Re: Needing help picking out fuel lines for my Fi Set up
[Re: 70RT Charger]
#2959507
08/31/21 02:09 PM
08/31/21 02:09 PM
Posts: 269 Anchorage, Alaska
metallicareload
Anchorage, Alaska
I don't know how much power you plan on making (or E85?)? I use my old stainless steel 3/8" feed line as a return line, I bent a new feed line out of regular 3/8" steel tube. Has worked well with my fuel injection with an intank pump
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: 70RT Charger]
#2959508
08/31/21 02:10 PM
08/31/21 02:10 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
You can use the factory line for most of it. Cut off the flared ends and use a -6 a/n adapter (uses a crush type internal collet). Or just weld on the fittings.
I prefer to use teflon hose for the flexible connections as you don't get any fuel vapor smell from it. (and generally smaller outer diameter and looks nicer, in my opinion)
[Re: 70RT Charger]
#2959567
08/31/21 04:01 PM
08/31/21 04:01 PM
Posts: 8,164 Plymouth, MI
Blusmbl
Plymouth, MI
That 350 lph drop in pump is brand new, I think it's only been out a month or so. Previously the options were a 255 lph drop in pump, or the 400 lph module that also requires the fuel tank to be modified or a replacement tank installed with that sending unit interface on it.
[Re: 70RT Charger]
#2959577
08/31/21 04:30 PM
08/31/21 04:30 PM
Posts: 4,206 New York
polyspheric
New York
The higher the tank-mounted pump pressure (modern factory FI is 43.5 psi, or 3 bar), the smaller the feed line can be. As pressure increases, flow through a fixed line ID increases as the square root of the change. Double the psi raises the flow by 41% (2^.5 = 1.414).
Boffin Emeritus
[Re: AndyF]
#2959625
08/31/21 06:21 PM
08/31/21 06:21 PM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
I ordered an EFi tank with the pump already installed from Holley, all from FASTMAN.I emailed Richard about the 350 pump, waiting for a reply. He sent me this regulator https://www.holley.com/products/fue...lters/filters/efi_filters/parts/162-554. I’m a newb when it comes to EFi but if this 350 pump will work it will save me a lot of work. If there’s a reason he didn’t want me to use it that’s fine also.
[Re: 70RT Charger]
#2959663
08/31/21 07:43 PM
08/31/21 07:43 PM
Posts: 1,111 Usa
A39Coronet
Usa
I'll be running OE 3/8 SS line from the tank to engine compartment with E85 on my Barracuda. Hardline + limited restricted fittings, that's a ton of fuel you can move.
Holley has been coming out with a ton of good products lately, but that pump just looks so cheap I have a hard time getting over it. Love how it has everything compressed to one unit tho.
[Re: 70RT Charger]
#2959713
08/31/21 09:27 PM
08/31/21 09:27 PM
Posts: 2,856 Pattison Texas
CSK
Pattison Texas
Rich got back with me and he highly recommended me using a return line so I’m going with his advise. Thanks guys! I am a firm believer in a return set up from front to back, I also have found I had to insulate all my fuel lines & the pressure regulator from heat,if not it heats up the fuel in the tank, I drive my car a lot & its hot here in Southeast Tx , , I have the Tanks Inc 450lph pump & tank. I
[Re: CSK]
#2959794
09/01/21 07:31 AM
09/01/21 07:31 AM
70RT Charger
eastern,Ky
Rich got back with me and he highly recommended me using a return line so I’m going with his advise. Thanks guys! I am a firm believer in a return set up from front to back, I also have found I had to insulate all my fuel lines & the pressure regulator from heat,if not it heats up the fuel in the tank, I drive my car a lot & its hot here in Southeast Tx , , I have the Tanks Inc 450lph pump & tank. I What did you use to insulate the lines and regulator with?
[Re: A39Coronet]
#2959796
09/01/21 07:34 AM
09/01/21 07:34 AM
70RT Charger
eastern,Ky
Holley has been coming out with a ton of good products lately, but that pump just looks so cheap I have a hard time getting over it. Love how it has everything compressed to one unit tho. That’s the lines I’ll use and I’m going to use the pump that FASTMAN recommended.
[Re: CSK]
#2959809
09/01/21 08:46 AM
09/01/21 08:46 AM
INTMD8
Lake Villa Il
That is my preference as well. Regulating inside the tank works of course but doesn't compensate for any pressure drop across the feed line/fittings. So with in tank regulation, you can see pressure drop slightly with higher fuel demands even if it's within the normal capacity of the pump.
[Re: 80fbody]
#2959893
09/01/21 12:53 PM
09/01/21 12:53 PM
INTMD8
Lake Villa Il
I like the Goodridge 910 hose/fittings fwiw. Lots of flexibility and easy to work with.
[Re: INTMD8]
#2959894
09/01/21 12:53 PM
09/01/21 12:53 PM
70RT Charger
eastern,Ky
I prefer to use teflon hose for the flexible connections as you don't get any fuel vapor smell from it. (and generally smaller outer diameter and looks nicer, in my opinion) If you used the adapters and a return line could you tell me how many adapters you used?
[Re: 70RT Charger]
#2960200
09/02/21 05:14 AM
09/02/21 05:14 AM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
I used the factory style hard line, Hemi sized 3/8 supply and bought a regular BB/SB 5/16 line for the return and ran them side by side. I flared the factory line with the GM push-on style o-ring fittings and bought the appropriate adapters. For example Russell Performance 644133. AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
