Re: Oetiker clamp for 3/8"
[Re: njmopar]
#2964710
09/16/21 02:06 PM
09/16/21 02:06 PM
Posts: 27,556 So Cal
autoxcuda
So Cal
IIRC, 170
You should be able to google it to make sure
[Re: PLATINUM6BBL]
#2964730
09/16/21 03:13 PM
09/16/21 03:13 PM
autoxcuda
So Cal
The 170’s seem to do it for common hose. They actually end up being pretty handy to have around.
Use those way more than the 157’s
157 would be something like thinner nylon hose.
[Re: autoxcuda]
#2964763
09/16/21 06:00 PM
09/16/21 06:00 PM
Posts: 3,843 Arlington, Texas
bobby66
Arlington, Texas
I Pretty sure these are 170’s
Interesting, I've only seen them in industrial applications. OSHA compliant, you know.
[Re: bobby66]
#2964775
09/16/21 06:56 PM
09/16/21 06:56 PM
autoxcuda
So Cal
Interesting, I've only seen them in industrial applications. OSHA compliant, you know. That’s just what I’ve used for 3/8 for machinery in a past job that were Oediker brand. I bought them from the industrial hose supply shop. Not sure what brand or number was on the original mopar stuff. I use them for function. They don’t cut the hose, stay tight forever, and don’t have a screw to scratch your hand. I also like ABA brand hose clamps. Nice stuff
[Re: autoxcuda]
#2964785
09/16/21 07:33 PM
09/16/21 07:33 PM
Posts: 10,611 Rittman Ohio
fourgearsavoy
Rittman Ohio
Although not correct I like the clamps from Fragola because they make a nice clean job with their push-lock hose and fittings. I just use my CV boot clamp pliers to set the crimp. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2964795
09/16/21 07:53 PM
09/16/21 07:53 PM
autoxcuda
So Cal
Although not correct I like the clamps from Fragola because they make a nice clean job with their push-lock hose and fittings. I just use my CV boot clamp pliers to set the crimp. Gus Same thing as an Oetiker? Just different brand? Actually some of the pictures for Frangola look to have Oediker stamped on them. I can make out the …ker stamped on these Fragola clamps. https://www.amazon.com/Fragola-999158-Hose-Clamp/dp/B002VT3GOUHere’s another:
