Re: Whats the best way to clean hazed glass? [Re: B1MAXX] #2969032
10/01/21 07:49 AM
10/01/21 07:49 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Good point with polishing, I was going to recommend just trying a paste wax to see if it offered temporary help
Re: Whats the best way to clean hazed glass? [Re: moparjim79] #2969050
10/01/21 08:37 AM
10/01/21 08:37 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
popcorn
I too would consider trying a polish or buffing compound paste. twocents
popcorn
Copper
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Whats the best way to clean hazed glass? [Re: dssaa] #2969106
10/01/21 10:30 AM
10/01/21 10:30 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Definitely strange. Can you feel the film?
Kind of looks like a hard water film or it may have been exposed to something for a long period of time that may have etched the glass.?
What's the history on the car ?
Did you just buy it ?
Sorry for all the questions but information is helpful to solve an problem
Several tips on Google
how to clean cloudy glass windows
Another that may not be listed was to soak a towel in white vinegar, place it on the window, cover the towel with something like saran wrap, seal most of it (tape?) to limit the evaporation and leave it overnight.
or try calling GORDON GLASS COMAPNY LINK
Re: Whats the best way to clean hazed glass? [Re: TJP] #2969193
10/01/21 12:26 PM
10/01/21 12:26 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Did you try what I posted above?
Her a can of Bar Keepers Friend powder.
It is safe and cleans off deposits and will fix that if it is infact something built up on it and not scratched or etched in to the glass.
In just about any store in the cleaning supply section.
Even Wal-Mart has it. Like 3 bucks,a can.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Whats the best way to clean hazed glass? [Re: dssaa] #2969361
10/01/21 05:41 PM
10/01/21 05:41 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
The dash is cooked. Is that sand laying on the wiper blade? Was this car exposed to desert heat and sand for years? Can you feel roughness like it was blasted with fine sand?
Re: Whats the best way to clean hazed glass? [Re: GomangoCuda] #2969407
10/01/21 08:26 PM
10/01/21 08:26 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
To answer some of the questions...I got the car a couple months ago and it sat outside in Colorado for quite some time. When the glass is wiped down it feels perfectly clean in the inside and outside. I tried a paste type cleaner last night but have not tried a polishing compound...that’s next. Did try barkeepers friend...I actually used paint thinner last night...which is what you see in the picture. Soon as it dried...cloudy again. I will try polishing tomorrow and post the results.
Re: Whats the best way to clean hazed glass? [Re: dssaa] #2969511
10/02/21 07:21 AM
10/02/21 07:21 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Hint when polishing, use long straight strokes not circles. Also do not focus on one area.
I've used Fast Orange successfully on glass. The mild abrasive and citric acid work wonders on hard water deposits.
Rubbing compound usually has an oil base lube that needs cleaned up afterwards. The oils might make things look better until they get washed off.
Angry white pureblood male
Re: Whats the best way to clean hazed glass? [Re: ruderunner] #2969562
10/02/21 09:50 AM
10/02/21 09:50 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
You want something with Cerium Oxide in it. (Plenty of products out there) You can use it by hand or put a pad on a drill is a lot faster. If you are not familiar with polishing glass(via power tools) read up/watch videos. You can damage the glass if not done correctly!
https://www.amazon.com/Glass-Polish...epair+Kit&qid=1633180754&sr=8-37
https://www.amazon.com/Windscreen-Polishing-Scratch-Repair-Adapter/dp/B07Q29SGY3
Re: Whats the best way to clean hazed glass? [Re: Moparite] #3000450
12/31/21 08:51 PM
12/31/21 08:51 PM
340SIX Offline
340SIX  Offline
Wondering what happened.
Re: Whats the best way to clean hazed glass? [Re: 340SIX] #3000529
01/01/22 12:53 AM
01/01/22 12:53 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The windshield in my Charger was installed in 2017 but has recently had a strange haze on the outside. I took a clay bar and window cleaner to it and it cleaned up great. It looks like it was black paint overspray. I have a 1600 sq ft shop and even though I try to spray bomb far away from the car, I guess the mist travels a ways before it dries.
Re: Whats the best way to clean hazed glass? [Re: 340SIX] #3003063
01/08/22 12:40 AM
01/08/22 12:40 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
What happened was I tried everything that was recommended and nothing seemed to work. I ended up putting the Charger away for the winter, and working on a couple trucks I have that need some attention.
I think I will just replace the front glass, tint the rest, and call it a day. This car is intended to be a resto mod, and was going to get tinted out anyways...However, when the old windshield is removed, I am still going to try
and figure this thing out....
Re: Whats the best way to clean hazed glass? [Re: dssaa] #3051841
06/19/22 10:13 PM
06/19/22 10:13 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
An update to an older post.....Took a polisher on low speed, covered the pad with Fast Orange hand cleaner and worked it for a bit. It worked and my glass looks amazing now. I didn't have to replace any of it. I know someone suggested it...it just took me this long to pull the car back down to the workshop and get started on it again....
Re: Whats the best way to clean hazed glass? [Re: GomangoCuda] #3051928
06/20/22 09:56 AM
06/20/22 09:56 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
That's what I'm guessing, it's been 'sandblasted' with fine grit. My '95 Neon after decades in ND wind-blown grit had a windshield that looked very similar to that.
Re: Whats the best way to clean hazed glass? [Re: dssaa] #3051948
06/20/22 11:16 AM
06/20/22 11:16 AM
moparx Offline
moparx  Offline
thanks for the update. up
glad the polishing worked out.
beer
Re: Whats the best way to clean hazed glass? [Re: 6PakBee] #3052001
06/20/22 02:06 PM
06/20/22 02:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer And thanks for posting the solution that is a common one wink
Re: Whats the best way to clean hazed glass? [Re: TJP] #3052068
06/20/22 06:23 PM
06/20/22 06:23 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Yep, dash is cooked, and its just dirt, not sand. Car sat outdoors in Colorado uncovered for years. Its cleaned up now, but a new dash is in my future for sure...
