I had a few issues with the clutch on my 71 RR 383-bench-4spd. When I purchased car, it was converted to an automatic and I had to round up all the parts to put it back to 4-speed. 69-RR transmission/bell housing, new clutch pedals, new NAPA 10.5" Diaphram clutch, z-bar, etc, etc. Clutch was working great, then later it was binding up and barely working. Could not get it to adjust, etc. Car is not 100% completed, but is up and running, mobile, so been working on it off and on along with other projects.
Finally got it up in the air and noticed that 1 side of the fork was not fully seated on the TO-bearing. After removing fork, it appears that the pivot bracket appeared to be slightly bent in a manner that moved the fork away from center of TO-bearing. I took it out and squared it back up, reinstalled and now the fork fits like a glove. But, now, the adjustment rod is kind of at a weird angle that the retaining clip won't go on.
So, I was wondering if there was a big block/small block clutch fork? If so, what are the lengths?
Currently, I have an NOS mopar one and from what I'm finding, there was only one for big/small block. But going to classic industries, they have a 10 7/8" one that fits both big & small block (CP7021), then they also list a big-block only, MD2515, with no length listed.
Also, to I need to lose the over-center spring on the NAPA diaphragm clutch? It was working fine before the fork/TO-bearing alignment problem started. The directions are long gone on the clutch installation.
Greatly appreciate any help.
Chris
