Exhaust gasket for stealth heads with manifolds #2966222
09/22/21 05:58 AM
09/22/21 05:58 AM
central new york
pettyblue440 Offline OP
central new york
Can someone recommend a gasket to use on a 383 with stealth heads and hp manifolds? Thanks jon
Re: Exhaust gasket for stealth heads with manifolds [Re: pettyblue440] #2966244
09/22/21 08:50 AM
09/22/21 08:50 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Manifolds generally require no gasket, I usually install manifolds on a freshly WET painted engine, or for clean dry heads, put a coat of hi temp paint on the exhaust mating flanges install/torque let dry.... the paint acts as a gasket....
Re: Exhaust gasket for stealth heads with manifolds [Re: DAYCLONA] #2966272
09/22/21 10:08 AM
09/22/21 10:08 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
MR Gasket ultras Mine have been in like 15 years with headers Used them on the kids 413 same thing.Cheap and work.Rocky
Chrysler Firepower
Re: Exhaust gasket for stealth heads with manifolds [Re: therocks] #2966280
09/22/21 10:23 AM
09/22/21 10:23 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
A trip through the milling machine with the manifolds should guarantee no gaskets required.
Kevin
Re: Exhaust gasket for stealth heads with manifolds [Re: therocks] #2966281
09/22/21 10:29 AM
09/22/21 10:29 AM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
Fel Pro MS90029. Cut the gasket down, to make individual gaskets for the manifold ports. Torque to factory spec, run for a couple hundred miles and then recheck. Then good to go.
I've never had luck with using header gaskets with manifolds: the port opening in the gasket is too large, thereby minimizing the amount of actual gasket sealing the manifold surface.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Exhaust gasket for stealth heads with manifolds [Re: pettyblue440] #2966291
09/22/21 10:59 AM
09/22/21 10:59 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Fel-Pro 1414 work good for manifolds
The only Carbs I care about are under the hood!
Re: Exhaust gasket for stealth heads with manifolds [Re: pettyblue440] #2966451
09/22/21 07:10 PM
09/22/21 07:10 PM
Boise
Moparteacher Offline
Boise
Check the manifolds for flatness with a straight edge. If warped, have them milled. Use a very thin layer if high temp (red) rtv. No gasket. Wipe off excess before it cures. Do not get rtv on skin.
Re: Exhaust gasket for stealth heads with manifolds [Re: Moparteacher] #2966457
09/22/21 07:44 PM
09/22/21 07:44 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
High temp is fine for cast iron on cast iron. That's what I have on my 68 with no problems. With dissimilar metals the expansion rate is different and you should use a gasket.
Re: Exhaust gasket for stealth heads with manifolds [Re: EWJ] #2966742
09/23/21 04:46 PM
09/23/21 04:46 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted by EWJ
Fel Pro MS90029.
This. You can get them for like $10.
Remflex if you think you have more than normal sealing challenges.
