EXHAUST HEADER PAINT #2961718
09/06/21 10:12 PM
09/06/21 10:12 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
What's the best brand to use for lasting results. Thanks
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: EXHAUST HEADER PAINT [Re: Magnumguy] #2961744
09/07/21 01:43 AM
09/07/21 01:43 AM
Wood stove paint, not header paint twocents
That or have them ceramic coated by a good shop scope
Re: EXHAUST HEADER PAINT [Re: Magnumguy] #2961753
09/07/21 05:20 AM
09/07/21 05:20 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I have great, long lasting results using VHT High-Temp paint. Great stuff and it touches up nicely.
Re: EXHAUST HEADER PAINT [Re: jbc426] #2961760
09/07/21 06:46 AM
09/07/21 06:46 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I used all kind of stuff over the years and nothing last's. Ceramic coat is the way to go.
Re: EXHAUST HEADER PAINT [Re: Magnumguy] #2961769
09/07/21 07:51 AM
09/07/21 07:51 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Like the others who commented already, the ceramic coating I did on mine (done by a speciality shop, not myself) lasted a good 10 yrs of seasonal driving only (summer time) and came out with no rust on them. Mind you, the coating did start to form into these 'crystal like' flakes where eventually it would peel off in that spot, but that's what I noticed just this year having take them off, and these areas were limitted to just a few spots.
So all in all, I was very happy to see how these lasted. Basically I think I could bring them back to the same shop who will put them through a complete pain strip process first and get them re-coated.
Re: EXHAUST HEADER PAINT [Re: Diplomat360] #2961821
09/07/21 11:27 AM
09/07/21 11:27 AM
lino lakes, mn
Schultz62 Offline
Schultz62  Offline
lino lakes, mn
I used flat black paint for outdoor grills. Cheap and easy to touch up. Never experienced any problems. Drove my Dart with those headers for years.(yes a couple of times in rain coming back from shows) No fuss. No muss.
Re: EXHAUST HEADER PAINT [Re: Magnumguy] #2961835
09/07/21 12:10 PM
09/07/21 12:10 PM
WV,USA
W
wvmarv Offline
wvmarv  Offline
W
WV,USA
https://www.kbs-coatings.com/xtc.html
XTC - High Temperature Paint - Header Paint - Stove Paint - Grill Paint - BBQ Paint
160 Reviews +Write a Review
XTC is a high temperature/heat resistant coating formulated specifically to protect metal surfaces operating at temperatures from 500° F to 1500° F. With proper preparation, XTC provides outstanding adhesion, film integrity, weathering, and thermal shock-resistance throughout this entire temperature range, and is guaranteed not to burn off! Available in 10 great colors.
Re: EXHAUST HEADER PAINT [Re: wvmarv] #2961851
09/07/21 12:59 PM
09/07/21 12:59 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Sandblasted and painted with BBQ black paint. Works really well and still lasting 7-ish years later.
'63 Dodge 330
11.19 @ 121 mph
Re: EXHAUST HEADER PAINT [Re: Magnumguy] #2961873
09/07/21 01:45 PM
09/07/21 01:45 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
Have not used on headers, but have used on cast iron manifolds with success.
https://www.walmart.com/ip/Black-Ru...e-Enamel-Flat-Spray-Paint-12-Oz/17203457
Unlikely you can do this curing in an oven with larger headers, but I did the 3 step curing in an oven. Has held up well.
Says flat black, but almost has a dark cast iron appearance.
I have Jet Hot coated manifold and sadly they rusted after a few seasons, so tried this on my next build.
Re: EXHAUST HEADER PAINT [Re: njmopar] #2961916
09/07/21 04:22 PM
09/07/21 04:22 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I had pretty good luck with the Seymour "Cast Blast" high temp stuff. Smells a little as it bakes on on the first couple of runs, but ok after that. I tried the silver Eastwood brush on stuff too but I thought the Seymour spray bomb actually lasted longer.
Re: EXHAUST HEADER PAINT [Re: 440newport] #2961933
09/07/21 05:32 PM
09/07/21 05:32 PM
PA
moparacer Offline
moparacer  Offline
PA
VHT is what worked best for me over the years.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: EXHAUST HEADER PAINT [Re: moparacer] #2962014
09/07/21 09:14 PM
09/07/21 09:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
X3 been using it for over 40 years. The only Ceramic coating I have seen that is even comparable is Jet hot coatings, everything else is over priced short term cr-p. Believe me I have seen a lot of it on customers cars twocents
Re: EXHAUST HEADER PAINT [Re: moparacer] #2962018
09/07/21 09:24 PM
09/07/21 09:24 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
The is my go to high heat paint as well.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: EXHAUST HEADER PAINT [Re: Magnumguy] #2962103
09/08/21 09:26 AM
09/08/21 09:26 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I've never found a paint that will last for very long on headers. Even the apply at home thermal coating I tried only lasted a few years before it eventually cooked off. I've always been very diligent about prep work too. Tried sandblasting, bead blasting, cleaning with alcohol, cleaning with lacquer thinner, cleaning with acetone. I've tried VHT, BBQ, and other high temp paints. I'll also add that my engines have tended to be at the higher end of the compression spectrum and tend to produce some very high exhaust temps. Whether that is a factor or not, I'm not sure.
Re: EXHAUST HEADER PAINT [Re: Magnumguy] #2962896
09/11/21 10:49 AM
09/11/21 10:49 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
VHT works pretty well but you do have to follow the instructions, I have use grill paint also. works, the key is to get all the factory paint off, get them very clean, then apply the new paint.
Coming soon!!!!
Re: EXHAUST HEADER PAINT [Re: Mr.Yuck] #2962908
09/11/21 11:17 AM
09/11/21 11:17 AM
moparx Offline
moparx  Offline
can nickel plated headers be blasted and painted, or does the plating need removed first ?
beer
Re: EXHAUST HEADER PAINT [Re: moparx] #2962909
09/11/21 11:24 AM
09/11/21 11:24 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
I would say it depends on
1. If the plating is completely intact
2. Do not get overly aggressive with the blasting, just roughen the surface. If you break through the plating it may lead to future peeling.
twocents beer
Re: EXHAUST HEADER PAINT [Re: TJP] #2962920
09/11/21 11:53 AM
09/11/21 11:53 AM
moparx Offline
moparx  Offline
i have a set of 2" to 2 1/8" stepped TTI's that have several [caveman] damaged tubes that need repaired.
the plating seems to be intact, so after i section in the repair pieces, i planned on painting them.
thanks for the advice. up
beer
Re: EXHAUST HEADER PAINT [Re: 340SIX] #2962940
09/11/21 12:34 PM
09/11/21 12:34 PM
Md.
carnut68 Online content
carnut68  Online Content
Md.
VHT for me. 7 years still look good.
America First!
Re: EXHAUST HEADER PAINT [Re: carnut68] #2963251
09/12/21 02:05 PM
09/12/21 02:05 PM
lino lakes, mn
Schultz62 Offline
Schultz62  Offline
lino lakes, mn
TC@HP2 I believe you may be on to something as my engines using headers with flat black grill paint were at 9:1 or so. They did burn a bit when first running the engine in and tuning. I just masked off a little and resprayed up top. As far as cleanliness in preparation...probably not the best. Just hit the already used headers with a scotchbrite green pad and wiped off with acetone before spraying. shruggy
Never had any high compression motors using my header method.
