Re: Carb to hood clearance
[Re: DusterKid]
#2963117
09/11/21 09:42 PM
09/11/21 09:42 PM
Posts: 16,469 On the run…
BloFish
On the run…
Measured from the vents, two inches are optimal.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: dvw]
#2963529
09/13/21 10:08 AM
09/13/21 10:08 AM
Posts: 1,771 Keymar, MD
DusterKid
Keymar, MD
Mine runs right about 1". Been 9.05@149 with this setup. Doug Is that from the top of the vents to the hood?
[Re: DusterKid]
#2965260
09/18/21 03:17 PM
09/18/21 03:17 PM
Posts: 4,561 Motor City
6PKRTSE
Motor City
I have 3" from the top of my carb flanges to the scoop on my Challenger.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: DusterKid]
#2965650
09/20/21 08:02 AM
09/20/21 08:02 AM
Posts: 4,035 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
How close have you ran with a carb to the hood (hood has no scoop) without it affecting the car? Where was the carb to hood measured? Top of bowls. vents? There are a lot of things that come into play depending so, there is no one answer that fits all, unless it is 3" above airhorns. The only way you'll know for sure it to test and try it on your application.
