Re: Installing my camshaft 2* advanced
[Re: Copper Dart]
#2967153
09/24/21 09:23 PM
09/24/21 09:23 PM
Posts: 427 saint paul mn.
johnzgarage
saint paul mn.
Ya, I think i get what your trying to do by lowering the total rpm on the torque/power curve. Is this just driven on the street ? or is it raced ? Correct, just street driven and I just wanted the power/torque a bit lower in the rpm range. Swapping our and breaking in another flat tappet cam that's better suited for my application/wants just doesn't seem worth the effort, risk or cost. This all came about because I have the engine apart to replace some gaskets and freshen up the paint and detail. Uncovering the timing chain and knowing that the crank gear has the advance/retard keyways started the ideas in my little head so.... Copper My guess is you want seat of the pants power, but yet want to drive down the highway at a lower rpm.....right ?
[Re: AndyF]
#2967169
09/24/21 10:51 PM
09/24/21 10:51 PM
Posts: 610 Boise
Moparteacher
Boise
You should go ahead and change it just so you go thru the process. You'll never learn anything by listening to a bunch of opinions on the internet, you actually have to run the test yourself and see what happens. In your case you'll never notice the difference but you shouldn't take my word for it, do the test and see for yourself and then you'll know. This is the best advise yet. You really don't know what difference if any advancing that camshaft 2 degrees will make, and you will never find out if you don't try. What's a worst thing that could happen? A minor change in the torque curve and shifting at a few hundred rpms earlier? My opinion (which isn't worth the ink used to create this post) is it won't make a noticeable difference, and if it does, it'll be favorable. It might result in a little more torque in the mid range, make the engine a tenee wenee bit snappier with no noticeable loss up top. Just do it and be glad you did it because YOU wanted to do it. No worries. Best of luck.
[Re: 67_Satellite]
#2967182
09/24/21 11:56 PM
09/24/21 11:56 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Don't be surprised if it hits a "wall" about 5000-5500 r.p.m. Been watching a series of you tube videos about a clown building a 440 for "Mopar MaMa" which inexplicably wouldn't rev past 5k. Many missteps along their way, but I don't know if they ever figured out they pissed in their wheaties with the fast comp cams hyd, cam and 1.6 rockers, I know just who you are talking about they dyno the engine again after changes got 470 hp out of it. be ok for a street car
[Re: Copper Dart]
#2967188
09/25/21 12:43 AM
09/25/21 12:43 AM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
Based on your comments I think you may need to change the cam entirely to achieve what you're after. (understand your trepidation of breaking in another cam)
Still, while it's apart, I think the best thing you could do is say, this is my goal/what I would like to achieve. Then, change what's necessary to achieve that.
Advancing your existing cam will not likely align with the ideal answer to the above question.
[Re: INTMD8]
#2967216
09/25/21 07:01 AM
09/25/21 07:01 AM
Posts: 20,671 in a cattle trailer down by th...
Guitar Jones
Crane cams literature from years ago stated that moving the cam 2° would change the power band 50 rpm. Advancing the cam would peak it 50 rpm lower and retarding it 2° would raise the peak power 50 rpm. They probably knew what they were talking about, so unless you need to make more power lower or later for your combination or you are looking to operate the engine in a specific rpm range you will never notice the difference.
[Re: Guitar Jones]
#2967219
09/25/21 07:37 AM
09/25/21 07:37 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Agree with most of the viewpoints above especially you'll never learn unless you try ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) life lessons! ![punkrocka punkrocka](/ubbthreads/images/graemlins/custom/punkrocka.gif) I have already installed it as built and i'm going to leave it alone. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif) Pump gas concerns and actual rpm shift/gains made me question the cliche' "if it aint broke, don.t fix it" This has served as a lesson on how to better choose a cam in the future. Thanks for all of the ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#2967229
09/25/21 09:18 AM
09/25/21 09:18 AM
Posts: 3,916 usa
lewtot184
usa
so what would you learn if the cam was installed an additional 2 degrees advanced if it was never ran at the ground in 4 degrees advance? ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) the old rule of thumb was if you don't know where to install a camshaft then put it in with the overlap split as a starting point. i think this rule is still a good one.
[Re: bobby66]
#2967418
09/25/21 10:57 PM
09/25/21 10:57 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
Back in the 70's I just lined up the marks and went on my way. Now I know what the smart kids were doing. I've seen many gear sets have the dot on the cam gear not directly over the point of the gear tooth, more towards the middle ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) If I align the dot to the right side facing the gear it would be one tooth off which is right at 12 degrees on the 3 bolt BB gear sets with the 3 keyways on the crank gear ![puke puke](/ubbthreads/images/graemlins/custom/puke.gif) I've seen many BB Mopar builds that wouldn't fall out of a tree with the cam retarded 12 degrees ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) I learned that lesson, about NOT assuming lining up the dots was the best way to install cams the hard way, it was on the first solid roller cam I built for a customer ![puke puke](/ubbthreads/images/graemlins/custom/puke.gif) Turned out the cam keyway was cut into it 10 degrees off ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) I degree every cam now ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif) , why shouldn't you ![work work](/ubbthreads/images/graemlins/custom/work.gif) DO IT ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: Guitar Jones]
#2967444
09/26/21 07:19 AM
09/26/21 07:19 AM
Posts: 6,324 nowhere
Sniper
nowhere
Crane cams literature from years ago stated that moving the cam 2° would change the power band 50 rpm. Advancing the cam would peak it 50 rpm lower and retarding it 2° would raise the peak power 50 rpm. They probably knew what they were talking about, so unless you need to make more power lower or later for your combination or you are looking to operate the engine in a specific rpm range you will never notice the difference. And that test was specific to that engine with that cam. You really cannot extrapolate much from that test. Engine Masters did a similar test.
[Re: Cab_Burge]
#2967495
09/26/21 12:00 PM
09/26/21 12:00 PM
Posts: 725 Southern Alberta
Uberpube
Southern Alberta
Back in the 70's I just lined up the marks and went on my way. Now I know what the smart kids were doing. I've seen many gear sets have the dot on the cam gear not directly over the point of the gear tooth, more towards the middle ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) If I align the dot to the right side facing the gear it would be one tooth off which is right at 12 degrees on the 3 bolt BB gear sets with the 3 keyways on the crank gear ![puke puke](/ubbthreads/images/graemlins/custom/puke.gif) I've seen many BB Mopar builds that wouldn't fall out of a tree with the cam retarded 12 degrees ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) I learned that lesson, about NOT assuming lining up the dots was the best way to install cams the hard way, it was on the first solid roller cam I built for a customer ![puke puke](/ubbthreads/images/graemlins/custom/puke.gif) Turned out the cam keyway was cut into it 10 degrees off ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) I degree every cam now ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif) , why shouldn't you ![work work](/ubbthreads/images/graemlins/custom/work.gif) DO IT Thats exactly how my comp cams timing set worked out on my 505 project.
[Re: fast68plymouth]
#2967804
09/27/21 12:42 PM
09/27/21 12:42 PM
Posts: 16,932 NC
440Jim
NC
Honestly, the chances of a fast rate hyd cam pulling strong up to 6500 in a BB is pretty slim. I agree.... Good point Dwayne. You are the voice of experience.
