listen to this cam lope! wow! #2965468
09/19/21 12:00 PM
09/19/21 12:00 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
Re: listen to this cam lope! wow! [Re: ph23vo] #2965469
09/19/21 12:13 PM
09/19/21 12:13 PM
Kirkland, Washington
Pacnorthcuda Offline
I like the two-handed tach!
Re: listen to this cam lope! wow! [Re: Pacnorthcuda] #2965481
09/19/21 01:30 PM
09/19/21 01:30 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Very impressive!
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: listen to this cam lope! wow! [Re: Pacnorthcuda] #2965502
09/19/21 04:30 PM
09/19/21 04:30 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
That’s a typical aviation tach used with most all old reciprocating / piston aviation engines.
Re: listen to this cam lope! wow! [Re: ph23vo] #2965596
09/19/21 10:22 PM
09/19/21 10:22 PM
SoCal
Frank Cannon Offline
SoCal
ww.youtube.com/watch?v=st7KG3eXZiw&t=99s
CALIFORNIA-SUNDAY-10:04 A.M.
Re: listen to this cam lope! wow! [Re: ph23vo] #2965636
09/20/21 05:47 AM
09/20/21 05:47 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Stuff that baby into a hydroplane and lets go....
What did they put Merlin's in besides Spitfires?
Re: listen to this cam lope! wow! [Re: ph23vo] #2965654
09/20/21 08:31 AM
09/20/21 08:31 AM
Virginia
BSharp Offline
BSharp  Offline
Virginia
Could part of it be that without a prop acting as a flywheel, the engine isn't running as smoothly as it normally would?
Re: listen to this cam lope! wow! [Re: BSB67] #2965658
09/20/21 09:00 AM
09/20/21 09:00 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
The P 51 Mustang.
America First!
Re: listen to this cam lope! wow! [Re: carnut68] #2965680
09/20/21 10:23 AM
09/20/21 10:23 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
The P 51 Mustang.
And Avro Lancaster, used 4 ea. and Havilland Mosquito's with 2 ea.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: listen to this cam lope! wow! [Re: 3hundred] #2965694
09/20/21 10:52 AM
09/20/21 10:52 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We have hundreds of Merlin/Packard V12's floating around here at work. You could say my boss is more than a fanatic.. It is amazing when we fire one up after a rebuild. Even more amazing when the boss does a fly by in one of his P51 Mustangs how loud these things are.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: listen to this cam lope! wow! [Re: BSB67] #2965705
09/20/21 11:37 AM
09/20/21 11:37 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Here's a couple.
https://en.m.wikipedia.org/wiki/Avro_Lancaster
https://en.m.wikipedia.org/wiki/De_Havilland_Mosquito
The Merlin's big brother, the Griffon was in The Miss Canada IV unlimited hydroplane that set a water speed record of 173 mph in Picton Ontario in 1950. The record isn't official because the transmission failed on the return run. It was on a 200+ mph pass when it failed.
Kevin
miss_canada_iv_record_run.jpgIMG_20151003_141825381.jpgIMG_20150923_165629070_HDR.jpg
Re: listen to this cam lope! wow! [Re: 6PKRTSE] #2965707
09/20/21 11:52 AM
09/20/21 11:52 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Merlins were also used in civilian aircraft.
Canadair Northstar was a DC4 with Merlins instead of radials.
The last surviving one is in Ottawa Ontario at the the Canada Aviation and Space Museum.
I delivered an ornithopter to them some years ago and got the back room tour of the place. I can say I helped with the restoration of this aircraft. I held one of the magnetos up while the tech removed the bolts to get it off the engine. Lol.
https://en.m.wikipedia.org/wiki/Canadair_North_Star
Kevin
Re: listen to this cam lope! wow! [Re: 6PKRTSE] #2965724
09/20/21 12:38 PM
09/20/21 12:38 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
You want to hear loud ...The F 22 Raptor is bad.. They did a fly by side by with a Raptor and a P 51 at the Ocean Md air in June, the P 51 looked like a matchbox plane compared to the Raptor. The sound of the P51 s supercharger is awesome.
America First!
Re: listen to this cam lope! wow! [Re: ph23vo] #2965756
09/20/21 01:35 PM
09/20/21 01:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: listen to this cam lope! wow! [Re: John_Kunkel] #2965796
09/20/21 03:45 PM
09/20/21 03:45 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the above engine is one of two (LH) for/from a DE Havilland Mosquito
anyone know why some had the rear two cylinders with one exhaust stack?
Re: listen to this cam lope! wow! [Re: 6bblgt] #2965859
09/20/21 09:03 PM
09/20/21 09:03 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Would've been nice just to hear it throttled hard once grin but understand the reasons they didn't as Leno commented. Still would've been awesome beer
Re: listen to this cam lope! wow! [Re: TJP] #2965895
09/20/21 11:49 PM
09/20/21 11:49 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
they were rated at 3,000 RPM how much higher did they get spun at EWP (or in boats/tractors)? work I'm guessing the V12 would sound great at 4,000 but that wouldn't be healthy long term
Re: listen to this cam lope! wow! [Re: 6bblgt] #2965900
09/21/21 12:51 AM
09/21/21 12:51 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Only reason I can think of for the paired rear exhausts is heat & flame too close to the airframe.
They do spit fire at times.
Didn't that aircraft have a lot of wood in its construction ?
(Something like that was called "the flying piano" for its wood content.)
Love the sound of a Merlin or Griffon flyover at speed. Nothing else like it.
Wonder what they'd sound like with an exhaust more like the old V12 Ferraris...?
As for the RPM, I would think the props are part of the equation.
And back in those days engines weren't apparently spun at high RPM in most applications.
Re: listen to this cam lope! wow! [Re: 6PKRTSE] #2965902
09/21/21 01:27 AM
09/21/21 01:27 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Agreed! I have attended all sorts of shows and love everything from Steerman's to them to B bombers. Awesome sounds!
Ride eternal, shiny and chrome
Re: listen to this cam lope! wow! [Re: carnut68] #2965936
09/21/21 09:14 AM
09/21/21 09:14 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The P 51 Mustang.
IMHO the sexiest plane from the era.
