Drag Week 2021: Adventure w/HEMI Joel
#2965696
09/20/21 10:54 AM
09/20/21 10:54 AM
Posts: 10,009 MN
JERICOGTX
MN
After Drag Week 2018, HEMI Joel, and I left Atlanta Dragway tired, wore out, happy we finished the event, yet bummed out we finished in 4th place. Yet somehow on the way home we talked about things that could be improved for the next year. Things to make the car go faster, pick up ET when it had 5 mph over everyone else in the class, make the crossover from Street to Race and vice versa easier, and less time consuming. By the time we got home, we had it figured out, and we would come back to Drag Week in 2019 ready to go... At least that was the plan... Little did we know, life would happen, and the world would come to a stand still after that.
Lots of people wonder why the big thrash to get to Drag Week? Well it goes something like this for most. After returning from what is the most grueling week of torture, as far as working on a car, driving it 1000 miles in the heat, rain, blazing sun, and by the time you get home, you don't even want to LOOK at the car again for a couple of months. As for Joel, he runs his own business, and while he does take care of a few things while on the road, when he returns, it's time to buckle down again, and take care of things that might have been missed in his absence.
Fast forward to midyear 2019, and while working on my Road Runner, I get a phone call from Joel, saying he wanted to stop by and talk to me. Joel, and I live about 7 miles apart, as the crow flies, and we talk on the phone at least once a week. It must have been very important if he wanted to talk at my place, in person. I told him to stop over anytime. Joel came over that night, and walked into the garage, and gave me the news. "We are going to skip Drag Week". OK, what's up? Joel had gone in for a check up, on suspicion, and the doctor had found something. Wanting to get it taken care of right away, meant missing Drag Week. I'm not gonna lie, I got a little choked up. Not because of missing Drag Week, but Joel is a very good friend of mine, not just a Drag Week buddy. We've done a lot of thing together over the years, and seen a lot of cool things. Things I'd never have done without him. I told Joel, don't worry about it, take care of yourself, and we'll go to Drag Week in 2020.
We all know what happened for Drag Week 2020. Really bummed it didn't happen, but it is what it is.
2021 rolls on in, and HOPE that Drag Week might happen in September. Only time will tell, but registration did open up, and those that were signed up for 2020 would get first shot at 2021. Since Joel was lightning quick on the keyboard, we were in for 2020. Race #1 complete.
Joel had plans for not only entering Drag Week, but also the Midwest Drags, which started in Norwalk, Ohio.
Over the last couple years, Joel had been making changes to the Coupe. One of which was taking the T56 Magnum apart, and having 1-4 gears "face plated". The T56 magnum is not known for it's powershifting ability, and having it face plated would change that. keeping 5-6 with stock synchro's and sliders, would keep the trans easy to drive on the street. they are not needed going down the track anyways. Joel also switch clutches in the car. In 2018 he ran a McLeod Soft Lok. While this is a good setup for a race only car, it is not a good choice for a street car. Each day we would arrive at the track, take 3-4 turns of base pressure out of the clutch, make a pass, then put 3-4 turns of base back in. It was very time consuming, and minutes at the track, can result in hours down the road on Drag Week. Something different was needed that could be used for both. I think a McLeod Twin disc RTX is what he installed in the car? The last major item that was switched, was valve springs. Out came the basic type of spring, and in went the Beehive style spring. Joel can give better details on that swap, but lets just say, it turned into a pain to get everything correct, and add in parts being out of stock, and unknown backorder status. The HEMI project came to a halt because of it.
And with downtime, it gave Joel time to hone his arts and crafts skills:
69 GTX
68 Road Runner
Re: Drag Week 2021: Adventure w/HEMI Joel
[Re: JERICOGTX]
#2965782
09/20/21 02:59 PM
09/20/21 02:59 PM
Posts: 10,009 MN
JERICOGTX
MN
With Joel's health improved, and back to normal, it was time to get back to work on the Coupe, and make a push for Midwest Drags in Norwalk. The event is similar to Drag Week, but smaller, and there is a ET cutoff for cars, as the Promoter wants to keep the event RACE only. No Plan B's, unless it's another race car. The classes are the same as Drag Week more or less. That allowed Joel to enter the Hot Rod class. Rocky Mountain Race Week has a Hot Rod class, but the rules are more open, and stuff like turbos and Blowers are legal. It's not the place for a 8 carb 392 HEMI. That event also has "travel" days, stretching the event out a full 7 days. Summit Midwest Drags sounded like the best option to go for a win.
As time went on, I'd call Joe and see how progress was going on the Coupe. He was working on it steady, but having a issue getting valvetrain parts. Somehow, someway the planets aligned, and Joel, and the manufacturer were able to piece together the right combo, and get him what was needed to finish the HEMI. Once that was done, he could get the engine in place, and on to the rest of the drivetrain. The old Soft Lok was out, and in went a twin disc setup, that was going to be 2 sintered iron discs with a floater ring, and then to adjust the clutch at the hit, Joel bought a "Hillbilly Soft Lok" Basically this is a spring/dampner that slows the release of the clutch pedal, the slip the clutch at launch. It took a little doing but he got it in there. With the Coupe finally running again, it was time for a test drive. Problem one on the test drive, was the clutch didn't work properly, and it was determined the new sintered iron discs were too big for the pressure plate. Joel removed the trans, and clutch, the proceeded to try and turn down the discs on his lathe. No such luck. The discs have a Rockwell hardness off the charts it seems. Rotate the discs in the lathe, and use a grinder? That is what he did. Got the turned down to the diameter that was thought to have worked, and reinstalled everything. No luck. Back out the trans has to come. With time running out, Joel thought it was best to install the sprung hub organic discs that came with the clutch assembly. BINGO. That worked. But on to the next issue. The motor was not happy. Would barely run, and Joel just could not figure out why? Midwest Drags was fast approaching, Joel was burning the candle at both ends, and doing what he could. Here is the part I'll come off and look like an A hole. I wanted to go racing my own car on Memorial Day Weekend, and I did not much time to help him. The older I get, the less I want to not miss time at the tack with my friends. Joel was OK with it, as the car issues were mostly a one person job. A friend of ours named Steve, came over and helped with what he could. I had told Joel the weekend before we were to leave for Midwest Drags, I needed to know if we were going or not by Wednesday. If we were not going, I was dragging my Road Runner to Thunder Valley in South Dakota, and racing with my friends. If we were going, I'd be ready to go. Joel didn't want to give me an answer until it wasn't possible to make the event. Friday rolled around, and I called Joel right away in the morning. to ask if the car was running. No... So I loaded up my stuff, and made the 5 hour drive to South Dakota. I told Joel if something changes, call me and I'll head back home. I ran my car on Saturday, and lost first round. About that time my phone rings, and see Joel is calling. He has thrown in the towel on Midwest Drags, but had an idea. If I drove home, we would then drive to the first day of MWD, watch some racing, and from there head to North Carolina to pick up his enclosed trailer, and new to him Land Speed racer that had work done on it in NC. Sounded like a good idea to me, so I loaded up, and headed home Sunday morning. After a 5 hour drive home, I packed a new suitcase, and headed to Joel's place, where he had the camper ready, and we headed out. We made it to Norwalk the night before the event started on Monday.
The plan for Monday was to watch one round of cars, then pack up, and head south. Mark Fisher who is a veteran Drag Weeker, and in the Hot Rod class, was also at MWD. He was running his familiar 32 Ford truck with a 496 Big Block Chevy. We really wanted to see what he would run. It didn't take long to see Mark make a pass, and after he did both Joel and I just sat with a dazed look on our faces. Mark ran a 8.98 @ 150 mph. He is a great guy, and it was difficult to be upset about it, but Damn... I asked Joel, now what? "I'm not sure I want to chase that...
69 GTX
68 Road Runner
[Re: tboomer]
#2965805
09/20/21 04:25 PM
09/20/21 04:25 PM
Posts: 7,471 Minnesota
Hemi_Joel
Minnesota
Great start to the story, Jeff. One thing you forgot is that after DW2018, when I finally got around to checking out the Hemi, I found it had lost a piston pin circlip, and the pin had carved a fascimile of the Grand Canyon into the cylinder wall. So I had to have the block sleeved. That took a while too. Every motor I build in the future will have pin buttons!
The new valve springs I used are the Comp conicals. They use a tiny retainer, too small for 10 degree locks. So I had to find some 7 degree locks for my .312 beadlock valves. Comp doesn't make them, but pac does, but they were out of stock indefinetly. Eventually, I located what was apparently the only existing set on the planet.
While it was apart, I also switched to a Milodon gear drive.
On the t56 Magnum transmission, I installed a pump on the front cover that sucks lube from the rear of the trans, and sprays it out in the front. This is because there have been some great failures reported drag racing these transmissions when all the lube sloshes to the rear, and the front gears starve. It's all about reliability. This plays into the DW21 story on Monday of the event.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2966104
09/21/21 05:33 PM
09/21/21 05:33 PM
Hemi_Joel
Minnesota
[Re: Hemi_Joel]
#2966229
09/22/21 06:54 AM
09/22/21 06:54 AM
Posts: 10,009 MN
JERICOGTX
MN
With the shock of Mark Fisher running 8's in the Hot Rod class in the back of our minds, it was still a great day to watch some racing and see friends that only events like this bring us together. Scott Abbott was running his old reliable 1970 Road Runner, that has done many Drag Week's, Rocky Mountain Raceweek, and now Summit Midwest Drags. Scott is one of the friendliest guys you can meet. Always smiling, and eager to talk. We also ran into Mopar Billy's brother Dale. Dale was running his Gremlin, along with his son Little Billy. They were both making passes in the car. Dale put on a show for everyone as he stood the Gremlin up on the bumper, and when it came crashing down, it took a good chunk of Norwalk pavement with it. Typical Gebhart, he kept his foot in it, and ran the thing out.
As the day went on, it was time for Joel, and I, to head to North Carolina, and pick up his Land Speed car. "The Garage Shop" was our destination in the hills near Charlotte, NC as they were the shop that had reworked the rollcage, and fixed some other issues in Joel's car. These guys do amazing work, and while there we got a shop tour. One of the cars they were working on was a replica of Buddy Bakers famous K&K Insurance Daytona's. They were going to take the car to Bonneville, and see if they couldn't break the class record with it. Power came from a NASCAR small Block. Would have rather seen a HEMI in the car, but it's not my money paying for it.
With everything loaded up we started to head back to Norwalk, to catch the tail end of Midwest Drags. We made stops at the Biltmore Estate in Ashland NC, and the Wheels through Time museum. Both very cool places to see. While back at Norwalk, we got a chance to talk with those that finished the event, said we would see them at Drag Week, and made our way to the Henry Ford Museum. Another great place to see, and I was surprised to see not just Fords there, but everything you can think of. One of my favorites was the Goldenrod streamliner. Powered by 4 Chrysler HEMI's. Very cool to finally see this thing in person.
69 GTX
68 Road Runner
[Re: slantzilla]
#2966425
09/22/21 05:54 PM
09/22/21 05:54 PM
Hemi_Joel
Minnesota
I'm pretty sure all this background story is supporting material for what is to come.
[Re: Jeremiah]
#2966730
09/23/21 04:03 PM
09/23/21 04:03 PM
Posts: 10,009 MN
JERICOGTX
MN
I know most that are following along are wondering what in the world THIS stuff has to do with Drag Week? I can say this, IF you want to enter Drag Week, and need help, you will have to bring along a Trunk Monkey. The first requirement of choosing a proper Trunk Monkey, is make sure you get along. The two of you are going to be together for over a week, when you add in travel time to the event, the event itself, and then back home. You spend a lot of time right next to each other in a hot, noisy race car, for hours on end. You will get into situations that you rely on each other, and the other person is going to be there right in the thick of it when it happens, and it WILL happen. Unless you each spring for your own room every night, you have to share that space as well. Some people are a little messy at times... Joel and I have traveled so much together, that it has become very easy. Yes he can drive me nuts at times, but I'm no saint, and I know I drive him nuts even more. At the end of the day though we work well as a team. I push Joel to keep things moving, yet he's made me slow down and enjoy the simpler things in life. We've driven from Minnesota, to Florida, and back, and never once listened to a radio. Conversations about cars, family, and life have filled the time, along with many one liners from movies like Tommy Boy, and Dumb and Dumber. There are not many dull moments. As I said, choose your Trunk Monkey accordingly, so you don't kill one another during the week. Our time together is a lot like the movie Planes Trains and Automobiles.
The other question people have, is why is there always a Drag Week thrash before the event? I can say for Joel, not having Drag Week 2020 took the wind out of his sails for working on the car. Lets face it, none of us are getting any younger, and when DW2020 was canceled, Joel spent time doing other things he enjoys. He's a busy guy, between owning a successful business, to his activity in his Church, and most importantly his time with his family. There are more important things than thinking about Drag Week the other 51 weeks of the year. Now add in parts shortages, and finding even a few minutes to dedicate time to the car, and the next thing you know Drag Week is right around the corner. The thrash is on!
As Drag week got closer, I checked in with Joel, and it was discovered that the Holley 94's had a bunch of crud in them. Was it from bad pump gas? He had dumped in a older can of VP race gas, and possibly it was from that. We mix in Klotz octane booster for the street drives, and maybe that was the mystery gunk. Now it takes time to clean out 8 carbs, and get them all back together, along with the Rube Goldberg carb linkage. With it all together the car was tested again on the street, and it was much better, but still not 100%. The plan was to test the car somewhere over Labor Day Weekend, but it wasn't meant to be. Joel wasn't comfortable with how it was running to drive somewhere, so he continued on trying to get the car in better shape for the event.
I had taken Thursday off work to help Joel out some, as we were going to possibly use it as a travel day, and head to Great Lakes Dragway, so we could test on Friday. We got everything sorted out for tools, and extra parts and supplies needed for the trip. It was actually a very relaxed day as far as DW prep went. With the Coupe loaded in the trailer, our bags packed, tools and everything else we needed for the week ready, Joel asked if we could leave that night? Sure. I just had to go home, pick up my dog, and bring him to my parents house. That would end up taking me about 45 minutes, and I'd be back at his house around 9:30pm. With Joel's 93 Dodge running, we saddled up, and aimed the truck East, with the goal of driving a couple hours to get outside of the Minneapolis/St. Paul rush hour traffic. At 10:00pm the tires on the mighty Dodge left the gravel of Joel's driveway, and hit the pavement. Off we went, with the familiar sound of Joel saying "I can't believe were really doing it!" (every time).
Not even 5 miles into our trip, I'm noticing the transmission temp gauge is already at 190*. I thought it was awfully quick to climb that high, but after all we were pulling a 28' enclosed trailer, and there is a 6500lb camper in the bed of the truck. We drive a little further, and I mentioned it to Joel. Thinking the trans might be low on fluid, we pulled into the parking lot of our local high school. Joel puts in 2 quarts of some slippery slimy fluid the rest of the world calls ATF. I have no idea what the stuff is? With the trans topped off, we continue East. The temp had cooled some, but after a couple miles it was once again climbing. It's now climbing to 210, and still going. Joel says to me "I have my foot to the floor, and we can't go over 62mph on flat land". Oh oh... We aren't going to make it going through the hills of Wisconsin this way... We decided it was best to turn around, and scrap our plans to test at Union Grove the next day. So we limped the once mighty Dodge home, and called it a night. Our plan was to wake up in the morning, switch over to Joel's work truck, and we'd have to find hotels along the way since we now didn't have a camper.
Friday morning rolls around, and now our plan is to drive to Stanton Michigan, and test the car there. They were having a Test night on Saturday, from 5-11pm. Joel doesn't want to drive through Chicago to get to Michigan, and asks if I mind if we go through the U.P.? "Sure, I've never been through there!". Changing to Joel's work truck doesn't take too long. We just had to switch the hitch height on his weight distribution hitch. Off we go. Once again "I can't believe were really doing it". (Yes, every time) Right away after we leave, Joel gets on the phone, and starts finding us a hotel room, as we now didn't have or travel days booked. He was lucky to find one just North of the Mackinac Bridge. We made it there with no issues, and I'm glad Joel called when he did, as the place was booked full, and nothing was available within a hour range. We asked why it was so busy, and were told that every September 11th, for the last 8 years or so, there is a antique tractor parade, and hundreds of old tractors cross the bridge. We got up the next morning, and wanted to be moving before the tractor parade, and not have to wait to cross the bridge. As we get closer, we see old tractors everywhere, and people are lined up on both sides of the street. as we crossed the bridge, the tractors were already heading North, and it was quite a sight to see. They just kept coming. If you've never been on the Mackinac bridge, I will say this, it's windy, and you are WAY above the water at it's peak. No way I'd want to be on a tractor crossing it.
We rolled into Mid Michigan Motorplex in Stanton, at 3:00pm. I'm pretty excited to be at this track, as it's one I haven't been to, and one I could add to my list. Gates were to open at 4:00, and testing started at 5:00, so we had some time to kill. Since we were the first ones there, and the gate was locked, Joel wanted to take the Coupe out of the trailer, and do some testing on the entry road. Nothing hard core, just driving it around, and getting used to the car again. I spent my time talking with a few racers that arrived after us.
At 3:55pm, Joel comes up to me, and says "we have a problem"...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2966769
09/23/21 06:35 PM
09/23/21 06:35 PM
Posts: 8,156 Plymouth, MI
Blusmbl
Plymouth, MI
The writeup is already excellent. Can't wait for more installments!!! I've crossed the bridge on my Harley before. Looking down through the grates and seeing the water almost 200' below is nuts.
[Re: Blusmbl]
#2966779
09/23/21 07:03 PM
09/23/21 07:03 PM
Hemi_Joel
Minnesota
Don't let Jeff fool you! That is not our hotel room. He's messy, but I would never let him get away with that!
[Re: tboomer]
#2967064
09/24/21 03:19 PM
09/24/21 03:19 PM
Posts: 859 lancaster,california
johnnycuda
Great start to your adventure, Billy is reading this, smiling!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: johnnycuda]
#2967611
09/26/21 07:36 PM
09/26/21 07:36 PM
Hemi_Joel
Minnesota
This is what cost me Midwest Drags. NEVER assume you know what's in a can!
[Re: HardcoreB]
#2967742
09/27/21 09:31 AM
09/27/21 09:31 AM
Posts: 277 lino lakes, mn
Schultz62
lino lakes, mn
What is that sludge Joel?? Looks like blackwater from septic
[Re: Schultz62]
#2967764
09/27/21 10:44 AM
09/27/21 10:44 AM
Hemi_Joel
Minnesota
The car has two fuel tanks. A 15 gallon for street, and a 3 gallon for race gas. The car had been running great, but right before Midwest drags when I took it for a test drive, it ran horribly. Somehow, all this crud got into the street tank. I'm not sure when or how.
