Re: Installing an aftermarket valve body questions
[Re: 6PAX]
#2966014
09/21/21 01:20 PM
09/21/21 01:20 PM
Posts: 25,794 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The spring is for the rear servo, it's stiffer than original and makes the rear band release quicker on the manual 1-2 upshift; not necessary but advisable. Billet rear servos with improved spring retainers are available from sellers here.
[Re: moparx]
#2966068
09/21/21 03:17 PM
09/21/21 03:17 PM
John_Kunkel
Rio Linda, CA
Different spring, the one they tell you to remove is the accumulator spring which makes absolutely no sense....an old myth keeps getting repeated.
[Re: moparx]
#2966335
09/22/21 01:16 PM
09/22/21 01:16 PM
John_Kunkel
Rio Linda, CA
Inserting a rod in the accumulator eliminates its function which is to cushion the 1-2 shift and the application of the rear clutch.
