/22 10:14 AM
Posts: 2,255 IL
furious70
IL
That's awesome!!! Saw you on the live feed!
[Re: furious70]
#3071647
08/26/22 03:00 PM
08/26/22 03:00 PM
Blusmbl
Plymouth, MI
3.5" pipes, 2 chamber Flowmasters, and no tailpipes. Not terribly classic of a sound but I love it.... and my neighbors do not. lol Saw you on the live feed! Next year I'm definitely going to try spraying it out of the hole out there, the road was surprisingly good. They missed my one good, close run against an early Nova. I lined up against Jim for all of the others, and his Charger made it look like the Fury still had a 318 in it... especially with my naps for reaction times.
[Re: Blusmbl]
#3071702
08/26/22 08:18 PM
08/26/22 08:18 PM
Posts: 2,070 CA
crackedback
CA
Maybe try leaving closer to idle to hit the converter. Just thought.
Slow the video down to .25x speed and watch how the car reacts when leaving.
Seems a bit travel limited up front.
[Re: crackedback]
#3071778
08/27/22 10:12 AM
08/27/22 10:12 AM
Blusmbl
Plymouth, MI
Thanks Rich!! Maybe try leaving closer to idle to hit the converter. Just thought.
Seems a bit travel limited up front. Thanks, I definitely have some things to try now in addition to the nitrous tuneup. I've watched the video a bunch and agree it seems to run out of front travel quickly, and once the front suspension tops out the car porpoises. I don't feel that on motor but did feel it on the nitrous pass, each porpoise it felt like it unloaded the rear and tried to spin. The torsion bars are jacked up a little in the front, mostly for oil pan clearance with all of the street driving I do. I'll have to see if I can put a smaller bump stop on it to help with the extension. It also has air shocks in the rear, those need to go as well. It has a snubber which is adjusted pretty close to the floor. I think chassis wise next outing I'll try leaving from both a lower and higher rpm to see if it likes either of those any better. I also can try lowering the front so it has more available droop, and also letting the air out of the air shocks. I have clamps on the front of the leaf springs on both sides, I'm surprised how violent it looks after watching it slowed down, it's hitting the tire hard which from what I understand is good for a radial. I've had multiple people tell me to not waste money on the cheaper drag valved shocks, and Vikings are the only adjustable fronts, so I think if I do anything I'll do it all - fronts, rears, caltracs and possibly their monoleafs, but only if I can't get what's on it to work. My biggest concern, if it loads and unloads a bunch in 1st gear that it will hurt the sprag in the trans, the valve body doesn't have low band apply.
[Re: Blusmbl]
#3071816
08/27/22 12:53 PM
08/27/22 12:53 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
My old S/P car had single adjustable steel Koni coil overs on the frontend with A arms, I switch them to a set of Afco 36-way double adjustable aluminum coil overs and it help that car 60 Ft better and react quicker once I got them adjusted to what that car needed: work: I agree on getting rid of the air shocks and better front shocks, you will maybe have fun tuning them and go quicker with better reaction times
[Re: Cab_Burge]
#3071979
08/28/22 05:39 AM
08/28/22 05:39 AM
Posts: 234 Brisvegas, Australia
Alchemi
Love your car mate, I too have a 68ht, to give your self options, it may be worth considering customising the front shock mount in the stub frame, i haven't tried too hard to find adjustable shocks, but its looking like im going to have down load some catalogues with specs. The C Body front shocks are very short, 8" compressed - 12.25 extended. What the hell the factory was thinking I have no idea (space no doubt).
If anyone has some suggestions, brands or part numbers, im all ears
I assume you have scaled the car? Hows your front to rear percentages? I've seen numerous different weights listed for various C's, real life and random spec sheets. The fury is meant to be the lightest, kinda worried cause mine has AC and a similar trim level to yours plus a 9 on the under body deadening section on my build sheet lols.
The real world weight loss thread on here is a gold mine of info, after the usual low hanging fruit the one that stands out to me with the C is our bolt sizes are generally a "size up" compared to A-B's, so lighter, or drilled bolts through much of the non stressed items will be pretty worth while.
[Re: Alchemi]
#3072036
08/28/22 11:19 AM
08/28/22 11:19 AM
Blusmbl
Plymouth, MI
Thanks Cab! Agree, it seems like a worthwhile investment, and I would expect the car would react a little quicker with better shocks. It moves around sloppily like a no prep car, it just doesn't have the front end travel to match, lol
Alchemi, thank you! Yep- the short front shock is definitely a problem. The rear is common with B bodies so anything you want is available. I've looked all over for adjustable shocks for the front. You can get KYB's, Gabriels, and Monroes for non-adjustable. AFCO and Viking show that they offer an adjustable front shock for the 65-up Furies, but the AFCO one looks to be the same part number as the B body front shock so I don't think that will work, it's 16" long instead of 12". The Viking front has a specific part number for the Fury, it's B2002 for their double adjustable but still street oriented shock, and look to be $200 apiece. They also have the B3002 which is the race oriented valving and those are $275 per shock.
I will give them a call to see what they recommend for my car. Your idea of modifying the upper shock mount is a good one too, I need to look at it further but there has to be a way to get a longer shock and have some more travel up there.
I did scale my car last year, before I put the nitrous kit on it (so figure another ~15 pounds of stuff), and I also weigh between 285-300 depending on how many cheeseburgers I've had that week.
3/4 tank, without me, 4027 pounds:
LF: 1085 RF: 1072 LR: 951 RR: 919
3/4 tank, with me: 4330 pounds:
LF: 1194 RF: 1113 LR: 1089 RR: 934
53.8% front, 46.2% rear.
I haven't done anything for weight reduction yet. I can pull the HVAC box out, none of it works anyway. It has 2 layers of carpet, I could remove one of those easily. I also have a manual brake pedal assembly for it that I haven't installed yet, that would get rid of the booster, a vacuum canister, and a vacuum pump that is installed to run the power brakes. Beyond that I think I'd need to start drilling holes and removing bolts. Maybe a lightweight battery too. And go on slimfast, lol
[Re: Blusmbl]
#3107241
01/01/23 02:14 PM
01/01/23 02:14 PM
Blusmbl
Plymouth, MI
Bumping this up just to keep track of progress more than anything. Goal is get into Roadkill nights again, run 11.50's turned down at Drag Week if I get in, and to run solidly in the 10's by the end of this year.
Since this thread I picked up Viking shocks for all 4 corners, Crusader valving for the rear, B body Caltracs, Calvert stock height split monoleafs, AREngineering front spring hangers and new shackles. Have new Firm Feel tubular UCA's on the way but they haven't arrived yet, will replace LCA bushings, the UCA's, and install the front Vikings all at the same time.
I installed the Caltracs/split monos yesterday since it was almost 60* outside. Have to recheck pinion angle, and also come up with some type of spacer for the lower shock mount as the grommets on the Vikings are smaller than OEM so they have 1/4" of lateral movement on the shock mount. Hoping that ditching the air shocks and worn out springs pick the 60' up a little. From there I want to spend more time tuning the nitrous, there should be some gains there.
If I can sell one of my motorcycles, I am going to swap the heads for Trick Flows, step up to 1 7/8" TTI headers, and redo the exhaust too so it's quieter for extended freeway cruising, but I'll put cutouts on it since whatever it gets replaced with won't flow as well as what's currently on the car.
The stock rods are a risk so I'm going to be more cautious and not run it much past 6000 rpm though. Eventual goal is a 512 stroker and then it'll get good internals but that's 2-3 years down the road. The other risk is the 8 3/4, we'll see if it lasts the season!
[Re: Blusmbl]
#3107360
01/01/23 10:28 PM
01/01/23 10:28 PM
GY3
Wichita
Wow, big upgrades! I love this car!
One little thing I might add: Get the shocks as close to vertical as possible. We relocated the upper mounts out towards the framerail.
[Re: GY3]
#3107401
01/02/23 01:43 AM
01/02/23 01:43 AM
Posts: 16,473 On the run…
BloFish
On the run…
I agree, worth the effort.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3107441
01/02/23 09:54 AM
01/02/23 09:54 AM
Blusmbl
Plymouth, MI
Thanks, appreciate it!!
I cut down the sleeves for the shocks yesterday so they are in correctly now. It also looks like the pinion angle is 2* nose up compared to the trans so I have 4* shims coming from Calvert, then the rearend should be done.
Would I need a different length shock if they get remounted vertically? The C channel they're attached to looks pretty easy to modify. Have been meaning to make a set of subframe connectors and patch the wheelhouses anyway, moving the shocks shouldn't be too much of an issue.
[Re: Blusmbl]
#3107449
01/02/23 10:20 AM
01/02/23 10:20 AM
Bad340fish
Tulsa OK
Keep an eye on the stock spring perches. The caltracs put way more load on them and they can start to roll over. If you have a welder or fab buddy it would be easy to reburn the factory welds and add some gussets. Calver also makes some real nice perches that are reinforced.
What mufflers are those that are on there?
[Re: Bad340fish]
#3107813
01/02/23 09:19 PM
01/02/23 09:19 PM
Blusmbl
Plymouth, MI
What mufflers are those that are on there? That explains the "HD perches" option on Quick Performance rearends and the boxed option on the perches for the Strange S60, I had no idea those were needed but it makes sense now. Thanks! I have a welder, while it won't be pretty I should at least be able to reinforce it a little. Mufflers are 3.5" 40 series Flowmasters. I love how it sounds, but the hearing loss I've had over the last couple years is saying it should be quieted down some, lol. If I get into Drag Week and don't have a chance to put tailpipes on it I'll toss another set of mufflers on the end for the street drives.
[Re: Blusmbl]
#3107815
01/02/23 09:25 PM
01/02/23 09:25 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Looking good, Nick! I'll have to swing by again some day and go for a ride. Maybe road trip the Imperial?
[Re: Blusmbl]
#3108012
01/03/23 02:29 PM
01/03/23 02:29 PM
ZIPPY
S.E. Michigan
Great work!
I'm in the same boat with exhaust + years of playing onstage next to hard hitting drummers haven't helped too much.
Rich H.
Esse Quam Videri
[Re: Blusmbl]
#3108082
01/03/23 03:02 PM
01/03/23 03:02 PM
GY3
Wichita
I went ahead and used my old Calverts and they don't bottom out. I gave Viking the dimensions for the new shocks. Then again, I didn't mount them totally vertical, either.
[Re: GY3]
#3108192
01/03/23 04:31 PM
01/03/23 04:31 PM
Bad340fish
Tulsa OK
I know some drag week guys run 3.5" Ultraflows and they claim they are fine on the road.
[Re: Bad340fish]
#3108194
01/03/23 04:48 PM
01/03/23 04:48 PM
GY3
Wichita
I know some drag week guys run 3.5" Ultraflows and they claim they are fine on the road. I run 3" Ultraflows with turndowns in front of the rear axle and they are pretty quiet going down the road but have very little restriction. The only problem I've had is the drivers side likes to crack where they stamped "Dynomax" in them. Drill stopped and welded and they seem to be fine.
[Re: GY3]
#3108361
01/04/23 09:09 AM
01/04/23 09:09 AM
Blusmbl
Plymouth, MI
Thanks guys!
Feets, you should come up for the Dream Cruise when your Imperial is back together!
Rich, totally. Work tracks my hearing as part of my CDL test and it took a significant dive in the last 2 years, from better than most to below average. I need to stop that trajectory. You're always playing next to a loud rhythm section too.
GY3, thanks for the exhaust and shock info. Sounds like I can at least stand them up a little further without worrying about bottoming them out but I'll have to measure.
Clark, those would definitely be the quick and dirty backup plan if I don't have time or $$$ to put a full TTI system on it.
For now I'm waiting on the new UCA's, LCA bushings, and the pinion angle shims should be here tomorrow. Another problem just popped up, one of the rear wheel cylinders has sprung a leak. Easy fix but the tires are super difficult to get off the car, the rearend is just a smidge too wide and the wheel lip hits the drum trying to get the tire in past the quarter. Without the air shocks on it and fully extended I have to deflate the tires and ratchet strap them to get them past the quarter. Debating one of the $600 rear disc kits that should give the tire/wheel a little more clearance compared to the drum. It never stops, lol
[Re: Blusmbl]
#3108546
01/04/23 06:13 PM
01/04/23 06:13 PM
Posts: 4,040 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Nice work! I may have some pieces to help you build a decent motor or two...
[Re: Blusmbl]
#3109003
01/05/23 03:22 PM
01/05/23 03:22 PM
Posts: 571 Spring Hill Fl
65Fury440
Spring Hill Fl
Thanks guys!
I enjoy your car and watching your progress racing. I had a 68 Sport Fury with a 383 330 hp that I did a lot of work on to race, reminds me of that car. If you are going 11s with that beast, I would forget about spending $600 on brakes and start looking for a Dana. Would be a shame to break the diff and all the other problems it can cause. Thanks for the posts!
[Re: 65Fury440]
#3109172
01/05/23 09:06 PM
01/05/23 09:06 PM
Blusmbl
Plymouth, MI
493_john, I really appreciate that. Thank you! I enjoy your car and watching your progress racing. I had a 68 Sport Fury with a 383 330 hp that I did a lot of work on to race, reminds me of that car. If you are going 11s with that beast, I would forget about spending $600 on brakes and start looking for a Dana. Would be a shame to break the diff and all the other problems it can cause. Thanks for the posts!
Thank you. I've had a '67 Imperial and '68 300 in addition to the Fury, just seem to gravitate towards the big and oddball cars. The Sport Furies are cooler for sure! Good point on the Dana. I should replace the 8 3/4 before it breaks and then also rolls the sprag in the trans. It has aftermarket Moser axles, and the converter hits pretty soft, but it's gotta be on borrowed time at this weight and power level.
[Re: Blusmbl]
#3109174
01/05/23 09:09 PM
01/05/23 09:09 PM
Posts: 34,870 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
neat car 8 3/4 still hanging in there ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#3122938
02/19/23 09:26 PM
02/19/23 09:26 PM
Blusmbl
Plymouth, MI
Thread update! Weather was not crappy today, got the Firm Feel UCA's installed along with the Viking Warrior front shocks, so now the suspension is completely done! Just need to get it aligned.
Thanks to rickraw's Summit discount codes, I have a set of Trick Flow 270's on the way, ETA is sometime in June, and Wilwood rear discs to match my fronts have shown up already. I don't trust the 8 3/4 if I go any quicker and don't want to have to pull the trans every time I break it, so the plan is to order a Strange S60 this week. Was considering a 9" but the snout is about an inch shorter than an 8 3/4, so I'd need another new driveshaft, instead of my existing one getting shortened. At that point the Dana is cheaper. Planning on 35 spline axles, 4.10's instead of my current 4.30's, a truetrac, and about 1/2" narrower, so hopefully between the rear being narrower and the discs, the wheels will be easy to get on and off the car again.
I'm debating if I'm going to bolt the heads right to this shortblock. It runs great right now, doesn't have any blowby, and everything works together well. My concern is with better heads it's going to want to rev to the moon, and it still has stock weight TRW 2355's in it so I'm worried the LY rods are going to yeet themselves if I rev it much past 6500.
Option 1 is use the 270's on the 446 shortblock and run that for a couple years until my wallet recovers. I need to buy new rockers anyway, could pick up some 1.6 instead of 1.5 Harland Sharps to get the lift up to 0.630-ish, and leave everything else the same (850 DP Holley, TM7 intake, MP cam, 1 3/4" headers), and try to keep the engine speed below 6500 to reduce stress on the rods. Guessing it would pick up 4-ish tenths from the head/rocker swap, and then I could jet the nitrous up a little further which should get me solidly into the 10's.
Option 2 is to leave it as is this year, then over the winter pull it and put a lightweight 512 stroker rotating assembly in it, with main studs, new caps, fresh machinework, etc. It would also get the heads, a roller cam, MW sized intake, and I'd upgrade the headers to the 1 7/8" TTI's. It's only money, right? Lol
Thoughts?
Thanks, Nick
[Re: Blusmbl]
#3122983
02/20/23 12:43 AM
02/20/23 12:43 AM
Posts: 2,255 IL
furious70
IL
you want the manual steering box in it before you bother aligning it, don't you?
[Re: furious70]
#3122992
02/20/23 07:28 AM
02/20/23 07:28 AM
Bad340fish
Tulsa OK
On those rear willwoods be sure to account for the rotor had thickness in your overall width. My set the hats are 1/2" thick so it adds 1" to the WMS width. Just about screwed myself on that one, my tires fit within 1/4" and that would have been an expensive redo.
New plan sounds good, faster never hurt anyone lol.
[Re: Bad340fish]
#3122997
02/20/23 08:18 AM
02/20/23 08:18 AM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
Thanks Doug! That's what I'm thinking for now too. Then if the shortblock ever gets hurt, then swap out the rotating assembly. Maybe 6k for shift points and then make sure it doesn't go above 6500 in 3rd.
Jeremy- definitely. I should be cruising through around easter. I also saw some tie rods that needed attention and the idler arm could use replacing too, I should do all of that at once! I assume it's gonna take at least a month for the rear to show up anyway so I have time.
Clark- thank you for the heads up. I should pull the brake kit out of the box and measure, that would've been a bad deal. My tires are as close as yours and I was hoping to get a smidge more clearance, without having them tucked in too far. A half inch out from where they are now would wreck everything, lol
[Re: Blusmbl]
#3123081
02/20/23 02:13 PM
02/20/23 02:13 PM
Posts: 5,161 CT
GTX MATT
CT
Thoughts?
Thanks, Nick I’m in a similar boat as you, and i’m putting the 270s on my built 446 short block (forged pistons & scat rods). The guides in my stealth heads are shot though. I bought 240s last year, then sold them for 270s. Ive had an Eddy Super Victor with MW ports on backorder since May. It JUST shipped. Summit has 4 more in stock, I’d buy one now if you can swing it. I was just gonna run my intake for now until it came in if the intake didn’t show up before the head swap. You’d be .594 before lash if you go to 1.6 rockers. I’m only .520 with 1.5s, might go to 1.6s later. I wish I had a little more lift but I’m happy with my cam and don’t want to risk breaking in another FT, and don’t want a solid roller. Its not going to rev to the moon with the 270s in my opinion, it will just make alot more power upstsirs. You don’t HAVE to keep revving it, but I know its hard not to!
Re: Thoughts on what to change to run mid 11's?
[Re: Blusmbl]
#3123083
02/20/23 02:37 PM
02/20/23 02:37 PM
ZIPPY
S.E. Michigan
All of the potential plans sound pretty good!
Only one tiny advantage I can think of, if you were to bolt the new heads on the existing 440 you could then sell the 906s for probably 350-500 to water the money tree a little.
But then they wouldn't be available as spares anymore, if you figure you might ever need spares....so maybe not.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3123431
02/21/23 03:14 PM
02/21/23 03:14 PM
Blusmbl
Plymouth, MI
Sean - I definitely think it could use some weight loss! I was planning on switching to manual steering (especially if I put the aluminum heads on it to get 40 pounds off the front!), and was probably going to switch to manual brakes with an aluminum master which would get rid of the booster, my vacuum pump, and vacuum canister. Beyond that I'm struggling for ideas though, it already has an aluminum radiator and 4 wheel discs. I could maybe pull half of the bumper brackets off? Or start drilling holes in inconspicuous places. If somebody made a fiberglass hood I'd buy it in a second, the original has to weigh 100 pounds!
GTX Matt- thanks for the heads up on the intake. I was hoping to keep my 4150 based carb and nitrous plate kit but if there is a ton of performance to be had by switching it I'd consider it! After reading Andy's articles on his 470, comparing the 240 to 270, the 270's seemed like a no brainer. Engine Masters did the same test, the 270's were better everywhere.
I think the 0.590 cam has 0.393 lobe lift, which should be 0.628 before lash with a 1.6 rocker. I might be doing the math wrong though?
Rich- yeah, that's an enticing idea! If I pull them off and they aren't cracked I could sell the heads, pushrods and HS rockers as a package deal for sure.
[Re: Blusmbl]
#3123532
02/21/23 10:22 PM
02/21/23 10:22 PM
Posts: 5,161 CT
GTX MATT
CT
My mistake, I thought you were running the 557, you got it right! And I’m not sure in the 4150 vs 4500 carb being a gain, but enginemasters ran an XP 4150 which is dual pattern. I’m still figuring out how I will run a 4150 on the intake (which adaptor), but if you’re going to eventually go stroker I would think a 4500 will help you. I’m not sure that the extra plenum volume on the Super Victor didn’t help EngineMasters tests, and I’m scared to run the Indy 440 2D.
[Re: GTX MATT]
#3123941
02/23/23 12:11 PM
02/23/23 12:11 PM
Blusmbl
Plymouth, MI
493 John- I like the bench seat but I like the idea of getting weight out of it that way. I need to start looking at what can be cut out in terms of brackets and stuff.... especially for the backseat. Nobody sits in it!
Doug, thank you for the offer. I may take you up on that. It drives fine and I didn't notice any play in the front end, but I did buy LCA bushings just in case. Looking at them, they're intact... just dry. I've also never had torsion bars out of a Mopar front end before so am a bit gunshy to do them, lol
GTX Matt- yeah, honestly it's overcammed for what it is now but with more compression and substantially better heads it should do better. The converter is loose enough that it can take advantage of it. That's a good point on the intake too, a 512 would benefit for sure from a 4500 sized flange.
[Re: Blusmbl]
#3123962
02/23/23 12:56 PM
02/23/23 12:56 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
I had always wanted to gut a back seat and only keep as much framework as necessary to keep it's shape then stuff a couple of blow up pool floats to make it look like everything was still in there, same with a passenger side bucket seat .
[Re: GY3]
#3124148
02/24/23 12:06 AM
02/24/23 12:06 AM
Jeremiah
Rogue River, OR
More jet and a go pro...send it.
Dvw makes a good point concerning the front end. You should do heim joint strut rods and greasable LCA pins if it gets town down that far.
Perhaps some rear air shocks for the bitchin stance?
[Re: Jeremiah]
#3125372
02/28/23 04:58 PM
02/28/23 04:58 PM
Blusmbl
Plymouth, MI
Ok, minor change of plans. I was on the waitlist for Sick Summer and was accepted this morning, so barring any catastrophes I’m doing my first drag and drive this June!
The car won’t be legal past 11.50 so I’m going to leave the motor alone, and jet it down a little to slow it down to 11.60’s.
In the meantime I need to get cracking on the rearend purchase so the rest of the car is bulletproof.
[Re: Blusmbl]
#3125374
02/28/23 05:02 PM
02/28/23 05:02 PM
Posts: 1,403 Chesterfield Twp. Mi.
John Burdine
In the meantime I need to get cracking on the rearend purchase so the rest of the car is bulletproof. That's cool, glad you got in.
[Re: Blusmbl]
#3125390
02/28/23 05:55 PM
02/28/23 05:55 PM
GY3
Wichita
In the meantime I need to get cracking on the rearend purchase so the rest of the car is bulletproof. Awesome! I've always wanted to do a drag and drive but just can't take off that long.
[Re: ZIPPY]
#3127038
03/06/23 06:01 PM
03/06/23 06:01 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
Cool to hear. Nice to see some other Mopars in the drag and drives. However, we all have to work more to be able to afford these damn cars.....
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3127077
03/06/23 08:48 PM
03/06/23 08:48 PM
Blusmbl
Plymouth, MI
Thanks, I'm super excited! I wasn't expecting to have a deadline for this season so things have ramped up substantially.
Sold my Road King about a week ago, and almost all of that $$$ went to parts for the Fury. Ordered the Strange S60 from Dr. Diff over the weekend. Ordered a headers-back TTI exhaust system, Plymouth exhaust tips, and Hooker Aerochamber mufflers, so it'll have a full 3" system with tailpipes that should help quiet it down some for the drives. Also bought a spare starter, alternator, spare pushrods, 2 spare rocker arms for what's currently on the engine, and then almost everything to do the cylinder head swap (head gaskets, full Harland Sharp rockers for E heads/Trick Flows, TF intake that I'll have to blend some for the MW 270's, valley plate, head bolts, Comp 928 springs to match the cam, etc).
It is looking grim for the heads to show up in time for the event, but that shouldn't be a problem, I'll just install those over the winter when I'm done with it for the season.
Also bought billet Motion Raceworks cupholders, a small bluetooth Kenwood amp, and dash and 6x9 speakers. It's going the wrong way with weight with the full exhaust and stereo, but if I have to spend 6 hours a day in it driving I had to prioritize tunes!
The rearend should hopefully get here by the 1st week of May, will toss that in immediately with the Wilwoods, bend up some brake lines, then will need to get the driveshaft cut down/rebalanced. Have a new speedo gear on the way from Brewers too.
Last stretch goal will be to patch the large cuts in the outer wheelhouses that were previously made for tire clearance. I might try that myself or see if I can find a local fabricator that could do it in a week or two. It doesn't have to be pretty, I just don't want a monsoon getting into the trunk. lol
[Re: Blusmbl]
#3128357
03/11/23 10:48 AM
03/11/23 10:48 AM
Posts: 5,161 CT
GTX MATT
CT
Also bought billet Motion Raceworks cupholders, a small bluetooth Kenwood amp, and dash and 6x9 speakers. It's going the wrong way with weight with the full exhaust and stereo, but if I have to spend 6 hours a day in it driving I had to prioritize tunes! What speakers did you buy? I recently put a sound system back in my car after years of no music and its so much better. Alpine S series sound really good for a cheaper/entry level speaker, my 6x9s really crank out the lows well just off of an old Kenwood receiver. I mounted 2 4s to a custom plate in the dash.
[Re: GTX MATT]
#3129125
03/13/23 05:57 PM
03/13/23 05:57 PM
Blusmbl
Plymouth, MI
Nothing fancy, just some 3 way JBL club 6x9's. For the front I saw the plates that adapt two 4" speakers to the 4x10 dash hole and I totally would've gone that route, except the Fury's main dash trim piece comes very close to the original 4x10 speaker on the left side, and if there was a larger magnet I'd have to cut the dash bezel. The twin 4's have to sound so much better than the 4x10! I went with this amp Kenwood and figured I can make a little bracket for the controller that will hide behind the billet cupholders I purchased, lol If I can hear any tunes over the exhaust I'll be happy enough with it. Sounds like my TTI order shipped so I can get started on the exhaust install this week. Diff is likely another 7 weeks out though.
[Re: Blusmbl]
#3131317
03/22/23 06:06 AM
03/22/23 06:06 AM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
In the meantime I need to get cracking on the rearend purchase so the rest of the car is bulletproof. Right-on! Cool that you got in. Keep grinding!!!
- A. Einstein
[Re: EvilB1Dart]
#3131334
03/22/23 08:27 AM
03/22/23 08:27 AM
Blusmbl
Plymouth, MI
Thank you!! I'll be in a holding pattern soon until the rearend shows up, but that should only be a weekend's worth of work or so, plus the time to get the driveshaft cut down.
So far I've got the *incredibly important* billet cupholders and stereo installed. The TTI exhaust showed up yesterday, should be able to install that this weekend. My Trick Flow 270's also surprisingly showed up last week but I'm still waiting on the valley plate and intake, I won't install those until after Sick Summer.
[Re: GY3]
#3131699
03/23/23 01:54 PM
03/23/23 01:54 PM
Blusmbl
Plymouth, MI
On an aluminum bracket that mounted the stereo volume control and slides with the seat!
I'm guessing between the extra weight of the exhaust, the dana, and the swap from 4.30's to 4.10's, it's going to slow down at least a tenth on motor. Like Tony said, nothing the 7/16 wrench can't fix. lol
[Re: HardcoreB]
#3134586
04/02/23 08:44 PM
04/02/23 08:44 PM
Blusmbl
Plymouth, MI
It's a definite possibility!! I'm close to having all of the parts to do the head swap, just waiting on the regular Trick Flow intake, and I'd need to order pushrods. If nothing else shows up this month I may do the head swap out of boredom until Strange finishes the S60! I test fit the TTI exhaust today and I'm unfortunately on the fence about it. Their systems for all of the other Mopars put the tailpipes in the right spot, these end up lower than a normal setup and the tips look pretty bad when installed because of the 3" gap to the bumper. The passenger side tailpipe was also grounding out on the shock crossmember, I could fix it with a couple solid whacks from a hammer though. Tailpipes seem like the right choice for a drag and drive car, but I may punt on this for now and just go with plan B of earplugs.
[Re: Blusmbl]
#3134744
04/03/23 01:14 PM
04/03/23 01:14 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Nice progress man!
Thing is going to be humming with 4.10s. Thought of cruising on a 30" tire and racing on a 28"?
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: Blusmbl]
#3134765
04/03/23 01:47 PM
04/03/23 01:47 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
That's a tough situation with the tailpipes. Could a section be cut out and welded up to tuck them in better?
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3134775
04/03/23 02:03 PM
04/03/23 02:03 PM
Posts: 10,021 MN
JERICOGTX
MN
Block of wood, and a floor jack.
69 GTX
68 Road Runner
[Re: John Burdine]
#3134822
04/03/23 04:54 PM
04/03/23 04:54 PM
Blusmbl
Plymouth, MI
Thanks guys! I have 295/65/15 ET Street SS's on it now, they're a little over 30". With my current 4.30's it's at about 3500 rpm at 70, and the 4.10's should bring it down to a nice relaxing 3300! A gear vendors would reduce that further to ~2750 at 70, which is right where the engine/cam has cleaned up enough and it's happy. A gear vendors is a stretch goal for sure but for now I'll just drive it slow.
I eventually want a set of 28's to do some of the daily driver, back of the track races at Milan, but until I swap the rearend, the tall tires are too difficult to get on and off to swap them frequently. The wheel lips are trimmed and the tires still have to be deflated and ratchet strapped to get out from under the car. Between the narrower rearend and discs that should be much easier soon though.
The tailpipes are a bummer for sure. There is at least an inch that could be squished out of the hanger but then they'll hit the shock crossmember even harder. Could maybe pie cut it past the hanger to get them to angle up closer to the bumper? I'm also worried now that the midpipe puts the mufflers too close to the driveshaft as it wasn't designed for a larger than stock driveshaft.
This is from another TTI c body install video, not my car but it's identical under there.
[Re: Blusmbl]
#3134916
04/03/23 09:59 PM
04/03/23 09:59 PM
Posts: 2,255 IL
furious70
IL
3" tailpipes pretty much fit like garbage on my Fury as well, I've never put the turndowns on and they took work to clear everything.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#3134919
04/03/23 10:19 PM
04/03/23 10:19 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
The exhaust looks killer........thing just keeps getting better and looking cooler by the month LOL! I enjoy watching the progress!!
- A. Einstein
[Re: furious70]
#3135377
04/04/23 07:15 PM
04/04/23 07:15 PM
Blusmbl
Plymouth, MI
Thanks Wes! I'm just using this thread as a project update at this point. 3" tailpipes pretty much fit like garbage on my Fury as well, I've never put the turndowns on and they took work to clear everything. After I ordered the exhaust, one of my other friends indicated the same thing, he had to have a shop fix the 3" TTI exhaust on his '68 300, it fit like garbage out of the box. If the mufflers clear my driveshaft I'll take it to an exhaust shop to get the tailpipes tucked up a little further. Also, for the manual steering box, I might be able to pick it up this weekend. I'll text you later. I'll also be in Chicago hopefully in a few weeks to pick up the rearend and could stop by your house then too!
[Re: Blusmbl]
#3135460
04/04/23 11:27 PM
04/04/23 11:27 PM
Posts: 2,255 IL
furious70
IL
we're around this weekend if it works for you!
[Re: Blusmbl]
#3135953
04/06/23 02:06 PM
04/06/23 02:06 PM
feets
Senior Management
Senior Management
Irving, TX
Have you tried popping off the bottom of the shock to get the tires off? It's a pretty common move on Fusey cars with big tires.
[Re: feets]
#3139801
04/21/23 05:44 PM
04/21/23 05:44 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Nick,
Its been a few weeks!!! Anymore updates to that STREET BRAWLER?!??!!
- A. Einstein
[Re: EvilB1Dart]
#3139946
04/22/23 11:33 AM
04/22/23 11:33 AM
Blusmbl
Plymouth, MI
Hah!! Thanks... no noteworthy updates, besides stopping by Jeremy's to pick up the van/C body manual steering box.
I did a mini vacation last week to help my uncle with a 1958 Chrysler 300D he is restoring, then did some motorcycling in NC. Back home until Sick Summer now. My TTI headers showed up yesterday so I can start final installing the exhaust, and likely won't put the exhaust tips on until I can have a shop tuck the tailpipes up a little so it looks better.
Rearend should be done at Strange any week now, they accepted the order on 3/8 and said 8-10 weeks for lead time. Once it's done I'll make a quick day trip out to Chicago to pick it up. Then just need to bolt the Wilwoods on, bend up some brake lines, and get the driveshaft cut down.
[Re: Blusmbl]
#3142050
05/02/23 04:02 PM
05/02/23 04:02 PM
Blusmbl
Plymouth, MI
Update!! Got word the rearend was done, drove out to Chicago and picked it up yesterday. Now I've got some work to do...
[Re: JERICOGTX]
#3142183
05/03/23 08:27 AM
05/03/23 08:27 AM
Posts: 9,824 MI, usa
dvw
MI, usa
[Re: GY3]
#3142227
05/03/23 10:28 AM
05/03/23 10:28 AM
Blusmbl
Plymouth, MI
Thanks guys!
Quick question- are there any major drawbacks to running hard brake lines direct to the calipers on a fixed caliper system? The Wilwood brakes have the calipers fixed, and the calipers don't need to be removed to change pads, so the only time the calipers would ever need to be removed is if I needed to pull the axles. I could do a short section of flex line on each side but am not sure where to secure them to. There are little tabs on the housing but don't think they're designed to hold the weight of a flex line and fitting.
[Re: Blusmbl]
#3142233
05/03/23 10:46 AM
05/03/23 10:46 AM
Bad340fish
Tulsa OK
I did flex lines and just welded a little tab to the axle, but yours is already pretty and painted. I see no reason why you couldn't do a hardline. You could also make a tab that is captured by one of the T bolts that holds the bearing in if you thought you needed a flex line.
[Re: Blusmbl]
#3142239
05/03/23 11:26 AM
05/03/23 11:26 AM
Posts: 4,673 On the parachute mount
n20mstr
Thanks guys!
Quick question- are there any major drawbacks to running hard brake lines direct to the calipers on a fixed caliper system? The Wilwood brakes have the calipers fixed, and the calipers don't need to be removed to change pads, so the only time the calipers would ever need to be removed is if I needed to pull the axles. I could do a short section of flex line on each side but am not sure where to secure them to. There are little tabs on the housing but don't think they're designed to hold the weight of a flex line and fitting. I hope this makes sense, run your hardline on the floor of the body. then mount a tab to hold a bulkhead fitting above each side of the rearend near the frame rail. Run your flex line down to the caliper from that point. Makes it a lot more convenient to NOT have brake lines on the rear housing. Easier to tie it down for towing etc. AND the one time you need to service the caliper, you will wish it had a flex line on it....
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3142266
05/03/23 12:37 PM
05/03/23 12:37 PM
Bad340fish
Tulsa OK
Thanks guys!
Quick question- are there any major drawbacks to running hard brake lines direct to the calipers on a fixed caliper system? The Wilwood brakes have the calipers fixed, and the calipers don't need to be removed to change pads, so the only time the calipers would ever need to be removed is if I needed to pull the axles. I could do a short section of flex line on each side but am not sure where to secure them to. There are little tabs on the housing but don't think they're designed to hold the weight of a flex line and fitting. I hope this makes sense, run your hardline on the floor of the body. then mount a tab to hold a bulkhead fitting above each side of the rearend near the frame rail. Run your flex line down to the caliper from that point. Makes it a lot more convenient to NOT have brake lines on the rear housing. Easier to tie it down for towing etc. AND the one time you need to service the caliper, you will wish it had a flex line on it.... Where was this post in 2018 when I put a Dana in my car? Great idea.
[Re: Bad340fish]
#3142353
05/03/23 06:18 PM
05/03/23 06:18 PM
Blusmbl
Plymouth, MI
That is a great idea! I'll have to see where the lines will end up on the car. And agree- I would just weld little tabs on the axle but I don't want to jack up the powdercoat.
[Re: Blusmbl]
#3142583
05/04/23 09:25 PM
05/04/23 09:25 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Update!! Got word the rearend was done, drove out to Chicago and picked it up yesterday. Now I've got some work to do... Hell yeah!!!! That's a nice piece, Nick! Right-on!
- A. Einstein
[Re: n20mstr]
#3142586
05/04/23 09:34 PM
05/04/23 09:34 PM
HardcoreB
Shelby Twp. Mi
Thanks guys!
Quick question- are there any major drawbacks to running hard brake lines direct to the calipers on a fixed caliper system? The Wilwood brakes have the calipers fixed, and the calipers don't need to be removed to change pads, so the only time the calipers would ever need to be removed is if I needed to pull the axles. I could do a short section of flex line on each side but am not sure where to secure them to. There are little tabs on the housing but don't think they're designed to hold the weight of a flex line and fitting. I hope this makes sense, run your hardline on the floor of the body. then mount a tab to hold a bulkhead fitting above each side of the rearend near the frame rail. Run your flex line down to the caliper from that point. Makes it a lot more convenient to NOT have brake lines on the rear housing. Easier to tie it down for towing etc. AND the one time you need to service the caliper, you will wish it had a flex line on it.... X2 Good choice to upgrade the axle if you're still wanting to add power to this chassis!
[Re: HardcoreB]
#3142911
05/06/23 10:05 PM
05/06/23 10:05 PM
Blusmbl
Plymouth, MI
Right now I’m hoping to make it bulletproof for drag and drive events. I have less than a month until Sick Summer and need to get it drivable again asap! Thinking the goal next year will be getting the Trick Flows installed, and then 2025 will be a 512 kit and beefing up the trans. The chassis should be as far as I can go with a stock suspension C body at this point. The car is at the alignment shop currently but I did get the Wilwoods on yesterday. I do appreciate the irony of doubling the value of the car with a rearend install.
[Re: Blusmbl]
#3143960
05/11/23 04:24 PM
05/11/23 04:24 PM
Blusmbl
Plymouth, MI
I should probably ask to have this thread moved to the projects forum since I'm mostly using it as an update thread instead of advice anymore, but more excitement has shown up! The long story is I dropped it off at a shop just to get it aligned after the new UCA's and steering parts. They put it on the alignment rack, and the balljoints were smoked. Figured it was already there so I had them order balljoints, and wanted to get the UCA bushings done at the same time since it was already apart. After one round of the wrong balljoints showing up, they got the right ones yesterday and they went to do them, the LCA bushings, and the alignment all at the same time. At this point everything in the front end should be new. But wait, they got the driver's side apart and the LCA is cracked at the bushing! I had no idea this was so common on C-bodies. Have a good used one showing up, should see it on Monday and then can get the driver's side back together, the alignment done and back home.... so I can start on the axle swap. lol Getting close on time and I'm starting to worry. I'll have just a little more than 2 weeks to swap axles, get the driveshaft to CCI to get them to shorten it, bleed the brakes, reglue the trunk seal, change the fluids, nut and bolt check the car, and get the nitrous bottle filled along with jetting it down. It needs a couple shakedown drives too, it hasn't really been driven on the road at all this year (but was solid all last year, thankfully). I also haven't made a pass with the Caltracs yet so might be testing that on Sunday before Sick Summer. Going to punt on doing the TTI exhaust, and plan B will be earplugs. I totally understand now why so many cars show up unprepared to these events.
[Re: 65Fury440]
#3145982
05/21/23 12:10 PM
05/21/23 12:10 PM
Blusmbl
Plymouth, MI
I was at the same point with my 65 Fury front end a few years back. Redid entire front end and new torsion bars and Wilwood discs. I wish I had just done a front end swap, like maybe a Crown Vic, for header/oil pan clearance, disc brakes. and ease of maintenance. Love the progress you've made and your car!! Thanks, I appreciate it. You aren't kidding- the front end on these is so weird and it would've made sense to replace with something more modern. Unusually short shocks and poor oil pan clearance. And some of the parts are very difficult to find used, plus not available at all new. Do have some updates since last week. Got the car back after the new lower balljoints, new LCA bushings, the new to me driver’s side LCA, and a fresh alignment. It drives so much better now, I wasn't expecting the difference. Drove it to work on Thursday and got on it a few times, everything else seems ok and the new suspension has made it feel safer for sure. I started the Dana swap yesterday and it's in the car now. Totally relieved, it being slightly narrower and with discs instead of drums, I can get the wheels on and off the car again without having to unbolt anything else! Going to drop the driveshaft off first thing tomorrow to get shortened. Hoping to have a friend come over today to help bleed the brakes. I also am going to swap the speedo gear and attempt to hook up a new set of parking brake cables. Beyond that, it just needs an oil change, gluing on a fresh trunk weatherseal, and a quick nut and bolt check, and it's ready to go for Sick Summer.
[Re: Blusmbl]
#3145985
05/21/23 12:39 PM
05/21/23 12:39 PM
Posts: 4,669 Wichita
GY3
Wichita
Nothing sexier than a Dana 60 peeking out from under that big booty!
[Re: ZIPPY]
#3146485
05/23/23 10:34 PM
05/23/23 10:34 PM
Blusmbl
Plymouth, MI
Thanks guys, I really appreciate it. The current motor is not really capable of hurting the 8 3/4 but I wanted to build it from the drivetrain and suspension up, after breaking so many parts on my Charger. Zippy was there one of the times it spit out an 8 3/4, lol. Can also pride myself that it's likely one of less than a dozen C bodies in the world that ever ended up with a Dana 60 in it. Huge shoutout to CCI here in Detroit. I dropped my driveshaft off to get shortened at 6:40 on Monday morning and had a call by 11:15 that it was finished. Doug recommended them a few years ago and they will definitely get all of my driveshaft business in the future. Swapped the speedo pinion and parking brake cables over the weekend. Hoping it moves under its own power with the Dana tomorrow, which gives me over a week's worth of shakedown time on it before leaving for Cordova on Saturday the 3rd.
[Re: furious70]
#3146709
05/24/23 11:39 PM
05/24/23 11:39 PM
Blusmbl
Plymouth, MI
That's cool! I wonder if it'll ever surface again. There are a couple really fast 65/66 Furies too. They've gotta be the lightest of all the C's.
Drove it tonight after buttoning the last of it up, and it feels great. Brakes work well, the 4.10's make it a little more pleasant on the freeway, and I like the truetrac.
Only minor issue is the speedo is way out in left field now and I don't understand why. According to the chart for a 30" tall tire it should've had a 38 tooth gear for the 4.30's, and a 36 tooth gear for the 4.10's. I put a 36 in it and it's easily 15% off now. What came out of it was actually a 43 tooth gear, which doesn't make sense, but the speedometer was correct with the 43 and 4.30's.
Based on the error percentage it should be back to correct with a 41 so I'll pick up one of those and toss it in.
On the home stretch now, only minor stuff to do and it's definitely a relief.
[Re: Blusmbl]
#3146777
05/25/23 11:39 AM
05/25/23 11:39 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Great news, glad it is all working smoothly.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3147314
05/28/23 10:24 PM
05/28/23 10:24 PM
Blusmbl
Plymouth, MI
Now for the not so great news, I think the pinion bearing may be smoked.
I screwed up and didn’t put enough gear oil in it for the LPW cover. It had 2 quarts and really needed a little more than 3. I have been super gentle on it during the break in period and would drive it 20-30 miles at a time then let it cool down. The oil smelled fine when I checked yesterday, and I refilled to the correct amount today, but it’s doing this weird binding on turns now only on power, has a high speed vibration, and the pinion seal is leaking. I have maybe 200 miles on it.
Going to pull the cover tomorrow to see if anything looks to be exposed to excessive heat, the wear pattern, and also check to see if there is any vertical/horizontal play in the pinion. I had worked through everything on my list the car needed by Saturday night, thought it was 100% ready, and am really kicking myself for this one.
[Re: Blusmbl]
#3147374
05/29/23 09:20 AM
05/29/23 09:20 AM
dvw
MI, usa
Going to pull the cover tomorrow to see if anything looks to be exposed to excessive heat, the wear pattern, and also check to see if there is any vertical/horizontal play in the pinion. I had worked through everything on my list the car needed by Saturday night, thought it was 100% ready, and am really kicking myself for this one. Short runs and light load using only 2 qts shouldn't have hurt anything. Doug
[Re: dvw]
#3147379
05/29/23 09:33 AM
05/29/23 09:33 AM
Bad340fish
Tulsa OK
What type of differential does it have? It might be just tight and causing the tires to drag in the corners.
[Re: Bad340fish]
#3147423
05/29/23 12:40 PM
05/29/23 12:40 PM
Blusmbl
Plymouth, MI
Thanks guys- I worry about the worst and am very doom and gloom, lol.
Doug, you're right. The rearend feels perfect with everything in the air, no slop, no runout, and no vertical/horizontal play in the pinion at all. Backlash is ok, no signs of heat either. It definitely leaked a bit from the pinion seal but was dry this morning after I wiped it off yesterday.
Clark and Cab- It has a helical style Strange s-trac in it, have driven the Eaton version in other street cars and it typically doesn't bind up like this. It's perfect launching in a straight line and is unlocked like I'd expect at light throttle. I did a bunch of tight turns in both directions in parking lots at various throttle positions and it feels fine, the diff itself is ok.
Investigating further, it only happens on off camber, tight left turns. Looking at the tire clearance, it appears to be touching the wheel lips in those maneuvers and that's what I was feeling in the car. There are fresh rubber marks on the front edge of the wheel lip and a corresponding mark on the tire. It used to not touch there but the combination of new springs, the slightly taller perch to tube distance with the dana, and the angle shims tilting the diff forward some have reduced the wheel clearance to the point where it must hit if the body rolls enough.
For the vibration, this is the first time I've had it above 75 mph with the pinion angle shims. I checked angle again, it's now at -4.3* compared to the trans. Calvert suggested anywhere from -2 to -4, I am going to change the shims from 4* to 2* to see if the vibration gets better. Beyond that I'm out of ideas. It felt OK under power but 90 mph coasting or lighter loads it vibrates and I think that is indicating driveline angles. I'll also check the trans mount.
Have one more Summit order showing up on Wednesday, including the shims, a new pinion seal, nut and washer, plus backup ignition parts. Really hope reducing the pinion angle fixes it!
[Re: Cab_Burge]
#3148052
06/01/23 07:39 PM
06/01/23 07:39 PM
Blusmbl
Plymouth, MI
Hopefully last update! Swapped the pinion angle shims to the 2* ones. The high speed vibration is better. Not gone completely but good enough, and honestly I might be oversensitive to it since I've changed so much on it. I've also never driven a car with solid spring eye bushings before, and the exhaust is also solid mounted with no isolators. lol The pinion has stopped leaking as well. Drove it to work today, have put about 300 miles on it since the axle swap. Will do one final nut and bolt check tomorrow, then it gets loaded on a U-haul trailer and towed out to Cordova on Saturday! The Sick the Magazine people asked me about the car out of the blue a few weeks ago. I gave the editor some info, and then a few days later he asked for some pics. I didn't think much of it, but this morning a short article popped up about the car. Definitely a nice way to build excitement for the event! Fury articleI won't be able to tell stories like Jeff, MoparBilly or Joel, but if the experience turns out well I'll definitely write something up when I get back. Then once all this is over I'll finally bolt the Trick Flow heads on, the exhaust, up the nitrous jetting, and get this thing in the 10's, which was the original intent of this thread.
[Re: Blusmbl]
#3148086
06/02/23 12:27 AM
06/02/23 12:27 AM
Posts: 2,255 IL
furious70
IL
I'll text you, interested in the driving path. I was hoping I might be able to go to Earlville on the 8th as the Charger is back there right now, great photo op, but very unlikely. Maybe meet up with you along the way somewhere with my Fury since it's out here now. I'm going to be in Indy with my boy fri/sat, maybe we'll see you on I-80 in the Cat
[Re: furious70]
#3148132
06/02/23 09:36 AM
06/02/23 09:36 AM
Bad340fish
Tulsa OK
Have you driven it loaded down yet? In the A body arrangement the cal tracks push the pinion angle down and that gives my car a vibration. I swap on air shocks on the road to counter this, it also makes the car ride pretty good. My A body barracuda is very nice on the road if you take out the noise and heat factor, you sir are in the lap of luxury! Have a great time!
[Re: Bad340fish]
#3148153
06/02/23 10:41 AM
06/02/23 10:41 AM
Blusmbl
Plymouth, MI
Appreciate it! Not fully loaded yet, but I always drive it with a single plastic tub worth of tools and spare parts after my fiasco getting to Roadkill Nights in 2021. I have probably 75 pounds more of stuff to put in it, plus another passenger. Will try to give that a shot today, I need to figure out what tools I'm bringing and where it's all going to fit in the trunk. Luggage will just get tossed in the backseat but I think 3 plastic tubs are going to fit in the trunk, along with the jack and nitrous bottle. The trunk is larger than most of the small trailers that people are towing!
[Re: Blusmbl]
#3148244
06/02/23 03:10 PM
06/02/23 03:10 PM
Bad340fish
Tulsa OK
Appreciate it! Not fully loaded yet, but I always drive it with a single plastic tub worth of tools and spare parts after my fiasco getting to Roadkill Nights in 2021. I have probably 75 pounds more of stuff to put in it, plus another passenger. Will try to give that a shot today, I need to figure out what tools I'm bringing and where it's all going to fit in the trunk. Luggage will just get tossed in the backseat but I think 3 plastic tubs are going to fit in the trunk, along with the jack and nitrous bottle. The trunk is larger than most of the small trailers that people are towing! Having a fastback is pretty nice, great storage horrible access. However you can't get to the stuff very well so it has to be packed in priority, you can see all of it though!
[Re: Gabby63]
#3148469
06/03/23 06:14 PM
06/03/23 06:14 PM
Posts: 2,255 IL
furious70
IL
On the road and I caught him in Chicago
[Re: Blusmbl]
#3148562
06/04/23 10:22 AM
06/04/23 10:22 AM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Good luck for the event!!
[Re: fast68plymouth]
#3148603
06/04/23 01:53 PM
06/04/23 01:53 PM
Blusmbl
Plymouth, MI
Thanks guys! And great to see you again Jeremy!
Made it through tech, and also drove it 70 miles to and from dinner yesterday. It’s ready and I’m excited for the week.
[Re: ZIPPY]
#3148894
06/05/23 02:44 PM
06/05/23 02:44 PM
Posts: 10,021 MN
JERICOGTX
MN
Safe travels, and low ET's Nick!
69 GTX
68 Road Runner
[Re: Blusmbl]
#3148897
06/05/23 02:48 PM
06/05/23 02:48 PM
Posts: 10,021 MN
JERICOGTX
MN
To Quote the great Mopar Billy, when discussing about writing a Drag Week story: " Jeff, never let the truth get in the way of a good story." LOL! He was the best at it...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3148987
06/05/23 07:31 PM
06/05/23 07:31 PM
Blusmbl
Plymouth, MI
Day 1 is in the books, ate dinner and am at the hotel. I was worried limiting rpm to 6k, the extra weight of the dana, and the gear swap from 4.30’s to 4.10’s, plus pulling the timing back to 35* for running pump gas only would slow it down on motor but it went 12.51 @ 108 in the heat of the day today (0.05 off it’s best n/a pass at Norwalk in killer weather) and it’s doing well on the road. I am never doing another one without putting tailpipes and quieter mufflers on it though, lol The vibe of these events is so cool. I expected the racers would be friendly but the towns we’ve driven through so far treat us like celebrities. It’s nuts, and I understand why this is so addicting. Will probably spray it on day 3 at GLD.
[Re: Blusmbl]
#3149016
06/05/23 11:07 PM
06/05/23 11:07 PM
Posts: 2,255 IL
furious70
IL
I had flowmaster 10's dumping before the axle at one point on my fury, was pretty abusive on long drives Glad it performed well on day 1!
[Re: furious70]
#3149063
06/06/23 08:51 AM
06/06/23 08:51 AM
GY3
Wichita
Cool! Would love to do one of these but just not in the cards right now.
[Re: HardcoreB]
#3149435
06/07/23 03:49 PM
06/07/23 03:49 PM
Blusmbl
Plymouth, MI
Really quick update: rained out yesterday, but went a new best of 12.40 @ 108.5 on motor at GLD this morning! Off to Iowa now.
[Re: Blusmbl]
#3149436
06/07/23 03:56 PM
06/07/23 03:56 PM
Posts: 10,021 MN
JERICOGTX
MN
You are going to Love Earlville Nick... All concrete, and downhill...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3149480
06/07/23 06:29 PM
06/07/23 06:29 PM
Blusmbl
Plymouth, MI
That sounds like a properly well done dragstrip!! I can’t wait.
I’ll also say the crowd at Great Lakes was just incredible. By 10am those stands were full and I felt like a celebrity driving back up the return road.
[Re: tboomer]
#3149583
06/07/23 10:18 PM
06/07/23 10:18 PM
Bad340fish
Tulsa OK
Great lakes is awesome, this picture is my Dad and I driving in wondering if all these people have jobs or not lol. Massive crowd at 8am on a Wednesday.
[Re: Blusmbl]
#3149585
06/07/23 10:22 PM
06/07/23 10:22 PM
Posts: 2,255 IL
furious70
IL
Really quick update: rained out yesterday, but went a new best of 12.40 @ 108.5 on motor at GLD this morning! Off to Iowa now. we had some pop up showers in Chicagoland, I wouldn't have guessed it rained out Byron, bummer.
