cuda cowl black what paint is correct?
#2966683
09/23/21 01:08 PM
09/23/21 01:08 PM
Posts: 5,651 South Dakota
hotairballoonpilot
South Dakota
Top of the cowl suppose to be black on cuda's but has anyone figured out what is correct for the black color itself? Semi gloss level,egg shell level? Certain brand of paint better than others? I did google it but only so far found documents of where and what up to build dates was done but not seen anything for the actual black itself that was used.
thanks
Contact Me about AMD Prices
Re: cuda cowl black what paint is correct?
[Re: RP's R/T's]
#2966746
09/23/21 04:58 PM
09/23/21 04:58 PM
hotairballoonpilot
South Dakota
Thanks. if I thinking I would use that black but wanted to see for sure if that was what was felt was correct.
[Re: hotairballoonpilot]
#2966751
09/23/21 05:27 PM
09/23/21 05:27 PM
Posts: 20,644 So Near, Yet So Far
topside
So Near, Yet So Far
All the blacked out areas (rad supports, etc) seemed to me that it was the same paint, essentially a low-gloss black. I personally prefer a semi-gloss as it lasts longer - well over 30 years so far - and mimics the new appearance from back then. Some flat blacks look almost dark grey, and/or don't age well. It should not have gloss.
[Re: topside]
#2966772
09/23/21 06:40 PM
09/23/21 06:40 PM
Posts: 21,808 Kirkland, Washington
Pacnorthcuda
All the blacked out areas (rad supports, etc) seemed to me that it was the same paint, essentially a low-gloss black. I personally prefer a semi-gloss as it lasts longer - well over 30 years so far - and mimics the new appearance from back then. Some flat blacks look almost dark grey, and/or don't age well. It should not have gloss. Your post contradicts itself. “Not have gloss” would mean flat. Any other sheen, satin, semi gloss…etc, has a level of gloss.
[Re: topside]
#2966862
09/23/21 10:12 PM
09/23/21 10:12 PM
Pacnorthcuda
What I mean is, "not shiny". There's a definite difference: semi & flat won't reflect images, but gloss will, if that helps explain it. Corey knows what I mean. Well…there certainly is a definite difference!
[Re: topside]
#2967041
09/24/21 01:47 PM
09/24/21 01:47 PM
hotairballoonpilot
South Dakota
What I mean is, "not shiny". There's a definite difference: semi & flat won't reflect images, but gloss will, if that helps explain it. Corey knows what I mean. I know what you mean. Thanks guys corey
