Re: Milodon 31580 Road Race Pan
[Re: SomeCarGuy]
#2978043
10/24/21 10:47 PM
10/24/21 10:47 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
The Milodon 31581 (external p/up version) in my '66 Charger slightly interfered with the original K frame. Not a big deal but the engine had to come out one more time. I eventually replaced the stock K with a QA1 because it was slightly bent.
[Re: Jeremiah]
#2978334
10/25/21 06:46 PM
10/25/21 06:46 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
I'm not sure on if or how to even modify the pickup tube. I'm sure it will most likely crack the tubing or break a weld by trying to bend it
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
[Re: Moparteacher]
#2979016
10/27/21 07:27 PM
10/27/21 07:27 PM
73cuda340
clarks summit pa
Thanks, I may just have to try modifying it myself. I called milodon and they're trying to blame it on the block and they said that the location of the pickup port is not in the stock location and that it has a custom angle to it. If this was the case, I don't see how the stock pickup worked .
[Re: 73cuda340]
#2984056
11/11/21 10:08 AM
11/11/21 10:08 AM
73cuda340
clarks summit pa
I got off of the phone with milodon and according to them, this setup won't fit my world aluminum block. If I want to use this pan, they said that I have to go with an external oil system. The engine builder says that this isn't true and that he helped design this block and the oil pickup tube adapter is in the factory location.
[Re: 73cuda340]
#2984067
11/11/21 11:19 AM
11/11/21 11:19 AM
Posts: 10,229 Someplace you aren't
SomeCarGuy
That sounds pretty hokey. You had a stock pickup before?
Maybe a machine shop could tweak the milodon one a bit
I want my fair share
[Re: SomeCarGuy]
#2984133
11/11/21 02:15 PM
11/11/21 02:15 PM
73cuda340
clarks summit pa
Yes, I originally had a stock pickup that fit just fine. Not sure which guy to believe at this point, but I now have about $700 between the pan , pickup tube and windage tray that won't work. I've read reviews where a few people said they had the same fitment issues with the pickup tube as well. I'm not really sure if I want to go the external route, it just seems like it's asking for more problems having to change even more parts.
