Milodon 31580 Road Race Pan
#2967392
09/25/21 09:02 PM
09/25/21 09:02 PM
Posts: 1,169 clarks summit pa
73cuda340
clarks summit pa
Does anyone know the measurements of the Milodon 31580 Road Race Pan for a hemi at the widest part of the sump? I'm trying to see if this will fit in my hemi cuda with 2 1/4" tti headers and stock steering and suspension. According to tti's website, it will clear the headers, but they also said that they clear power steering boxes and I had to clearance a tiny spot on the steering box to get them to fit.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Milodon 31580 Road Race Pan
[Re: 73cuda340]
#2967407
09/25/21 09:43 PM
09/25/21 09:43 PM
Posts: 10,198 Someplace you aren't
SomeCarGuy
That’s an excellent pan, my absolute favorite. Wish I could help you. Sold my 69 rr with one years ago. I remember it cleared well with 1 7/8 hookers and stock steering. I was really impressed with how it tucked up, had oil temp port, all those baffles. Just a nice piece.
I want my fair share
[Re: 6bblgt]
#2967762
09/27/21 10:42 AM
09/27/21 10:42 AM
Posts: 3,131 tennessee,usa
mattsmopars
tennessee,usa
I have the milodon road race pan on my 1966 coronet. Its factory hemi K frame and mounts, all the steering in factory parts with manual box, and I am running TTI 2 1/8 headers I have no trouble with the pan. I like it because it give you ability to have large oil volume and does not cause issues with ground clearance. I have a build thread on here of my 66 coronet with some pictures you can check out if need be. Funny thing I picked up an old nascar pan at Carlisle this year, and it is very similar to the milodon pan. Matt
[Re: mattsmopars]
#2967927
09/27/21 06:39 PM
09/27/21 06:39 PM
73cuda340
clarks summit pa
Thanks for the pictures and replies. I just ordered one from Jegs, it'll take about two weeks until it arrives though.
[Re: 73cuda340]
#2974135
10/13/21 09:17 PM
10/13/21 09:17 PM
73cuda340
clarks summit pa
I see that milodon lists their part number 32006 windage tray for this oil pan. Will the stock tray not work? Also, is there an issue with not installing the bracket for the pickup tube underneath the main cap bolt? I'm very skeptical on loosening the bolt and installing the bracket. I'll have just under a 1/4" less contact on the main cap bolt with the bracket underneath.
[Re: 73cuda340]
#2974148
10/13/21 10:00 PM
10/13/21 10:00 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
stock tray will not fit pickup tube. No bracket on my tube ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2976386
10/20/21 07:46 AM
10/20/21 07:46 AM
73cuda340
clarks summit pa
Has anyone ever installed this pan with the engine still in the car? I don't know if my issue is because I have studs for my oil pan, but I can't even get the windage tray in place and the oil pan doesn't want to go in place either. I tried rotating the pickup tube to get the windage tray in place, but it still won't go. Not sure if there are any other tricks to make this work. Thanks
[Re: NITROUSN]
#2976398
10/20/21 08:34 AM
10/20/21 08:34 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
I had to remove the studs from mine to get the pan on/off in the car. The ones across the front and the first two back on each side had to come out. I left the rest of them in.
[Re: 73cuda340]
#2976450
10/20/21 12:05 PM
10/20/21 12:05 PM
Posts: 270 Mountain View, CA
68rrunner
Mountain View, CA
Has anyone ever installed this pan with the engine still in the car? I don't know if my issue is because I have studs for my oil pan, but I can't even get the windage tray in place and the oil pan doesn't want to go in place either. I tried rotating the pickup tube to get the windage tray in place, but it still won't go. Not sure if there are any other tricks to make this work. Thanks I cheated and solved the problem by going with an external pickup version of the pan. I can easily get the pan off and on now by just removing the centerlink.
[Re: 73cuda340]
#2976616
10/20/21 09:04 PM
10/20/21 09:04 PM
SomeCarGuy
Has anyone ever installed this pan with the engine still in the car? I don't know if my issue is because I have studs for my oil pan, but I can't even get the windage tray in place and the oil pan doesn't want to go in place either. I tried rotating the pickup tube to get the windage tray in place, but it still won't go. Not sure if there are any other tricks to make this work. Thanks I did it. No studs though. Was easy job. You might use a hoist. Can’t remember exactly what I did, just it went in without fuss.
[Re: 73cuda340]
#2976792
10/21/21 12:06 PM
10/21/21 12:06 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Here are three other tips learned the hard way.
The rear seal fixture uses two shorter bolts or they can bottom out and not clamp the gasket well.
Bottoming out the block pan bolts can cause them to crack and pop open the pockets into the crankcase.
The pan rail stiffening plates really help keep the pan bolts from dimpling the pan's sheet metal and spread additional clamping force along the pan rails.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2977379
10/22/21 09:19 PM
10/22/21 09:19 PM
73cuda340
clarks summit pa
It looks like I may be able to get the pan in with the studs still installed. I found the problem is that the pickup tube is actually hitting the side of the oil pan and stopping it from lining up with the studs. It's actually in line with the oil pan rail on the engine block. I double checked and it's the correct matching pickup for the oil pan. Did anybody have to modify their tube or change anything with the oil pump?
[Re: 73cuda340]
#2977384
10/22/21 09:25 PM
10/22/21 09:25 PM
73cuda340
clarks summit pa
The bracket that bolts to the main cap has about a 1/2" to 3/4" gap between the pickup and bracket too.
[Re: 73cuda340]
#2977387
10/22/21 09:31 PM
10/22/21 09:31 PM
SomeCarGuy
I looked up this pan after reading this thread just to see the price these days. Lots of guys saying the pickup is all wrong and requires reworking. I don’t remember anything being wrong with mine. That was around 2009.
