928 ways to lose at bracket racing #2962956
09/11/21 01:18 PM
09/11/21 01:18 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
When your opponent loses his harmonic balancer, it hits your car .. starter thinks it comes off your car and shuts you off at the line ..
I have more, add yours
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 928 ways to lose at bracket racing [Re: bigdad] #2962963
09/11/21 01:36 PM
09/11/21 01:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Generally speaking for me of late it just requires unloading the car. Its all downhill from there boogie
Re: 928 ways to lose at bracket racing [Re: Al_Alguire] #2962970
09/11/21 01:42 PM
09/11/21 01:42 PM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
Opponent forgets to turn on his fuel pump, and his car noses down at the 1/8th, but you run it out the back and break out by .01.
Re: 928 ways to lose at bracket racing [Re: Al_Alguire] #2962973
09/11/21 01:46 PM
09/11/21 01:46 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
My theory is to over build for the power produced, figuring that it would take some time to break or need to repair something. Always something small needs attention with that theory. I had a 2nd hand 340 Dart with 10K miles when I got it. That car lasted the best with little issues other than normal maintenance. Is there some sweet spot that exists?
Re: 928 ways to lose at bracket racing [Re: A/MP] #2962986
09/11/21 02:06 PM
09/11/21 02:06 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Went to the Twin 10K race at 41 last year. Ran the Blind Squirrel race Friday night, car ran great. Unloaded Saturday morning and warmed the car up. Get the call for our only time shot and head to staging. Shut the car of and get my belts and helmet on. Fire the car to pull up and the trans now has all neutrals. Broke the lugs off the pump gear.
Hoping for better luck this year.
Re: 928 ways to lose at bracket racing [Re: bigdad] #2963002
09/11/21 02:50 PM
09/11/21 02:50 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Neutral safety switch harness boot got hard, and would wiggle loose. I added a ground wire while waiting for the replacement harness. Got the call for my round, car won’t crank. I use the aforementioned external ground, and cranked the car reaching in from the outside. Oops, neutral wiring is fine, THE CAR WAS IN GEAR. Fortunately, it only went driverless for 10 feet and didn’t hit anything.
Re: 928 ways to lose at bracket racing [Re: bigdad] #2963003
09/11/21 02:55 PM
09/11/21 02:55 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Racing Bruce Kaul. 1/8th mile, CFR. I’m dialed 6.50 or so, Bruce 4.90 or so. Tree flashes, I react, What? Bruce is launching almost right with me? Morel of the story, check the crossover more closely.
Re: 928 ways to lose at bracket racing [Re: bigdad] #2963004
09/11/21 03:01 PM
09/11/21 03:01 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
2016. Hadn’t been racing in several years. The Dark Ages. Having a great time, even being a Duck. Until, tree flashes, let go of the button. WHAT? The steering wheel is loose in my hands? Morel of story: Double check the removable steering wheel lock more carefully.
Re: 928 ways to lose at bracket racing [Re: Leigh] #2963009
09/11/21 03:22 PM
09/11/21 03:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Broke the throttle pedal at the hit, factory pedal. Broke the throttle cable attachment at the carb, 2 different cars. Blabbing in a friends trailer, missed the call.
doug
Re: 928 ways to lose at bracket racing [Re: dvw] #2963066
09/11/21 06:55 PM
09/11/21 06:55 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Used to run Ram puck style disc and came out of the water a little hot and a piece of the sintered bronze disc jammed between the plate and disc. Car stuck in gear and no clutch pedal. Had to abort start and lost going into third round after having near perfect runs in the first 2 rounds. realmad Stopped using a Ram puck style disc twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: 928 ways to lose at bracket racing [Re: bigdad] #2963071
09/11/21 07:11 PM
09/11/21 07:11 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Twice in one weekend in Ohio...missed a dial in board error, and next day misread my TT ticket and dialed a tenth off.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 928 ways to lose at bracket racing [Re: A39Coronet] #2963105
09/11/21 08:47 PM
09/11/21 08:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Not me but a good friend of mine has run out of the gas in the final more than once!
68 Barracuda Formula S 340
Re: 928 ways to lose at bracket racing [Re: Bad340fish] #2963134
09/11/21 11:16 PM
09/11/21 11:16 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
red light ....... .0004 4th number
Re: 928 ways to lose at bracket racing [Re: bigdad] #2963135
09/11/21 11:16 PM
09/11/21 11:16 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Final for a $2,000.00 purse. My opponent's car would not start when it cam time to do the burn out. So being the sportsman, I told his pit crew to get it going, they jumped it and it fired. I reached up and hit my start switch, Click , click, The guy shrugged his shoulders and pulled into the burnout box.
Re: 928 ways to lose at bracket racing [Re: jwb123] #2963141
09/12/21 12:37 AM
09/12/21 12:37 AM
A727Tflite Offline
A727Tflite  Offline
Seen this happen way too many times. Nice guys always seem to take it in the shorts. But when it works to your favor you can stand even taller.
Re: 928 ways to lose at bracket racing [Re: A727Tflite] #2963532
09/13/21 10:18 AM
09/13/21 10:18 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Happened to a buddy of mine: R is for reverse, not Race...... lol
Re: 928 ways to lose at bracket racing [Re: bigdad] #2963537
09/13/21 10:37 AM
09/13/21 10:37 AM
Out of the State of Confusion
blue_stocker Offline
How about...having gone 3 rounds at Pomona in class eliminations, meeting up with the slowest car in the class and having him covered by +.3, cut the light and have him by a car length at the tree and pulling only to shift into 4th and have the rear u-joint fail and roll the drive shaft...he passes at the 1st mph light and BING, you lost! That being the pits, same car goes into the finals for an Eliminator runner-up...GRRR!!!! Hahaha, that's racing!
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: 928 ways to lose at bracket racing [Re: Cuda340] #2963542
09/13/21 10:44 AM
09/13/21 10:44 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Stand the car up on the rear bumper for 300 feet 'til the carb hiccups.
(Early 2nd gear swat to calm it down was a mixed-result tactic.)
Won the popularity contest, though.
Years earlier, humiliated myself by getting distracted & rolled the beams.
Basically a rear-wheel stage, sure didn't feel right, starter's expression as he looked in my window is unforgettable.
Fixed it but deserved to lose, and did.
Re: 928 ways to lose at bracket racing [Re: topside] #2963546
09/13/21 10:53 AM
09/13/21 10:53 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Just recently I ran a young man in a 7.30 car and mine is 6.50. He had a better light but did a whomp-whomp at the finish line, while I kept my foot down and took the stripe by .006. He bought back I I went over to talk to him, told him I've done the same thing and worse but we keep trying.
Re: 928 ways to lose at bracket racing [Re: bigdad] #2963583
09/13/21 12:23 PM
09/13/21 12:23 PM
Cab_Burge Online work
Cab_Burge  Online Work
I am sure there are closer to 10,000 ways to lose a drag race whistling
I'm up to # 8999,, I think whistling whiney shruggy
