like I said...hickabilly a early chevy q-jet by tac welding the mopar throttle lever on to it
got a new reman one for a chivy truck fer 120$
should be able to find a chivy in a jy,IMO
I am with RR... what did we miss?,,,try another known good carb
I can send you one that needs a throttle lever for it but its a non emisions carb from a 350 inbaord mercruzer
I grab em off caddy's,pontiac's,chivy's and look for mid 80s dodge carbs for the lever and KD linkage
![](/ubbthreads/images/graemlins/scope.gif)
I just grab the lever and jets/needles out of the dodge ones,swap them into the chivy one and its pretty close on the meetering/jetting for a 318/360
the u-pull it here is full of the 40$ with a 10$ core charge
keep looking
![](/ubbthreads/images/graemlins/popcrn.gif)
