1969 Charger dash cluster question. #2964364
09/15/21 12:25 PM
09/15/21 12:25 PM
The Grand State of Confusion-O...
SKR8PN Offline OP
SKR8PN  Offline OP
On the 1969 Charger cluster, which gauges are controlled by the voltage limiter?
Karma has no menu. You get served what you deserve.
Re: 1969 Charger dash cluster question. [Re: SKR8PN] #2964371
09/15/21 12:37 PM
09/15/21 12:37 PM
moparx Offline
moparx  Offline
oil pressure, temperature, and gas gauge.
beer
Re: 1969 Charger dash cluster question. [Re: moparx] #2964379
09/15/21 01:05 PM
09/15/21 01:05 PM
SKR8PN Offline OP
SKR8PN  Offline OP
Thanks! That helps a bit.
Re: 1969 Charger dash cluster question. [Re: SKR8PN] #2964397
09/15/21 01:42 PM
09/15/21 01:42 PM
SKR8PN Offline OP
SKR8PN  Offline OP
Fuel gauge works. Temp gauge will work when the wire is grounded but not when connected so that issue is more than likely the sender. Oil gauge is dead when grounded so that's either the wiring, the bulkhead connector or the gauge itself.
