Good to have you back.
I moved in the fall of 2017, bought a 1993 Daytona chassis car (roller) and started a new build this year.
Engine Summary:
572 CID (4.500β bore x 4.500β stroke) Approximately 14.7 CR (final CR will be after measuring piston to deck during assembly)
B1 original Heads, CNC Ported 429/326 cfm at 0.800β lift, milled to 60cc chambers, 332cc intake ports, 125cc exhaust ports
T&D paired rocker arms 1.7 ratio, part number 8013, 5/8β shafts
B1 cast single 4-barrel intake manifold with RB spacers.
ICON Elite forged Pistons # IC433CAKTS.std with rings & 0.185β wall Trend wrist pins, 1.355 Compression height, -6.5cc net relief
Rings 0.043" top SS with CrN, 1/16" Napier 2nd, 3/16" oil ring
Cometic 5-layer MLS head gaskets 4.530β dia x 0.056β thick
Cam duration 280/294 at 0.050β, 0.800β lift, 113 LSA
7/16 dia Comp Cams 8649 pushrods, 9.800β long, 0.165β wall, ball-ball ends, pushrod oiling
2-1/4β primary headers with 4β collectors
Here is my plan for posting progress:
572 B1 org Part 1-Buying Parts.................... Started posting
Link to Part 1572 B1 org Part 2-Component Observations.. Started posting
572 B1 org Part 3-Machine Shop Report....... Started posting
572 B1 org Part 4-Mock-ups ...................... Started posting
572 B1 org Part 5-Build Notes ................... Started posting
572 B1 org Part 6-Dyno Results
572 B1 org Part 7-Track Testing
