Page 3 of 3 1 2 3
Re: Dyno Dissappointment [Re: Pacnorthcuda] #2959345
08/31/21 09:36 AM
08/31/21 09:36 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Originally Posted by Pacnorthcuda
Originally Posted by GTX MATT
Dyno results through an automatic can sometimes be misleading, especially with a higher stall converter. Some produce realistic results, some read super low.
That power may be dead on but we need more info because you’ve got a lot missing. Does the car feel strong to you? If you really want to know if it makes the power it should take it to the track and see what the trap speed is.
Why? The dyno is measuring power at the wheels, how it’s transmitted is irrelevant at that point.
I think the difference is, launching the car at the track as normal, you have max converter slip for a short time and it's coupled as close as it will be by the top of low gear.
Now take the same car and launch/make a pass in high gear. Would be a ton more slip/heat (resulting in less power to the tires) and to the same effect, would also show on a chassis dyno.
On cars with multi plate lockup converters, can often be a huge difference between locked and unlocked numbers.
Or, going from a less to more efficient converter with no other changes can result in much higher numbers with no other changes.
Re: Dyno Dissappointment [Re: INTMD8] #2959453
08/31/21 12:36 PM
08/31/21 12:36 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
“Dyno Disappointment”
Actually......... not at all uncommon.
Sort of similar to...... “first time at the track disappointment”
Re: Dyno Dissappointment [Re: INTMD8] #2959490
08/31/21 01:26 PM
08/31/21 01:26 PM
Originally Posted by INTMD8
[quote=Pacnorthcuda][quote=GTX MATT]Dyno results through an automatic can sometimes be misleading, especially with a higher stall converter. Some produce realistic results, some read super low.
Torque converters can make so much difference in the car performance that is is hard to believe until you test several different ones or see someone do that at the track.
the last converter swap I did was from a custom built 10 inch street and strip Contintental to a 8 inch SS Hemi Turbo action, that swap made my car pickup .2 ET in the 1/8 mile and gained 2.0 MPH shock scope
We've seen .8 ET gain and very little MPH loss going from a stock 11 inch street Hemi converter to a custom built 8 inch Rossi race converter in the 1/4 mile up
The bad side of different brands is also possible, GER were junk down The first 8 inch race converter we bought and used was a Art Carr 8 inch race converter for Hemi NHRA stocker, it would slow the car down 3.0+ MPH and .3 ET in the 1/4 mile from the stock 11 inch street Hemi converter whiney puke down
Page 3 of 3 1 2 3
