400 sonic test #2965778
09/20/21 02:49 PM
09/20/21 02:49 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
hi
whats the best b eng 400 block to use? what are good sonic test numbers and where do you test? i was told once on thrust side??
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 400 sonic test [Re: 440lebaron] #2965780
09/20/21 02:51 PM
09/20/21 02:51 PM
AndyF Offline
AndyF  Offline
The best one is the one that looks the best and has the best numbers. Look at casting quality, machining quality, and sonic numbers.
Re: 400 sonic test [Re: 440lebaron] #2965801
09/20/21 04:17 PM
09/20/21 04:17 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
the early '72/''73 "cold weather" blocks were supposedly the best of the 400's. Part number ends in 230 I believe. Had some thicker side ribs. Whether it's really stronger, who knows.
Re: 400 sonic test [Re: 80fbody] #2965813
09/20/21 05:01 PM
09/20/21 05:01 PM
AndyF Offline
AndyF  Offline
The early 230 blocks look really nice and have big beefy mains but the cylinder wall are not any thicker than other casting numbers. I spent a bunch of time finding an early 230 block years ago because I had heard that it was "the one". When we sonic checked that 230 block we found out it was junk. All of my money and my dreams of a killer block disappeared in a poof.
Re: 400 sonic test [Re: AndyF] #2965876
09/20/21 09:41 PM
09/20/21 09:41 PM
I bought one of AndyF 230 cold weather block and sonic tested it, it was no better in the cylinder walls than any other 400 block I have tested whiney
OP, I shoot for a minimum of .160 after boring on the major and minor cylinder wall thrust surfaces, the block side and the cam side scope
That has work so far up to 800 HP on race gas and a little more on E85, I do replace the main caps also do to a friend breaking one in a 451 C.I. 400 block S/G motor years ago making close to 750 HP and using old race gas in his Super Gas car tsk
I have bought three race blocks, high nickel Koleno, KB aluminum and the last one is a Bulldog cast grey iron. These will be used for a Hi Po build, north of 900 HP N/A luck
I have cracked the main webbing in three RB blocks before switching too the 400 blocks to make sure I don't run over a crankshaft twocents work
Re: 400 sonic test [Re: Cab_Burge] #2965898
09/21/21 12:37 AM
09/21/21 12:37 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I was taught to measure bores at every 90 degrees, which also tells you the core shift.
The best blocks would be .200 minimum wall at finished size, but lots of guys run less.
Another thing I've been told is the dash # after the casting # is how many repairs/revisions on the mold.
Lower dash # is most likely to be most accurate, per that guru.
Re: 400 sonic test [Re: 80fbody] #2965917
09/21/21 08:10 AM
09/21/21 08:10 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have the 71 230 block and it had a couple thin cylinders. #1 and #8 i think. .120 on the thrust of #1 before it got bored. Best Machine told me to fill it, so it got a tall fill with Hard Block and aluminum main caps added. Been running this as a 511 for 4 seasons now. Mostly street use, but has been down the track a couple dozen times now. I believe its under 700hp at this point and no issues with it yet. I do keep a spare 77 400 block just in case.
Re: 400 sonic test [Re: 440lebaron] #2965921
09/21/21 08:26 AM
09/21/21 08:26 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Take a look at this recent post of mine (W2 stroker build - cylinder wall thickness check please), keep in mind that was a 360 block.
Cab_Burge provided his response there as well, it looks like about 0.200" is a good number to shoot for. Consistency in the thickness seems equally important.
Re: 400 sonic test [Re: Diplomat360] #2965951
09/21/21 10:29 AM
09/21/21 10:29 AM
westerly, ri. usa
westerly, ri. usa
thanks for the info, going to run stock eliminator next year, need 400-500 hp 8 to 1 compression, found 3 blocks will check numbers
Re: 400 sonic test [Re: 440lebaron] #2966053
09/21/21 02:43 PM
09/21/21 02:43 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
If you have a "bad" or "thin" block, I'll buy it from you. I'll pay shipping and better than scrap value and it'll live again. I work in a machine shop, and the Rottler can run while we go to lunch. Sleeves are stronger than the original up S/F....Ken M
Re: 400 sonic test [Re: EchoSixMike] #2966148
09/21/21 08:34 PM
09/21/21 08:34 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Buying any unchecked block of any year is a gamble. I'm relieved that both the '77 400, and the '75 440 blocks checked out good. Both are standard bore with enough room to go .030 over, or more. The sides of the cylinder walls on both blocks are the thinnest areas. These were cleaned magged and thickness checked at Tim Wilkerson's shop.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: 400 sonic test [Re: 440lebaron] #2966160
09/21/21 09:17 PM
09/21/21 09:17 PM
AndyF Offline
AndyF  Offline
If you want to find a good block start with a lot of blocks and check them all. This is a picture I took in my old shop when I was buying blocks for a race program. A lot of blocks turn out to be junk after they are tanked, magnafluxed and sonic checked. Start with 10 blocks and you might end up with one good race block and 3 or 4 okay street blocks.
