Re: Any plumbers here? [Re: BDW] #2967110
09/24/21 06:36 PM
09/24/21 06:36 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I'll just add that if you decide to replace the unit, you may want to check if any codes have changed since the prior installation was performed. It most cases, the changes are much easier to perform during the replacement as compared to once the unit is installed or further down the road if an inspection (e.g. home sale) reveals a deficiency.
Re: Any plumbers here? [Re: cruzin] #2967254
09/25/21 10:59 AM
09/25/21 10:59 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Here is what I used to retrofit my two homes. Simple and easy to install.
https://www.rinnai.us/residential/tankless-water-heaters
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
