If I wanted to use a 3G in a '71 Duster..... #2959254
08/30/21 10:50 PM
08/30/21 10:50 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
.....And wanted to use a carburetor, what are the options for an intake manifold? How about ignition?
I'm guessing that motor mounts and headers are commonly available, right?
Not right away though. The car needs some work.....
Re: If I wanted to use a 3G in a '71 Duster..... [Re: Kern Dog] #2959290
08/31/21 04:59 AM
08/31/21 04:59 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Ignition options= MSD Hemi 6, FAST, and Mallory Firestorm if you can find one
Intake manifold= OCP, Indy ModMan, Ritter Dragpak style, MP/Edelbrock dual quad, Holley Hi-ram, and the early MP single 4 or XV Motorsports if you can find one
Re: If I wanted to use a 3G in a '71 Duster..... [Re: GTS340] #2959735
08/31/21 10:32 PM
08/31/21 10:32 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Weber makes carbed intakes, and I forget who makes the distributor based front plates...
Re: If I wanted to use a 3G in a '71 Duster..... [Re: Dragula] #2959753
09/01/21 12:01 AM
09/01/21 12:01 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Thanks!
I'd need an intake that would clear a stock hood. I remember hearing about the MSD spark controller but didn't know if it was a hybrid distributor or some electronic setup.
Re: If I wanted to use a 3G in a '71 Duster..... [Re: Kern Dog] #2959789
09/01/21 07:07 AM
09/01/21 07:07 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I read nothing but bad things about that Indy Modman.
Let me know if you're interested in the Edelbrock dual 4bbl setup, I have a brand new one in the box I'm not using. This one, along with the OCP unit is likely the only option for fitting under the hood.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: If I wanted to use a 3G in a '71 Duster..... [Re: GTS340] #2959804
09/01/21 08:31 AM
09/01/21 08:31 AM
USA
hudsonhornet7x Offline
USA
Never heard of the Mallory Firestorm before. I can't find much info about it. Will it work with the newer 58 tooth reluctor wheel?
Re: If I wanted to use a 3G in a '71 Duster..... [Re: hudsonhornet7x] #2959812
09/01/21 09:06 AM
09/01/21 09:06 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
No, early wheel only
Re: If I wanted to use a 3G in a '71 Duster..... [Re: GTS340] #2959840
09/01/21 10:06 AM
09/01/21 10:06 AM
USA
USA
Thank you
Re: If I wanted to use a 3G in a '71 Duster..... [Re: Dragula] #2960102
09/01/21 08:33 PM
09/01/21 08:33 PM
Augusta, GA
Lightning Offline
Lightning  Offline
Augusta, GA
Prefix bought Arrow's stuff a couple years or so ago.
https://store.prefix.com/products/arr-cas-1010-gen-3-hemi-non-efi-intake-manifold
https://store.prefix.com/products/hemi-front-distributor-kit
They make both that Nascar/Cascar intake and that front distributor. Wish they were cheaper though.
Re: If I wanted to use a 3G in a '71 Duster..... [Re: Lightning] #2960172
09/01/21 11:48 PM
09/01/21 11:48 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
HEMI Gen3 Front Distributor Kit
Regular price$1,670.00
This kit allows you to run your Gen3 5.7L / 6.1L HEMI without the need of expensive electronics.
"Without the need of expensive electronics" ??
No, instead you have an expensive adapter to run a distributor!
Re: If I wanted to use a 3G in a '71 Duster..... [Re: Lightning] #2960206
09/02/21 06:14 AM
09/02/21 06:14 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
The distributor kit is pricy but $575 for the intake is not. Very much inline with a lot of quality LS options and for the longest time they were unavailable.
Re: If I wanted to use a 3G in a '71 Duster..... [Re: Kern Dog] #2960222
09/02/21 08:26 AM
09/02/21 08:26 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I think your best choice would be the OCP ($679)intake with the MSD Hemi 6( $870 w/harness). The OCP is 4.9" tall so it should fit under stock hood. The owner is very helpful also. Remember the Hemi6 only works 32 tooth tone ring so if your engine is 09+ you need to swap out tone rings. Forget about the Prefix front distributor it was made to run CASCAR.
Depending what you have it might be a wash to go the FI route vs carb,
Re: If I wanted to use a 3G in a '71 Duster..... [Re: RTSE4ME] #2960505
09/03/21 01:17 AM
09/03/21 01:17 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I was thinking that....A stand alone harness to run the EFI and spark may be another route.
Re: If I wanted to use a 3G in a '71 Duster..... [Re: A39Coronet] #2960965
09/04/21 01:18 PM
09/04/21 01:18 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Got to buy an adapter to put oil in it though
Re: If I wanted to use a 3G in a '71 Duster..... [Re: Kern Dog] #2960979
09/04/21 02:47 PM
09/04/21 02:47 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
I pretty sure you have to go EFI to get it under the hood.....
If you haven't already... Check out the Crop Duster build..
>>>>> https://www.motortrend.com/features/gen-iii-hemi-swapped-1970-plymouth-duster/
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: If I wanted to use a 3G in a '71 Duster..... [Re: racerhog] #2961129
09/05/21 03:24 AM
09/05/21 03:24 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Thanks. That isn't the "Crop Duster" though.
Re: If I wanted to use a 3G in a '71 Duster..... [Re: HotRodDave] #2961155
09/05/21 08:14 AM
09/05/21 08:14 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Negative...pop the plate off and use a funnel... adapter is nice but not required.
