Re: Which front tires delema
[Re: Dragula]
#2959746
08/31/21 11:19 PM
08/31/21 11:19 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
most would recommend radial front and rear . I guess some of that will depend on your mph and the tyre speed rating . I have seen those MT SR fronts go out of round/ delaminate . Not a big fan of them . I use street radial tyres front though i think a little shorter than yours ,28"? Mine are 185/80R15 also 185R15 (26.7") waiting on the shelf . I am only going 131ish mph max . http://www.tarziatyrecentre.com.au/nankang-retro-rc-001-185r15-93h-new-classic-tyre-1 These are i think the old Michelin mould . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2959799
09/01/21 08:01 AM
09/01/21 08:01 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Eventually I plan on trying the 28" tall M/T SR Radials. Simply b/c they are the only 28" tall and skinny radial front I know of. I have M/T Sportsmans up front and they suck as far as street driving goes. It drives so much better w/ a pair of 165R15 radials up front, but they're too short. If I wanted a 25"-26" tall tire, I'd just use a 165R15.
FWIW...I've driven my car w/ every possible combination of radials and bias tires on it. Mixing them is not a problem in my opinion. The bias tires just wander and hunt ruts.
[Re: 69ACME]
#2959811
09/01/21 08:58 AM
09/01/21 08:58 AM
Posts: 12,408 Taxes & Virus's R-US, NY
Dragula
I would love to hear an explanation as to how putting a front tire (radial) that tracks straighter going to make a car more unstable because it has a bias ply on the back. I can see why a rear radial/front bias isn't a good match. But the conventional wisdom of never mix radials with bias never seems to come with any evidence or explanation. I did this once before on one of my street cars.....Spun it 720 after hitting one of those rubber bridge gap things as the radials and bias tires do not react the same to side loads, and they made the car unstable at thruway speeds. This was back in 1988 on my 73 Cuda... So I am leery of doing this on my prostreet car, but I think they will improve how it drives.
[Re: Dragula]
#2959855
09/01/21 11:07 AM
09/01/21 11:07 AM
Triple Threat
Renton Washington
I have the 27" ET Street Front Radial and 29.5x10.5W Bias Plys on my dart.
Went 9.84@135 last weekend, drives fine.
[Re: Triple Threat]
#2959857
09/01/21 11:10 AM
09/01/21 11:10 AM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
I have bias Hoosier front runners, and Hoosier 275 radials on the rear of my street strip Dart. Had zero issues driving and racing it regards mixing tires
[Re: B3422W5]
#2959866
09/01/21 11:36 AM
09/01/21 11:36 AM
Posts: 4,694 Wichita
GY3
Wichita
We put the SR's on the front of the '63 last year and it drives great! We had some old Nexen's volkswagen sized tires that were way too small and not speed rated for what we were doing. ET Street Pro radials on the back and it is smooth as can be!
I tried a friend's Moroso's on the front a few years ago and they drove like dogshit on the street AND at the strip!
[Re: GY3]
#2959912
09/01/21 01:37 PM
09/01/21 01:37 PM
Posts: 19,548 north of coder
moparx
i have ran just about any combination of rear tires and rear rim widths, and skinny VW radials on the front [165 and 145 size "shorties"], with both independent front suspension and straight axle setups with ford single buggy spring and parallel leaf spring setups. as long as you have some decent caster, and the toe in matches how the steering is set up [front steer or rear steer], radials on the front work great ! bias ply tires ALWAYS seem to hunt for ruts no matter what size or width you use, although there are a lot of guys who will say otherwise. i'm not bashing them, however. i'm just stating my own experience over the 50+ years i have been "playing with cars". now with that said, there was ONE time i REALLY liked the way a bias tire worked on the front of a vehicle. that was on my charger back in the 72-74 [or so] time frame, and on my 48 plymouth sedan in the 76ish-79 time frame, when i was running Formula One Super Stock bias tires. i had L-60's and M-50's on the rear with 8 & 10" wheels, and F-60's on the front with 6" wheels. those cornered and went down the road GREAT ! however, i don't recall what the alignment specs were i used at that time. as i said, this is just my personal experience. your mileage will vary.
[Re: Stanton]
#2960022
09/01/21 05:32 PM
09/01/21 05:32 PM
GY3
Wichita
28" Tall https://www.summitracing.com/parts/mtt-6678Yeah but those things are really too skinny for the street and they look stupid on anything like a B-body. I'm always afraid they'll roll off the rim if you were to take a corner at anything over 10 mph !! Not that bad on a B-body.
[Re: GY3]
#2960126
09/01/21 09:16 PM
09/01/21 09:16 PM
tex013
Sydney,Australia
[Re: Stanton]
#2960223
09/02/21 08:27 AM
09/02/21 08:27 AM
Dragula
28" Tall https://www.summitracing.com/parts/mtt-6678Yeah but those things are really too skinny for the street and they look stupid on anything like a B-body. I'm always afraid they'll roll off the rim if you were to take a corner at anything over 10 mph !! Just ordered a set....So we will try the radials. New 5" wide Holeshot wheels should be here early next week.. The other tires have never had good street manners, so any improvement.
