Page 18 of 20 1 2 16 17 18 19 20
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Neil] #2963940
09/14/21 09:50 AM
09/14/21 09:50 AM
West Palm Beach, Florida
Copper Dart Offline OP
Hurst Pro-Matic shifter ordered up
I'm having to remove some of the peel and stick product I installed at the recommendation of a non-car guy shruggy whistling
Its a product typically used on roof repairs. I cant tell if its a butyl based or tar so Im removing it to avoid trouble. If it is tar based I can imagine, once the firewall heats up in the typical south Florida climate, the mess Ill have melting down onto my floors. shocked
As I'm removing it I must say it doesn't seem like a tar based product and man does it stick!
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2964928
09/17/21 09:43 AM
09/17/21 09:43 AM
Rebuilding the steering column and I can't find the lower bearing. This bearing has water damage and is a little rough but after clean up with ospho (phosphoric acid dissolves rust) it is usable.
The column I suspect it's from a 1973 Duster floor shift. I would appreciate help in finding where to buy a new bearing or if someone makes a service kit to replace the bearing and race as an assembly would be great too. Thanks in advance.
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2965424
09/19/21 07:31 AM
09/19/21 07:31 AM
Just some more pictures of the steering column bearing. Cast aluminum bearing race has mopar part numbers but I found nothing in my search. The race presses up into the lower most column tube, the bearing fits the steering shaft snug and the spring keeps it seated fully into the race.
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2965426
09/19/21 07:33 AM
09/19/21 07:33 AM
More pictures. I hope someone can find and share information on this particular bearing setup. up
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2967448
09/26/21 07:52 AM
09/26/21 07:52 AM
Progress on the steering column and bearing. I adapted the lower bearing from the '73 column onto my '70 column that i'm converting to floor shift. Once I removed the column shift tube, the original bearing served no purpose.
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2967451
09/26/21 08:14 AM
09/26/21 08:14 AM
Test fitting the column I found out several interesting things. scope First, the lower firewall bracket to steering column is not in a fixed point, it's adjustable! workSo the depth into the engine compartment of the entire column and position of the mid supports can be moved. The coupling from power steering to manual steering have different spline/shaft sizes, shruggy the manual steering box has a larger shaft so I had to change the coupling too. I tried to get a measurement to have a record for myself.
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2967455
09/26/21 08:25 AM
09/26/21 08:25 AM
Once I have the measurement right, I have to drive hammerthe lower spring clip up to press and hold the bearing into its race at the bottom of the column. It's surprising how hard it is to move and it leaves gouge marks in the shaft too. shocked
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2972196
10/08/21 08:08 PM
10/08/21 08:08 PM
I temporarily installed the steering column to be able to steer the car onto the lift later for the engine/transmission/K frame re-install. The lower column only needed to be 2" into the engine compartment and now the underdash mounts are toward their extension limits. up Looks much better all painted up.
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2974763
10/15/21 08:54 PM
10/15/21 08:54 PM
Something I was doing my best to avoid but it needs to be addressed. violin When I pulled the original carpet out it revealed scope some common but bad news. Seems over the years that the a/c condensate has leaked onto the passenger floor soaking the carpet jute and rusting the floor. frown After removing the loose rust and applying ospho I am left with swiss cheese. sawzall weld hammer primer I purchased a new repair panel but I don't want to use the entire section so I'm going to just remove at the marked line. Wish me luck punkrocka
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2975095
10/16/21 06:27 PM
10/16/21 06:27 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
A patch should work. Good luck with it.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: DynoDave] #2975135
10/16/21 07:48 PM
10/16/21 07:48 PM
Thanks Dave up
OK so I did a thing..... sawzall hammer weld No turning back now shocked
I couldn't keep a straight line to save my life using the cut off wheel and the sawzall but I got it done! I think I'm going to cut back just a bit more to make the rearmost butt weld seam land on top of the torsion bar crossmember. I will overlap the sides and forward joint 3/4" and stitch and rosette weld the new patch panel in. Too time consuming and I'm not comfortable trying to butt weld the entire panel besides it's just the floor whistling, the only one that will see it is whoever I run over lol. up
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2975166
10/16/21 09:38 PM
10/16/21 09:38 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I'd buttweld it in myself even if it took a little longer. weld
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Neil] #2975253
10/17/21 09:42 AM
10/17/21 09:42 AM
I thank you guys for chiming in, it not only motivates but encourages me to keep going with this project. bow
I think, besides being considerably more time consuming, buttwelding weld with a mig welder requires clear access to both sides green (upper and lower floor) and I have limited lower access plus it requires near expert fitting of the panels. wrench I know some guys out there have either mad skills bow or have been doing these kind of repairs for years and are very experienced experts rant but I am far from a expert in the required skills department lol! smirk This is a patch and if this was some rare model car I would buttweld and probably replace the section completely. scope I plan on using small sheet metal screws to hold everything together and tight before welding and, of course removing the screws and filling the holes. luck
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2975307
10/17/21 12:13 PM
10/17/21 12:13 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
This way works great so long as you can pull the unused metal out from the back. Might work for you?
https://www.youtube.com/watch?v=_u31t13QO6A
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Neil] #2975449
10/17/21 09:52 PM
10/17/21 09:52 PM
That was fantastic! Thanks so much for sharing bow
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2975841
10/18/21 07:45 PM
10/18/21 07:45 PM
Just a bit of progress. Trimming this replacement panel is more difficult than I anticipated, my arms and hands are going to fall off violin Renewed respect of the body shop techs that do this for a living! Not the most fun part of this project by far. biggrin I'm marking, measuring, trimming scope, tapping hammerand test fitting a dozen times and I'm still far from a great fit.
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2975848
10/18/21 08:03 PM
10/18/21 08:03 PM
The forward edge gap is too much, I think it's so wide because of the angle of the original floor contacts the replacement panel and kicks it up so I'm going to attempt the infamous butt weld. I already cut the rear most edge to butt weld it and the fit is fantastic. I remind myself that it's only metal right? Tough to get much done in just a couple of hours but persistence pays off. boogie
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2975918
10/18/21 11:23 PM
10/18/21 11:23 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Same guy in the video above has another separate video on how to set your welder up. It's worth watching.
https://www.youtube.com/watch?v=qScAlxb34UA
Also when welding panels in use a flashlight to check for any pin holes and go back and weld those up as needed.
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Neil] #2977365
10/22/21 08:09 PM
10/22/21 08:09 PM
Fit, measure, mark and trim a little more. Rinse and repeat..... hammer sawzall scope
It might not seem like a big deal to you younger guys but, from kneeling hunched over the rocker, yellowI have to squeeze out of the passenger door with the floor section in hand, greenclose the door without crushing the extension cords and do the crab shuffle sideways around to the other side of the car all the while careful not to scratch the car. Only room I have for working is the drivers side so I have no choice and it's kicking my butt. work My age is showing lol. frowwn
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2980390
10/31/21 09:31 PM
10/31/21 09:31 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
That trimmed up pan looks great!
I hear you on the age thing. I was up on my ladder today, cleaning out the gutters. Same house, ladder and routine for 28 years. Gets harder to do every year.
DynoDave
Member # 12304
