W2 stroker build - too much main bearing clearance?
#2964036
09/14/21 02:24 PM
09/14/21 02:24 PM
Posts: 1,753 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Looking for some advice.
These are the numbers for my current build, using forged Eagle crank, .020" under on rods and factory size on the mains. While the rods look pretty good, the mains are a little big, at least based on everything I have always read and heard: 0.001" per 1" of journal diameter, so I should be at 0.003" max, but is that extra 0.0005" going to be an issue here?
ACTUAL BEARING CLEARANCE Main #1 2.8097 2.8126 0.0029 Main #2 2.8092 2.8127 0.0035 Main #3 2.8095 2.8129 0.0034 Main #4 2.8095 2.8129 0.0034 Main #5 2.8096 2.8130 0.0034 Rod #1 2.1041 2.1062 0.0021 Rod #2 2.1040 2.1064 0.0024 Rod #3 2.1040 2.1064 0.0024 Rod #4 2.1041 2.1064 0.0023 Rod #5 2.1041 2.1064 0.0023 Rod #6 2.1040 2.1060 0.0020 Rod #7 2.1040 2.1063 0.0023 Rod #8 2.1041 2.1064 0.0023
For comparison, here are the numbers for the cast 0.010" under (crank & stock rods) in my old 360 build:
ACTUAL BEARING CLEARANCE Main #1 2.7997 2.7960 0.0037 Main #2 2.7997 2.7960 0.0037 Main #3 2.7995 2.7960 0.0035 Main #4 2.7994 2.7960 0.0034 Main #5 2.7994 2.7960 0.0034 Rod #1 2.1143 2.1125 0.0018 Rod #2 2.1148 2.1125 0.0023 Rod #3 2.1143 2.1125 0.0018 Rod #4 2.1149 2.1125 0.0024 Rod #5 2.1143 2.1125 0.0018 Rod #6 2.1148 2.1123 0.0025 Rod #7 2.1143 2.1125 0.0018 Rod #8 2.1148 2.1125 0.0023
This motor ran with a 15W40 oil, great oil pressure, summary only weekend "toy" use.
Should I be worried here and should I start looking at the 0.001" thicker main bearings? I have the 3/4 grove FM 120M pieces about to go into this block otherwise.
Thanks!
Re: W2 stroker build - too much main bearing clearance?
[Re: Diplomat360]
#2964055
09/14/21 03:12 PM
09/14/21 03:12 PM
Posts: 9,092 Rogue River, OR
Jeremiah
Rogue River, OR
What are you using to measure it? Those numbers look okay to me especially for a drag engine. Over the years I haveheard a ton of people say not to run them that loose. Reasons stated included lack of a hydrodynamic wedge being created by the oil, etc.
On the other hand I know quite a few people that have embarrassingly loose engines and they seem to do just fine as street/strip engines. Perhaps a road race/endurance type of engine would be more susceptible to issues as the oil gets really warm? Maybe some of the guys with automotive engineering backgrounds can chime in on that side of things.
[Re: Jeremiah]
#2964061
09/14/21 03:23 PM
09/14/21 03:23 PM
Posts: 13,319 Marion, South Carolina [><]
an8sec70cuda
I'd rather it be loose than tight. I'd run it.
[Re: an8sec70cuda]
#2964094
09/14/21 05:06 PM
09/14/21 05:06 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’ve found that the “calculated clearance” and the “measured clearance”(bearings set into housing bore, torqued to proper spec, measured with a bore gauge that is set and zeroed to shaft diameter) often don’t agree with each other.
I use the “measured clearance” method.
[Re: Diplomat360]
#2964117
09/14/21 06:28 PM
09/14/21 06:28 PM
Diplomat360
Windsor, ON, Canada
Guys,
All numbers are MEASURED, meaning, here is what I used:
1) the main and rod bearings were installed, torqued to the required assembly readings: - mains => 110 ft-lbs with studs - rods => 85 ft-lbs to achieve approx. 0.0051-0.0055 both stretch with Eagle spec'ed ARP 2000 bolts
2) the dial bore gauge with 0.0001" precision was used to capture the measurements of the installed bearing diameter
3) the micrometer with 0.0001" precision was used to catpure the measurements of actual journal sizes
So these are all real numbers.
I attempted to record (for the purposes of blueprinting the engine) as much detail as possible.
[Re: an8sec70cuda]
#2964131
09/14/21 07:33 PM
09/14/21 07:33 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
I'd rather it be loose than tight. I'd run it. I have heard if its to loose only you will know, its its too tight everyone will know during the track cleanup lol
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: Diplomat360]
#2964209
09/14/21 10:38 PM
09/14/21 10:38 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
I've never heard or seen a rod bearing or main bearing spin from being to loose, not so on being to tight Your good on those clearances, I run similar on all my motors
[Re: Hemidavey]
#2964244
09/15/21 12:24 AM
09/15/21 12:24 AM
Posts: 4,457 Washington
madscientist
Washington
I wouldn’t run it that loose on the mains. It’s not 1975 any more. Even the rods are a bit loose for me. I’m glad the oft repeated “if it’s loose only you will know it” wives tale was brought up. With 1975 oils you need Grand Canyon clearance like that. Run a modern oil and close up the clearance. It’s the 21st century.
[Re: madscientist]
#2964324
09/15/21 10:37 AM
09/15/21 10:37 AM
Diplomat360
Windsor, ON, Canada
...With 1975 oils you need Grand Canyon clearance like that. Run a modern oil and close up the clearance. It’s the 21st century. This point here that madscientist brings up is part of the reason why I'm hesitant to run with that clearance. My intention with this build was to move to a lighter oil, something like a 10W30 for example instead of the 15W40. There is some obvious hp gain to be had by doing so, although quite frankly I doubt it would have a noticable impact given my intended use, that being a street car. Since I am running a HV oil pump that provides more feed, with the larger clearance the oil loss that's occuring there is most likely made up for by the higher volume. Probably the reason why my old 360 motor had a spotless looking crank journals when I took everything apart. That feels a bit like a band-aid fix though...LOL! Any suggestions as to what alternative bearing set I could look at? I do not want to re-grind the crank to something like 0.010" under on the mains. I will measure the main housing sizes (which I did not do so far), perhaps they are a tad wider and are NOT compressing the bearings sufficiently? The FM 120M bearing spec calls for a max of 0.0027" clearance, so I'm past that value. Unfortunately they do not have a 0.001" larger size available, which would mean I'd need to look at an alternative in that size.
[Re: Diplomat360]
#2964372
09/15/21 12:43 PM
09/15/21 12:43 PM
Cab_Burge
I've used Valvoline 5W20Wt oil in my street and strip motors for dyno testing for years due to no HP gain or loss on oil temps. from 80F to 220 F with loose clearances like I posted already. As far as synthetic oils I don't like them due to many bad results from switching to them during dyno tests years ago Maybe I will try again, maybe not
[Re: Cab_Burge]
#2964378
09/15/21 01:04 PM
09/15/21 01:04 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I would be more worried about the tight rod bearings in your old engine. Get that sucker together and “send it”. The day I worry about .0005 to much clearance I quit.
[Re: justinp61]
#2964428
09/15/21 03:18 PM
09/15/21 03:18 PM
Diplomat360
Windsor, ON, Canada
Check and see if King offers a -.001” bearing. I know they made a +.001” main. Funny (but sad) story about King bearings here. So a few months back, alright, more than a year now since I started planning this and acquiring the parts, I had originally decided to give the King stuff a try. I ordered both the mains and the connecting rod bearings from Summit...and waited....waited, waited some more. After a couple of months I got tired of it...sure, I didn't need them at the moment, but I was itching to get the block over to the machine shop. Needless to say, I cancelled that order and shipped the FM stuff straight to the shop the very next day. What irked me about this was that I actually called King directly about this delay, gave them my Summit order (which they found), and was told these would ship out "...within another week...". That was around the tail end of the first "wait" event...lol, it never got any better afterwards. So from a customer service perspective I wasn't impressed. So now looking at this again I see that I can get a 0.0005" oversized bearing (choice of up or down as well, so that's nice), unfortunately their ETA shows December timeframe right now. Based on my prior experience with King I trust that statement...NOT!!! Besides, really if all I'm making up is 0.0005", well like pittsburghracer said, I probably should find something else to do instead! ha... Gents, appreciate everyone's great feedback. I'm going to run with what I have, will measure the housing dimensions as well, just to know what those are. Thanks!
[Re: Diplomat360]
#2964458
09/15/21 05:24 PM
09/15/21 05:24 PM
Posts: 606 Boise
Moparteacher
Boise
Check and see if King offers a -.001” bearing. I know they made a +.001” main. Funny (but sad) story about King bearings here. So a few months back, alright, more than a year now since I started planning this and acquiring the parts, I had originally decided to give the King stuff a try. I ordered both the mains and the connecting rod bearings from Summit...and waited....waited, waited some more. After a couple of months I got tired of it...sure, I didn't need them at the moment, but I was itching to get the block over to the machine shop. Needless to say, I cancelled that order and shipped the FM stuff straight to the shop the very next day. What irked me about this was that I actually called King directly about this delay, gave them my Summit order (which they found), and was told these would ship out "...within another week...". That was around the tail end of the first "wait" event...lol, it never got any better afterwards. So from a customer service perspective I wasn't impressed. So now looking at this again I see that I can get a 0.0005" oversized bearing (choice of up or down as well, so that's nice), unfortunately their ETA shows December timeframe right now. Based on my prior experience with King I trust that statement...NOT!!! Besides, really if all I'm making up is 0.0005", well like pittsburghracer said, I probably should find something else to do instead! ha... Gents, appreciate everyone's great feedback. I'm going to run with what I have, will measure the housing dimensions as well, just to know what those are. Thanks! Is that .0005" per shell or .0005" for upper and lower combo? If it's .0005" per shell then you can always replace just one shell with an oversized, without issue. One of two ways to compensate for the loose clearances IMO, run a heavier oil or run an HV pump, but probably not both. If you've got HV pump in place already then you may want to sneak-up (actually down) on the viscosity. Start with maybe a 20w50 and observe idle pressure at full temp and then move down in viscosity until you pressure starts dropping below desired at idle. All testing done at operating temp. But, there is definitely a correlation between journal area, clearance and sufficient hydroscopic wedge to protect the journal. Oil pressure alone doesn't determine the level of protection. As for a HV pump, reconsider if you choose to close-up those clearances, and avoid high pressure all together (not that you ever stated such). Here's a fwiw. I recently primed a fresh 383 on the engine stand with 6 quarts in a Hemi pan with Milodon full windage tray and IJ crank scraper. Valve covers and valley tray off. HV ported oil pump with the MIlodon high pressure spring. Similar clearances. Quickly gained 80psi and all looked good so I continued to run the drill for a few more minutes while observing. It took about three minutes and I started to get splurging (air bubbles) coming around the flat tappet .0005" undersize lifters and out the spray holes on the ductile rockers yet the pressure gauge held steady at 80psi. The longer I ran the drill, the worst the cavitation in the pan yet maintaining 80 psi on the gauge the whole time. I was shocked! I then switched to a standard pressure spring in the pump. 60 psi, similar more-than-sufficient flow rate out the rockers and around the lifters, but after nearly 20 minutes no air bubbles, cavitation or drop in max pressure of 60psi. 10w30 Joe Gibbs Driven break-in oil FWIW. I doubt I'll ever run a HP oil pump spring again and the next build will seriously reconsider the HV. Good luck on whatever you choose.
