Re: Pitman removal w/linkage attached?
[Re: varunner]
#2965656
09/20/21 08:39 AM
09/20/21 08:39 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
FWIW, I needed to remove the oil pan on my challenger. I disconnected the pitman arm from the gear box, and the idler arm from the k-member. Then the whole assembly, drag link and all dropped down. Pan came off easy and it should give you plenty of room to drop the gear box out. Also I did this on a 2 post lift, so the front suspension was dropped down. Might be a different story if the car weight is on the suspension.. I did the same thing on my A body.
