Power brake options??? #2968337
09/29/21 08:23 AM
09/29/21 08:23 AM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
So….I’m in the middle of building a 76 SWB big block truck and I want to install the power brake system before I put the dash back in…not so fast there big boy…vacuum boosters are currently made out of unobtainium. Looks like the current best option is to send this one in for rebuild….is there another option, aftermarket maybe, like wilwood or??? Thanks…
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Power brake options??? [Re: RapidusMaximus] #2968374
09/29/21 09:59 AM
09/29/21 09:59 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Hydroboost conversion is what I had in mind when the time came.
https://www.powerbrakeservice.net/new-1967-1988-dodge-truck-d100-w100-hydroboost-brake-booster.html
Pretty sure GJ has done a similar conversion with factory parts and probably cheaper then the $450 pbs wants?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Power brake options??? [Re: 3hundred] #2968399
09/29/21 11:40 AM
09/29/21 11:40 AM
Weatherford, Texas
Weatherford, Texas
Ouch, thanks for the info, but that’s 840 dollars after you add the correct m/c and required hoses… eek
1968 Plymouth GTX
Re: Power brake options??? [Re: RapidusMaximus] #2968411
09/29/21 11:59 AM
09/29/21 11:59 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I know, cost rarely deters me. That's why I suggested asking Guitar Jones about his conversion.
'69 300 Convertible
'16 300 S Hemi
Re: Power brake options??? [Re: RapidusMaximus] #2968622
09/29/21 09:29 PM
09/29/21 09:29 PM
Alberta
440_Offroader Offline
Alberta
I put a hydroboost off a 2002 2500 Cummins, onto my 79' project with a 440. The two holes on the right fit in the factory booster bolt holes. The other 2 on the left I had to drill through the firewall. The brake pedal hooked right up. I did have to make a thin plate that fit between the hydroboost and the firewall. It pretty much covered up the 2 unused bolt holes from the original booster. You do need adapters in the hydroboost master cylinder, to go from metric to SAE.
I haven't got it all hooked up yet though. Still need to get hoses made, but I bought the hydroboost for $20, and $13 for the fitting adapters. I can't imagine the hoses being too bad for price.
Re: Power brake options??? [Re: 440_Offroader] #2968627
09/29/21 09:38 PM
09/29/21 09:38 PM
Alberta
Alberta
On another note, I did put a 3/4 ton small diameter, double diaphragm booster on a Ramcharger years ago. Not sure if those are just as hard to find? I guess you might need one of them anyway, if your installing a RB engine, just for clearance to the valve cover. That is, if you don't go the hydroboost route.
Re: Power brake options??? [Re: 440_Offroader] #2968699
09/30/21 09:49 AM
09/30/21 09:49 AM
RWG75
RWG75
Ya absolutely need the small diameter booster to clear 440 valve covers if you ever expect to remove them. Might be able to shoe horn it past the larger one but I doubt it and will be almost zero clearance. Swapping the 3/4 ton dual diaphragm has been the ticket for years. Ya might also look at 70s C-bodies as they ran dual diaphragms too. They should all be 4 bolt masters and not sure about the firewall bolt pattern. As far as getting one remanned, last I knew the only place for that was carid and quality was suspect at best.
Re: Power brake options??? [Re: 3hundred] #2968891
09/30/21 08:08 PM
09/30/21 08:08 PM
Guitar Jones Offline
Like 440 offroader I used a HB off a 2000 Cummins truck, but since mine is a diesel I couldn't use it as is because it's too long and hit the intake elbow. I made a flat plate to mount the unit to the firewall and shortened the pushrod. I used hoses and master cylinder from the 2000 truck as well as the power steering pump to get the two return nipples. You can just tee off the single though. Now I guess the ticket is to get the entire assembly off 2500 GM van, (a "G" I think) that already has the flat plate and is supposed to bolt directly to the firewall but the pushrod eye is different. This unit clocks the HB and master cylinder differently and probably needs custom hoses. Both will need M/C to proportioning valve lines made.
You can buy a reseal kit for the HB off ebay, they all take the same kit. You need a special tool to remove the pushrod though if you plan to change that. The big nut that holds the HB unit to the bracket is 1 7/8" I believe, but don't quote me on that.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Power brake options??? [Re: Guitar Jones] #2968914
09/30/21 09:00 PM
09/30/21 09:00 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Here is the clearance with a 440 and the big booster. Not much space there.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Power brake options??? [Re: moparmarks] #2969517
10/02/21 07:34 AM
10/02/21 07:34 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Quick correction to GJ about the return line, DO NOT T them together, both need to run to the reservoir.
A single line can't flow enough and leads to funky problems with things like self activation of the brakes.
Also, 2 bolt dual boosters are available, 85 W250 is one application. Might depend on gvw.
Angry white pureblood male
Re: Power brake options??? [Re: ruderunner] #2969524
10/02/21 08:18 AM
10/02/21 08:18 AM
Many of the kits use this method as does the one posted earlier in the thread. I didn't do it on mine though. Plenty of guys on the 1st gen forums have done the same and I haven't seen any reported problems so it's news to me. shruggy
Re: Power brake options??? [Re: Guitar Jones] #2970005
10/03/21 03:01 PM
10/03/21 03:01 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
On an IH forum I'm on, people do quite a few Hydroboost swaps. Some have had problems with T fittings.
Think about this, most, maybe all, OEM applications have separate returns requiring tooling for different reservoirs. If a T was adequate they would do that instead.
Personally I'm not a fan of Hydroboost. Don't care for the pedal feel and Ford systems are awful. You lose power steering assist if you're on the brakes hard.
Re: Power brake options??? [Re: ruderunner] #2970110
10/03/21 09:48 PM
10/03/21 09:48 PM
Oh I get it and that is why I used a hydro power steering pump on mine, I just never heard of problems with the T.
I love my hydroboost, the brakes have never worked so well on my truck. I may do the crew cab in the future too.
Re: Power brake options??? [Re: Guitar Jones] #2970347
10/04/21 12:59 PM
10/04/21 12:59 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Booster Dewey has an excellent reputation.
https://boosterdeweyexchange.com/
Kevin
Re: Power brake options??? [Re: Twostick] #2970724
10/05/21 05:00 AM
10/05/21 05:00 AM
Weatherford, Texas
Weatherford, Texas
Kevin
Thanks, I’ll probably give these guys a call today up
1968 Plymouth GTX
Re: Power brake options??? [Re: RapidusMaximus] #2970936
10/05/21 01:48 PM
10/05/21 01:48 PM
ILLINOIS
V
volaredon Online content
volaredon  Online Content
V
ILLINOIS
Yeah I looked into him but seems crazy high. Have another place closer I'm waiting for a response quote from.
