Rear seat/trunk divider Jute padding #2962243
09/08/21 05:31 PM
09/08/21 05:31 PM
South San Francisco, Ca
70sixpkrt Offline OP
I'm going to put some jute padding on my trunk divider and wondering if it would put a lot of weight on the flimsy cardboard. Has anybody reinforced the cardboard part that goes over the hooks?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Rear seat/trunk divider Jute padding [Re: 70sixpkrt] #2962365
09/09/21 12:53 AM
09/09/21 12:53 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Try light weight insulating bubble wrap from Lowe's or Home Depot, and see if you like it better than jute. Or replace the flimsy cardboard with press board.
Re: Rear seat/trunk divider Jute padding [Re: 70sixpkrt] #2962445
09/09/21 11:37 AM
09/09/21 11:37 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
The factory chipboard is pretty substantial at .110" thick (like my products). Some other reproduction are pretty rickety. Probably to make them easier to ship.
The factory never installed a shoddy material on those but I make our trunk dividers with or without it. And they are substantial enough to support the extra 1-1/2 lbs of material.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Rear seat/trunk divider Jute padding [Re: 71TA] #2962484
09/09/21 01:28 PM
09/09/21 01:28 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
And put it on the inside so you don't see it from the trunk.
Re: Rear seat/trunk divider Jute padding [Re: burdar] #2962527
09/09/21 03:48 PM
09/09/21 03:48 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ive done several using fatmat ( seat side ) with no issues .
So go for it.
