Vinyl top installer #2961137
09/05/21 06:04 AM
09/05/21 06:04 AM
McMurray PA
K
Kevin E Offline OP
Kevin E  Offline OP
K
McMurray PA
Good morning,
Does anyone know of a good place/person in the Pittsburgh PA area that installs vinyl tops? I purchased the top from Legendary and now am having trouble finding someone who still installs these. Thanks for any and all help, Kevin
Re: Vinyl top installer [Re: Kevin E] #2961140
09/05/21 06:41 AM
09/05/21 06:41 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Good luck. Around here nobody does it. At the last car club meeting, a few of us that have vinyl roof cars came to the conclusion we'll have to develop that expertise within the group and do it ourselves.
Re: Vinyl top installer [Re: 6PakBee] #2961147
09/05/21 07:41 AM
09/05/21 07:41 AM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Other than removing the front and rear glass, it's something you can do yourself successfully.
Watch a few you tube videos, be patient and methodical. Like learning any new skills, be prepared for failure on the first try. My first attempt wasn't perfect, a couple air bubbles and a couple small lumps where I didn't smooth the adhesive enough.
Angry white pureblood male
Re: Vinyl top installer [Re: ruderunner] #2961202
09/05/21 11:21 AM
09/05/21 11:21 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Kevin,
About 6 or 7 years ago a former coworker wanted a white top put on his 2011 challenger. He found an older gentleman who has been doing this type of work full time since the late 70s. I believe he was in Chambersburg, which is about 1.5-2 hours from Pittsburgh.
I never got a name or business name out of that conversation though. Hopefully this helps a little.
Re: Vinyl top installer [Re: moparjim79] #2961206
09/05/21 11:32 AM
09/05/21 11:32 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I think Dayclona on here wrote a nice start to finish how-to on vinyl top installations. I searched for it, but can't find it.
There are numerous YouTube videos I've seen where guys are pulling on the tops like their life depends on it, and many people say to not do that no matter what unless you want to tear the fabric or seams apart.
Re: Vinyl top installer [Re: Neil] #2961373
09/05/21 08:48 PM
09/05/21 08:48 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
If me and the wife could install it back in the 90s for the first time on a 71 B Body
It really isn’t that difficult honestly
Why would you have to remove the front and rear glass ?
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Vinyl top installer [Re: bee1971] #2961374
09/05/21 08:51 PM
09/05/21 08:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You do not have to pull the glass. It does make it easier but not required. Same for the headliner.
Re: Vinyl top installer [Re: bee1971] #2961378
09/05/21 09:02 PM
09/05/21 09:02 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
The real reason I took on the challenge
When I called numerous companies back in the 90s for a quote in WI
Sure , we can do it for this price , just drop it off and we will get it to it when we have time
So the car will sit outside ? Or do you have storage until you have time ? Serious
I figured for about $500-$750 per quote I could go thru multiple vinyl tops thru Legendary
Remember this was in the 90s
Still on my 71 Bee and Perfection
Trim and location and measure and only cut once is everything - Don’t cut and then
Believe it or not , I used 3M spray adhesive in a can
Siberian Huskies
Re: Vinyl top installer [Re: NITROUSN] #2961381
09/05/21 09:03 PM
09/05/21 09:03 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
That’s why I was asking - My factory glass never left the car
Siberian Huskies
Re: Vinyl top installer [Re: bee1971] #2961457
09/06/21 05:24 AM
09/06/21 05:24 AM
McMurray PA
K
Kevin E Offline OP
Kevin E  Offline OP
K
McMurray PA
Thanks for the info guys, I have been toying with doing it myself and given it’s a tough task finding someone who does it, I may still have to. I’ve had a couple leads but when I call they said they don’t do it anymore. Given it’s a wide seam for a Challenger I’ll just need to be careful of the centering of it and watch how the seam follows down the back sail area. I just got the car back from the painter in June so the windows are out so that’s not an issue.
Thanks again everyone, Kevin
Re: Vinyl top installer [Re: Kevin E] #2961460
09/06/21 06:39 AM
09/06/21 06:39 AM
ohio
ohio
Start from the center out and be very careful to start centered. A heat gun helps but a killer hair dryer works.
Glass removal makes it way easier, maybe not required on vehicle with glued glass but maybe required for gasketed glass. Pretty sure 68 70 B body front glass gasket covers the edge of the vinyl.
Re: Vinyl top installer [Re: ruderunner] #2961512
09/06/21 10:59 AM
09/06/21 10:59 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Quote
I recently had my 69 Charger done. The glass was out so it helped make it go easier. The front molded rubber seal is not in the way if you needed to do it with the glass in.
Re: Vinyl top installer [Re: Kevin E] #2963701
09/13/21 04:29 PM
09/13/21 04:29 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I just installed a vinyl top on my 70 Challenger. When I bought it from Legendary they told me it was the hardest top to install, they were right.
The previous top someone cut the top below the back glass to get it to fit.
I found that if you glue the area below the rear glass to the body line above the back glass before you do the c-pillars it makes a easier.
As was said it is very important to center the vinyl top to the roof and a heat gun helps. Also don't try to do it yourself.
Good luck!
Re: Vinyl top installer [Re: RTSE4ME] #2963797
09/13/21 08:38 PM
09/13/21 08:38 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up beer
Re: Vinyl top installer [Re: TJP] #2964079
09/14/21 04:39 PM
09/14/21 04:39 PM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
Try Executive Motors in Gibsonia.
Re: Vinyl top installer [Re: Kevin E] #2964626
09/16/21 08:13 AM
09/16/21 08:13 AM
OH
Red383 Offline
Red383  Offline
OH
Re: Vinyl top installer [Re: Red383] #2965783
09/20/21 03:02 PM
09/20/21 03:02 PM
McMurray PA
K
Kevin E Offline OP
Kevin E  Offline OP
K
McMurray PA
Thanks for the archive article, very detailed. But I actually found someone in Bethel Park Pa to install it. Specialized Auto Interiors, guy named Rick.
I will post some pics when he completes it.
Kevin
