Wanted - Big Block Engine - 3rd Quarter #2939378
07/03/21 01:14 PM
07/03/21 01:14 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: Wanted - Big Block Engine - 3rd Quarter [Re: moparts] #2940448
07/06/21 10:33 AM
07/06/21 10:33 AM
an8sec70cuda Offline
Looking for a driver's side valve cover for a 1970 440. Has to be for a 1970 model. Only need the driver's side, but would consider a pair.
Looks like the one in the pic below.
email me at owensjc@scdot.org
or pm me here. Email is best.
Thanks, Chip
CHIP
'70 hemicuda...8 sec street car
'69 road runner 440 w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'06 GMC 2500HD LBZ Duramax...toy hauler
'16 Grand Caravan SXT...baby hauler
Wanted 1968 carter Avs mixture screw [Re: an8sec70cuda] #2941796
07/10/21 01:29 PM
07/10/21 01:29 PM
englewood beach, florida
ts70rt Offline
ts70rt  Offline
Looking for a 1968 only carter avs single mixture screw. This is on a 340, 383 and 440 carter avs 1968 only single center 10 x 32 left hand thread mixture screw. Pics supplied. Thanks
Re: Wanted - [Re: moparts] #2943667
07/15/21 07:42 PM
07/15/21 07:42 PM
Alabama
gold1950 Offline
gold1950  Offline
Alabama
DELETED -
Re: Wanted - Big Block Engine - 3rd Quarter [Re: moparts] #2944834
07/19/21 01:31 PM
07/19/21 01:31 PM
ohio
69coronetr/t Offline
ohio
Looking for mechanical 6 pack carbs
Edelbrock STR lid singel 4bbl [Re: moparts] #2947031
07/25/21 04:16 PM
07/25/21 04:16 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Im looking for a lid to a Edelbrock STR for singel 4bbl in good shape to a 440 intake !
Contakt me by mr440mopar(att)hotmail.com
Re: Wanted - Big Block Engine - 3rd Quarter [Re: moparts] #2949852
08/02/21 10:51 PM
08/02/21 10:51 PM
St. Louis, MO
moparbuff Offline
moparbuff  Offline
St. Louis, MO
Looking for un-modified Torker intake manifold(Model 3015). Thank you.
Victor or Trick flow heads [Re: moparbuff] #2950315
08/04/21 09:27 AM
08/04/21 09:27 AM
USA
hudsonhornet7x Offline
USA
I am getting ready to start a project and am looking for a pair of Edelbrock Victor heads, or a set of Trick flow big block heads. Please pm me here if you have a set to sell, or email me at dburt@vtc1.org Thanks
Re: Wanted - Big Block Engine - 3rd Quarter [Re: moparts] #2951350
08/07/21 11:59 AM
08/07/21 11:59 AM
South western, Ontario
dodgedifferent2 Offline
Found
OE Choke [Re: dodgedifferent2] #2951679
08/08/21 02:17 PM
08/08/21 02:17 PM
Transman Offline
Transman  Offline
Looking for a choke to fit the cast iron 440/383 intake with AVS carb.
1967-1970 approx time frame. This choke does not have the side wall that is used on manifolds where one side of the well is open.
Wanted: 383-400 Holley Street Dominator Intake Manifold [Re: Transman] #2952799
08/11/21 12:45 PM
08/11/21 12:45 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Hello,
Wanted: a low deck, big block Holley *Street* Dominator Intake manifold. Any condition will be considered - I can weld, tap and it will be painted before installation.
I can also provide a UPS label to make our transaction more convenient for the seller. Please PM me with details.
Thank you,
Jeremiah
Re: Wanted: holley 6 pack outboard Vacuum housing an [Re: Jeremiah] #2954652
08/17/21 12:55 PM
08/17/21 12:55 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I have a friend who is looking for a holley 6 pack outboard vacuum diaphragm housing and linkage. Someone has removed his to make the mechanical linkage and we would like to put them back original. He has located one and needs one more if possible please PM me here.
Matt
Re: Wanted - Big Block Engine - 3rd Quarter [Re: moparts] #2956879
08/24/21 10:46 AM
08/24/21 10:46 AM
Sacramento,California
JRepucci Offline
JRepucci  Offline
WANTED NOS STAGE IV Direct Connection cylinder heads for 440
wtb 400 motor [Re: JRepucci] #2957961
08/27/21 11:19 AM
08/27/21 11:19 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
hi
looking for a rebuildable 400 engine mid 70's stock, in northeast
gary
pm or gcastagna@oceanwesterly.com
BB pulley needed [Re: 440lebaron] #2958888
08/30/21 12:09 AM
08/30/21 12:09 AM
Washington
hemienvy Offline
hemienvy  Offline
Washington
I need a 2-groove, 5-7/8 diameter water pump pulley, p/n 3698917.
I think these are on 1973-on Big block with A/C.
Thanks !
Re: BB pulley needed [Re: hemienvy] #2959442
08/31/21 12:25 PM
08/31/21 12:25 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
WTB 2 used big block camshaft bolts
cowgerwilliam035@gmail.com
WTB 2 used 62-65 v8 motor mount bolt thick washers
BOLT 004.JPG (548 downloads)
BOLT 005.JPG (548 downloads)
BOLT 003.JPG (548 downloads)
Re: Wanted - Big Block Engine -Crankshaft 3rd Quarter [Re: moparts] #2961091
09/04/21 11:03 PM
09/04/21 11:03 PM
Lakeland, Florida
cbcborm Offline
cbcborm  Offline
Lakeland, Florida
LOOKING FOR 1968 TO 1970 440 FORGED CRANKSHAFT USED.
PREFERRED FLORIDA AREA.
ALSO LOOKING FOR 340 SIX PACK EDELBROOK INTAKE MANIFOLD.
EMAIL TO MELMOPAR1@VERIZON.NET WITH INFO.
THANKS, MEL
Re: Wanted - Big Block Engine - 3rd Quarter [Re: JRepucci] #2961361
09/05/21 08:26 PM
09/05/21 08:26 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Looking for an aluminum flange gasket like below for Carter AVS and possibly some Holley 4160 applications. All I really need is the aluminum piece but will take complete if you have it. I am fairly certain this was used on 71 AVS applications based on the instructions and gaskets included in the kits specific to the 4966 and 6125 carbs. Possibly used on 70 AVS applications as well.
Mike Afflerbach
Best to contact by email
cudaize@comcast.net
Standard bore, stock stroke 440 rotating assembly [Re: moparts] #2962085
09/08/21 08:00 AM
09/08/21 08:00 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I'm building a 440 on a budget and I have a good standard bore block, I want to get the compression up a little. (or lot)I am looking for someone's higher compression bottom end. Forged crank, rods, pistons. Can be aftermarket pistons, can be stock 10:1 slugs. Just something that you pulled out to go with a stroker bottom end. The closer to Ohio the better.
Thanks.
1966 Dodge Coronet 500
1969 Dart GTS 340
1969 Super Bee.
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Wanted - Big Block Engine - 3rd Quarter [Re: moparts] #2963982
09/14/21 11:36 AM
09/14/21 11:36 AM
JRepucci Offline
JRepucci  Offline
Wanted: Direct Connection Parts
Holley 6 Pack carburetors #4782 and #4783
Blue Anodized DC valve covers
