Fel Pro MS90029. Cut the gasket down, to make individual gaskets for the manifold ports. Torque to factory spec, run for a couple hundred miles and then recheck. Then good to go.
I've never had luck with using header gaskets with manifolds: the port opening in the gasket is too large, thereby minimizing the amount of actual gasket sealing the manifold surface.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
