E Body - Cars For Sale - 3rd Quarter #2939312
07/03/21 12:17 PM
07/03/21 12:17 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: E Body - Cars For Sale - 3rd Quarter [Re: moparts] #2944553
07/18/21 01:02 PM
07/18/21 01:02 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
1970 Dodge Challenger Convertible
$45,000
Originally:
Yellow, Black Interior, Black top
Currently:
GB5 Blue, White interior, White top
I bought the car 17 years ago all apart as someone’s discarded project. Most of the back end, floor, and under hood bodywork had been done. I finished the car in my choice of paint color and interior to serve as a reliable and presentable driver quality car. The car retains the original engine and transmission. Many new and reproduction parts were used as well as rebuilt originals where I felt the reproductions at the time were lacking. Below are some details of what has been done. Please feel free to contact me with any questions.
Engine:
- Original 318 rebuilt, approximately 3000 miles on rebuild.
- Rebuilt heads with the same casting as the originals.
- New Rings, Bearings, Oil pump, Water pump, Fuel pump.
- Stock grind 71 340 Cam with new lifters.
- Factory correct 70 340 intake with correct number AVS carburetor (Original intake included).
Exhaust:
- Newer style 360 exhaust manifolds
- NOS Walker Head pipes
- Reproduction Resonators
- Walker mufflers with pipes welded to them, turn down style. At least one has a hole in it.
Suspension
- New upper and lower ball joints
- New upper and lower control arm bushings
- New tie rod ends
- New Rear springs and shackles
- New front and rear shocks
Transmission :
- Original 904, nothing done to by me except selector shaft seals, tail shaft seal, new dipstick tube and drain fluid.
Rear Axle:
- 7-1/4, believe to be original, nothing done by me except to check fluid level.
- New U-joints
Exterior:
- Base Clear 71 B5 blue hand rubbed to an almost glass finish. There are currently many imperfections due to moisture, etc. Popping under paint.
- New bumpers from Autobody Specialties.
- Original grille and bezels in very nice shape.
- Reproduction hood moulding.
- Convertible mouldings all in excellent shape except for right front pillar. I actually had it straightened but the fellow took the curve out of the moulding and the door rubbed it. I tried to put the curve back but kinked it.
- Beautiful correct grain vinyl top and rear curtain put on. Before having the top put on I put on new cylinders, new hoses, and new seals in the pump.
- Tail lights and bezels are originals in good driver shape.
- 14” Rallye wheels with decent centers and new trim rings
- 71 Style painted rallye mirrors.
Interior:
- New White PUI interior
- Door panels and rear panels are original black ones painted with Krylon plastic paint.
- Console is 71 style with ashtray and has crack next to shifter.
- New carpet
- (3) speaker 71-Up dash with single speaker AM/FM radio from a C-body
- New Seatbelts
- Black Legendary boot
- New Black visors.
Brakes:
- Manual 10” Drums
- New cylinders, shoes and hardware prior to me buying.
- New steel lines and hoses
- Rebuilt original style master cylinder
- System has DOT 5 silicone fluid.
Other:
- New reproduction gas tank and fuel lines
- New aftermarket radiator 22”
Below is the decode of the fender tag , I do not have a broadcast sheet
R11 AM Radio
V5X Black Vinyl/aluminum side mouldings
Y05 Build to US specs
EN1
V3X Black Convertible top
A04 Basic Radio Group AM Radio, Power Steering, Variable wipers and electric washer, left remote mirror
C16 Console
C55 Bucket Seats
G33 L/H OS remote racing mirror
P37 Power Convertible top
FY1 Lemon Twist paint
H6X9 Black standard vinyl interior
000 Not two-toned
A04 Built October 4 1969
009217 Order Number
E44 318 Engine
D31 904 Auto transmission
JH27 Challenger, high price class, 2 door convertible
G0B 318, 1970, Hamtrack assembly plant
149019 Sequential number
Below are some links to pictures
Cudaize@comcast.net
Current Photos
https://www.flickr.com/gp/193058870@N07/775Gf4
On lift
https://www.flickr.com/gp/193058870@N07/1v176y
As bought
https://www.flickr.com/gp/193058870@N07/459n8y
Modify message
1971 Challenger R/T 340 real N96 [Re: cudaize] #2944948
07/19/21 08:52 PM
07/19/21 08:52 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
For sale 1971 Challenger R/T 340. 1 of 39 Shaker 340 R/T's made. Plum Crazy. Born with automatic transmission. Engine is a 71 340. 416 short block. 71 heads, intake and thermoquad. Hooker headers. Rubber bumpers, gull wing and rim blow. The car is done to a high standard. Dip prime and over spray under side. Ultra solid original body. Hood has been replaced. Other panels appear to be the originals. Drives out well. All the pictures are too big. Call me and I'll get them out to your e mail. Offered at 62,500. 716-498-6672 evenings. Thank you.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Hemi Cuda [Re: Dartman440] #2952522
08/10/21 04:34 PM
08/10/21 04:34 PM
Sunny Land
RichP Offline
RichP  Offline
Sunny Land
70 Hemi Cuda F8 Green with Black interior 4 speed
Numbers matching drivetrain 44k miles all original body panels and interior
Just one repaint on straight rustfree body
Comes with 3 fender tags & buildsheet $250K
Coming out of a private collection with other rare cars!!
Contact gotmusclecars@gmail.com for more info and pics!!!
Always looking for Hemi 4 speed cars with documents and it's original drivetrain!
PINK TA [Re: RichP] #2952523
08/10/21 04:35 PM
08/10/21 04:35 PM
Sunny Land
RichP Offline
RichP  Offline
Sunny Land
Pink TA 4 speed all numbers Low mile one repaint with buildsheet
$110K Contact gotmusclecars@gmail.com for more info
1971 Cuda' 340 Auto. 2 fender tag California Car. [Re: RichP] #2952787
08/11/21 12:11 PM
08/11/21 12:11 PM
Southern Michigan
Dartman440 Offline
Dartman440  Offline
Southern Michigan
SOLD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
At The Nationals Fast,
Thanks Again
1973 dodge challenger [Re: moparts] #2954541
08/17/21 08:19 AM
08/17/21 08:19 AM
wisconsin
K
kingfish11 Offline
kingfish11  Offline
K
wisconsin
1973 dodge challenger,originally 318, now 383 4 barrel 727 counsel automatic non ralley gauges,orignally an ac car, currently doesnt have a/c compressor ,lines etc. previously a texas car solid body frame etc, one patch in trunk, Nice body and paint, original color , autumn bronze metallic.,Black interior. 323 sure grip 8.75 rear, runs and drives, tinted windows, Amd r/t hood and rt stripes have been added as well as rear spoiler.Has clear title in my name, also has correct vin and fender tag. many new parts! the only reason i am considering selling is i bought a hellcat. Car is located in northern wisconsin $18,500 firm cash only no trades. 715 403 2140
chal int.jpg (944 downloads)
Re: E Body - Cars For Sale - 3rd Quarter [Re: cudaize] #2957357
08/25/21 05:36 PM
08/25/21 05:36 PM
Ohio
Race Inc Offline
Race Inc  Offline
Ohio
Original paint true SURVIVOR 1970 Challenger R/T convertible. 25k original miles Go Mango with near mint white seats and original white top. Original carpet and early 70s replacement polyglas tires. Original window sticker. Numbers matching 383 Magnum and numbers matching 727 console automatic. Runs and drives beautifully. As seen in Carlisle survivor tent 2012. 3 owner car. You simply won't find a better original e body convertible in such a great color combo. This car needs to get out and be seen. I haven't had it to any shows since Carlisle 2012. $89,900.00. call two one 6 310-110seven
Re: E Body - Cars For Sale - 3rd Quarter [Re: moparts] #2958366
08/28/21 03:38 PM
08/28/21 03:38 PM
N.W. Indiana
62maxxx Offline
62maxxx  Offline
N.W. Indiana
1970 Challenger R/T [Re: moparts] #2935123 06/21/21 12:18 AM
62maxxx Online Content
N.W. Indiana
Up for sale, is my high school car I have kept since 1978 (42 YEARS). 1970 Challenger R/T, it came with a 1968-383 Magnum, 727 slapstick and a 3:91 when I bought it. It's a REAL R/T with 94K original miles, the original, factory EK2 (Go Mango) paint code, (repainted) white vinyl top and white interior. It has the original "956" radiator, dash, gauges, steering wheel, door panels and seats with new upholstery, seat buns and headliner. Original sheet metal except for the rear quarters, dutchman panel, trunk pan and extensions. Original fender tag along with TWO build sheets! I correctly converted it to a fresh, rebuilt 4-speed with the modern synchros, Centerforce clutch and a new 3:54 some years ago. There is approx. 2K/ miles on this drivetrain. I added a front disc brake conversion, PST front end components, Milodon hemi oil pan, Flowmaster Super 40's with 3" pipes to the rear, MP super stock springs with "C" body shocks, black hood stripe, 6-way seat, burnt orange carpeting and a original Mopar re-chromed luggage rack (no repo) and a painted to match trunk lid. I have the original painted trunk lid also, since you had to have a special lid to mount the luggage rack. The rear seat belts, jack, jack spring and the spare tire hold down are missing. I always preferred the "340" air cleaner over the dual snorkle set up for a cleaner engine bay "look" for anyone wondering why it's on there. With the factory color combo, this car is a magnet at every car show I have attended. It is simply, just a beautiful car. I can say after owning this car for 42 years, it runs & drives fantastic. $61,500/NEGOTIABLE. E-Mail: magnumforce440@comcast.net Located in NWI, 40 miles east of Chicago. 360 degree video available upon serious interest.
This car will be at MCACN in CHICAGO this NOVEMBER if it does not sell by then. Thanks!
70 Chall5.jpg (1348 downloads)
70 Chall7.jpg (1347 downloads)
70 Challenger 020.jpg (1346 downloads)
70 Challenger 009.jpg (1345 downloads)
70 v-code Cuda 4speed [Re: moparts] #2958475
08/28/21 09:22 PM
08/28/21 09:22 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Operation 1970 440-6 pac 4 speed Cuda;
EV2 Hemi Orange, black top and interior, bucket seats, console, power steering, power disc brakes, am/fm radio, 3:54 Dana rear axle, 15" rally wheels.
Original quarters and trunk floor, beautiful older restoration in excellent condition. Bottom of the car is painted. Non matching drivetrain. Well, they match... The engine and tranny do match... Each other... But not the car.. 😁 3" TTI exhaust, Los Angeles built car so there is no build sheet...
This is a very clean and solid car.. Went riding in it today and it is nice, tracks straight, shifts great and has getting-up-and-go..
Passing this on for a good friend..
$110k obo
Julius. 818-590-2860
Or Private Message
Troy
Houston Mopar Connection Club
1970 Challenger RT Convertible [Re: hemi68charger] #2959049
08/30/21 03:00 PM
08/30/21 03:00 PM
Boston, MA
crocha617 Offline
crocha617  Offline
Boston, MA
1970 Dodge Challenger RT Convertible was 383 now has a nice 440. This is a real JS27 RT not a clone.
It's a very nice rust free car that was restored by the previous owner a long time ago but the body and paint still look very fresh. He painted it a custom blue/turquoise color. The underside and engine compartment look excellent as well. The bumpers and trim look like new. The seats appear to be the originals and are starting to show their age but are still very presentable. The dash pad is mint and the rear convertible panels are very nice. Someone installed speakers in the front door panels at some point. The car runs, drives, and sounds really good and everything works. It has after market front disc brakes, front sway bar, and power top. The original fender tag and dash tag are with the car and the cowl and radiator support match. I have not looked for a build sheet yet. I have photos from when it was restored showing the metal that was done etc.. that I can forward to serious buyers.
There is no radio installed but I have the original, the speedometer needle broke recently but I have an extra speedometer assembly that I will include. The driver's side window rattles a bit. Otherwise the car is very nice. I am open to offers and possibly a partial trade that would probably only work out if you were local. I like Mopar convertibles from 1968-1971 but may consider something else from that time frame.
Please contact me with any questions you may have. Asking $57k or BO
Call Chris @ 617-593-2852
1970 Challenger Shell [Re: crocha617] #2962423
09/09/21 10:17 AM
09/09/21 10:17 AM
TN
JS29R0B Offline
JS29R0B  Offline
TN
1970 Challenger shell. This is very solid car. It has been in my barn on a concrete floor for 25 years. No dash vin or title.
You will not find a more solid car. Needs Dutchman panel and other minor patch work. I am 60 miles southeast of Moparty in Bowling Green.
I can help load. 8k. Email moparmafia@yahoo.com
1971 Cuda 340 [Re: moparts] #2963877
09/14/21 12:11 AM
09/14/21 12:11 AM
X
xx29 Offline
xx29  Offline
X
for sale: 1971 Cuda 340, console auto, factory A/C car, BS23H1B, numbers matching engine out of the car, transmission still hooked up with driveshaft, 92K miles, last driven in 1987, California car with original blue license plates, Lemon twist/black interior, no vinyltop, fendertag missing, small sections of buildsheet were found, car is mostly original with one repaint in the 80's, owner history known, I've talked to the original owner who purchased the car in Whittier, CA in late summer of '71. Build date 6-71, blue engine with electronic ignition. Some rust repairs needed. However, original trunk floor has no rust. No fancy options, standard gauges, manual outside mirror, hood pins. Power steering, power disc brakes. Correct radiator. 14" Rallye wheels. Original exhaust system still in it with exhaust tips. Grille just about perfect. Car is complete. Clear CA title in my name. $42500. No trades. Thank you. e-mail: ebodycab@msn.com. Phone: 818-345-0515.
1970 Challenger T/A [Re: moparts] #2964210
09/14/21 10:39 PM
09/14/21 10:39 PM
X
xx29 Offline
xx29  Offline
X
for sale: 70 T/A, burnt orange/burnt orange interior, column auto, original paint/stripes, needs some rust repairs, no engine, have 70 340 block if wanted, no T/A block, correct part # auto trans, correct # radiator, sixpack set-up, standard gauges, power steering, power disc, original T/A hood and rear spoiler, $32500, no trades, thank you. email: ebodycab@msn.com, phone: 818-345-0515
1971 Challenger convertible [Re: moparts] #2964218
09/14/21 10:55 PM
09/14/21 10:55 PM
X
xx29 Offline
xx29  Offline
X
for sale: 1971 Challenger convertible, 318 car, JH27G1B, originally automatic, converted to 4spd, B5 blue from factory, someone started a color change to red, everything inside is painted red, amateur job, metalwork done poorly, I would do it again if building a nice car, power steering, drum brakes, non-air car, rolling shell, have 318 and 4spd cores to go with it, needs completely gone thru, depending on what one would do with it, $22500, no trades, thank you. Email: ebodycab@msn.com. Phone: 818-345-0515
Re: E Body - Cars For Sale - 3rd Quarter [Re: moparts] #2964544
09/15/21 09:13 PM
09/15/21 09:13 PM
Rochester NY
TheMoparKid Offline
TheMoparKid  Offline
Rochester NY
1971 Dodge Challenger RT
#s matching 383, pistol grip 4 speed (1 of 413)
GA4 light gunmetal metallic
Fender tag and build sheet
Older rotisserie restore
$62k obo
