Trailduster rear quarter glass install question #2968641
09/29/21 10:39 PM
09/29/21 10:39 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Well I finally found a distributor for the rear side quarter glass on the 74 Trailduster project...but have a quick question for anyone who has done this type of glass install....do you use any type of adhesive in the channel where the glass goes, or just on the frame lip of the removable top? Don't want any leaks, and I have the early style which does not use the lockstrip on the gasket. I have the gasket installed on the window, but if it needs some adhesive in there, I will remove it. Any tips would be appreciated.
Dave in Colorado
Re: Trailduster rear quarter glass install question [Re: dssaa] #2968653
09/29/21 11:51 PM
09/29/21 11:51 PM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
Where did you find the Ramcharger/Trailduster rear side glass and what was the cost?
Re: Trailduster rear quarter glass install question [Re: dssaa] #2968695
09/30/21 09:21 AM
09/30/21 09:21 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Dave in Colorado
All you can do is install the glass the way you have started. Then if needed you can get a pump gun and pull the seal back and lay a bead between the seal and the body or the seal and the glass. If you try to use any sealer prior to lpulling the glass in place you will just make a mess and possibly still mess the sealing part. They were a pain when new so no different now.
Re: Trailduster rear quarter glass install question [Re: NITROUSN] #2968725
09/30/21 11:14 AM
09/30/21 11:14 AM
moparx Offline
moparx  Offline
a BIG 10-4 on the MESS made by putting sealer in that type of glass installation ! mad
it only took me one "try" to learn THAT lesson !
beer
Re: Trailduster rear quarter glass install question [Re: chargerbr549] #2968885
09/30/21 07:45 PM
09/30/21 07:45 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
I actually found it on Ebay...a company called Precision sells it and it was sold by Parts-Pros on Ebay. It was $200 for both seals....
Re: Trailduster rear quarter glass install question [Re: dssaa] #2969438
10/01/21 09:12 PM
10/01/21 09:12 PM
Armada MICH.
DUSTER_340 Online content
DUSTER_340  Online Content
Armada MICH.
Just like the older mopars with rubber gasket installs, use 3M Glass Bedding and Glazing compound.
https://www.3m.com/3M/en_US/p/d/b40067023/
