Side exit exhaust tips. I need sound advice... Ha ha! #2961225
09/05/21 12:29 PM
09/05/21 12:29 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Sorry for the bad pun. I want to put those long flat nascar style exhaust tips in front of my rear tires. Does anyone with that kind of system, become annoyed by the sound with your windows down? I plan on using Magnaflow 14210 mufflers, because they have the inlet and outlet, like on AAR 'Cuda factory mufflers. Thanks!
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: Hooligan] #2961313
09/05/21 06:37 PM
09/05/21 06:37 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Not sure about 'flat' exhaust tubing, but when the car had fenderwell headers the 3" round exhaust ran along the frame and exited in font of the rears.. it would annoy other drivers, but it wasn't too loud and sounded great to me, especially when going through underpasses.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: jughed] #2961338
09/05/21 07:45 PM
09/05/21 07:45 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Dr Gas sells those as exhaust tips and also versions that are mufflers too.
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: jughed] #2961423
09/05/21 10:43 PM
09/05/21 10:43 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
"Annoy other drivers" So funny! Thanks!
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: Neil] #2961424
09/05/21 10:44 PM
09/05/21 10:44 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Cool. I'll check it out. Thanks!
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: Hooligan] #2961784
09/07/21 08:59 AM
09/07/21 08:59 AM
scratchnfotraction Offline
on my stepside I just put on new pipes and magna flow muffs.
I have headers and used 2.5 pipe *about 3' no bends, hang muffs, and about 3'-3.5' nice sweeping 90* bend/no kinks and both tail pipes are right inline under the bed step brace & edge on fender. would be just right for mounting a set of LRE stacks & all tucked up above the lower frame rails. so no ground clearance issues.
give u a looky see when we catch up again.
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: scratchnfotraction] #2961954
09/07/21 06:28 PM
09/07/21 06:28 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Hey Scratch! I would take a ride in your step side to give your exhaust systemt a listen, but I'm still carrying the emotional scars from when you almost killed me in your Jeep! LOL
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: Hooligan] #2961960
09/07/21 06:34 PM
09/07/21 06:34 PM
I think they are commonly refer to as "Boom Tubes" scope
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: Cab_Burge] #2962436
09/09/21 11:06 AM
09/09/21 11:06 AM
lino lakes, mn
Schultz62 Offline
Schultz62  Offline
lino lakes, mn
Not flat per se but oval exhaust tubing is available. Can most likely use it after the mufflers then out the side before the rear tires. Bologna slice it to match the 1/4 panel angle. I hear you on annoying the 'others' as my old Dart had 3in exhaust with turn downs blowing outward slightly before the rear axle. Lots of dust and drumming on the ground. Loud yes as it set off car alarms but useful when a minivan etc tries to merge into the side of your car.
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: Schultz62] #2962608
09/09/21 10:00 PM
09/09/21 10:00 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Well, I ordered the Boom tubes, and a set of custom 18x8 aluminum wheels. Here's what the beast looks like now...
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: Hooligan] #2962617
09/09/21 10:13 PM
09/09/21 10:13 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Cool short bed. up
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: Neil] #2962629
09/09/21 11:19 PM
09/09/21 11:19 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Nice truck. I assume it's a newer model with an older grill? Was the grill a direct bolt-on?
Post a video when you get the boom tubes on. A guy that used to be on E-bodies.org had them on his 3gen hemi Cuda. They sounded really good.
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: Hooligan] #2962638
09/10/21 02:42 AM
09/10/21 02:42 AM
I like your innovating that air cleaner up
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: Neil] #2962672
09/10/21 10:24 AM
09/10/21 10:24 AM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Cool short bed. up
Thanks! However, the tires won't stay cool, because it does burnouts with ease!
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: burdar] #2962675
09/10/21 10:37 AM
09/10/21 10:37 AM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Well, I bought the truck just as you see it here. It's a 1974, and I think that is the correct grille. It's only my 3rd Mopar truck. I had a 1981 D150 Midnite Express clone, and a 1989 Ram D50... which really doesn't count, because it is a Mitsubishi.
Those stacks with Are Chamber mufflers on the '81 sounded great... even with the slant 6. I planned on doing a swap to a 360, but I sold the truck
I will try doing a video, but I never did a video before.
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: Cab_Burge] #2962682
09/10/21 10:54 AM
09/10/21 10:54 AM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
I can't take credit for the air cleaner. I bought the truck this week just as you see it. I love building custom Mopars! Soon, I will post build threads on my other 3 Mopar builds. Here's a sneak peak. '72 Satellite, 360 6-barrel, 5 speed. '69 Super Bee Gasser. 6-71 supercharged 426 Hemi, 4 speed, straight axle front end. '73 Charger, 400, 5 speed, with a Weber carbureted 6-pack, and hood mounted air cleaner.
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: burdar] #2962684
09/10/21 10:57 AM
09/10/21 10:57 AM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: Hooligan] #2962727
09/10/21 02:37 PM
09/10/21 02:37 PM
lino lakes, mn
Schultz62 Offline
Schultz62  Offline
lino lakes, mn
Holy hell Hooligan you have some great cars. Also the truck is super cool. When I responded I thought you were talking car. Now that I see your truck I still believe oval exhaust before each rear tire.
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: Schultz62] #2963023
09/11/21 04:40 PM
09/11/21 04:40 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Boom tubes came today. Freakin" awesome! Some guy on eBay, making them in his home shop! Not junk made in Chi-land.
Mounted in front of the rear tire just the way you like it!
Re: Side exit exhaust tips. I need sound advice... Ha ha! [Re: Hooligan] #2963030
09/11/21 05:03 PM
09/11/21 05:03 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Wheels and tires arrived too. I'm speechless! 18x8 with 4.5" back spacing. I ordered 3-bar spinners. (not here yet) Gotta have spinners! Tires are 255/45/18. All will fit perfecto, like I hoped for!
