Fuel in oil. #2962976
09/11/21 01:47 PM
09/11/21 01:47 PM
Red Deer, Alberta
Greenwood Offline OP
Red Deer, Alberta
With maybe 15 passes on it, the oil in my heap is pretty murky looking and has a distinct smell of gas. Is this a sign that I might still be way rich (76 primary, 84 secondary in a 780), or am I finally to a point where there's enough blow-by that I just really need to plan for a tear down? Compression is great 205-215 psi cranking pressure, cold.
Re: Fuel in oil. [Re: Greenwood] #2962992
09/11/21 02:21 PM
09/11/21 02:21 PM
Out of the State of Confusion
blue_stocker Offline
If you're concerned about compression, do a leak-down test and check your fuel system, especially if you have one of the cheap fuel regulators. I had one that had a leaky diaphragm that ended up with approx 1 qrt of race fuel in my crankcase. The day before going to a test session I had a very hard start and even though I kept smelling gas, I hadn't done basic inspection (look down the throttle bores with the electric pump running) and almost hydrauliced (sic?) a cylinder. The next day I noticed bubbles coming out of the front corner of the oil pan (crankcase pressure) and oil on the trailer deck! So much for that test session, back to the shop! The following day I drained the oil and noticed not only the strong odor of fuel but it was also diluted with gas in the oil pan; glad I didn't make any passes on that fresh engine! Needless to say, I pulled the engine and discovered washed bearings, scuffed cylinder walls but saved myself a big bill from catastrophic engine failure...it's always the little things. Not saying anything about your situation other than, make sure of what you do know so it doesn't bite you!
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: Fuel in oil. [Re: Greenwood] #2963005
09/11/21 03:03 PM
09/11/21 03:03 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The jetting seems kinda big for a 780 Holley.
If you have a mechanical pump, I’d could have a diaphragm that’s failing and letting fuel pass through it.
If electric, what’s the pressure set at?
Re: Fuel in oil. [Re: fast68plymouth] #2963068
09/11/21 07:02 PM
09/11/21 07:02 PM
Red Deer, Alberta
Red Deer, Alberta
Electric pump. 7-8 psi.
Re: Fuel in oil. [Re: Greenwood] #2963082
09/11/21 07:37 PM
09/11/21 07:37 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Drop it to 5.5 to 6psi.
Secondaries seem too rich. Check your #5;6,7,8 plugs
Re: Fuel in oil. [Re: Greenwood] #2963147
09/12/21 01:00 AM
09/12/21 01:00 AM
You would have to have a massive issue in the motor for unburnt liquid fuel to get in the oil from the intake system twocents work scope
Re: Fuel in oil. [Re: Cab_Burge] #2963152
09/12/21 01:57 AM
09/12/21 01:57 AM
Red Deer, Alberta
Red Deer, Alberta
I don't have a power valve on the secondaries, hence the staggered jetting. I think I'll drop two more, and see if anything happens. Cab, are you thinking just regular blow-by? I haven't leak-downed this thing in a while. Last time it was around 8%, and that was probably 60-70 passes ago.
Re: Fuel in oil. [Re: Cab_Burge] #2963187
09/12/21 10:11 AM
09/12/21 10:11 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
x2
Re: Fuel in oil. [Re: HardcoreB] #2963489
09/13/21 07:05 AM
09/13/21 07:05 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Check your float levels in the carb. If too high it will continue to dump fuel into the intake after shutoff.
Re: Fuel in oil. [Re: maximus] #2963525
09/13/21 09:51 AM
09/13/21 09:51 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Also check needles and seats. Turn on fuel pump with engine off and look down carb to see if there's any dripping. After you shut engine off after a pass there is still pressure in the fuel line, it will drip quite a lot of gas into your engine. Gas drips into intake and then finds an open valve.
