Re: ram - crap bolts and ex manifold warpage [Re: mopars4ever] #2959582
08/31/21 04:38 PM
08/31/21 04:38 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Stumpy has it right with going to headers, imo. Only have to worry about replaceable header gaskets going out beats warped iron manifolds in my book.
Re: ram - crap bolts and ex manifold warpage [Re: Neil] #2959610
08/31/21 05:34 PM
08/31/21 05:34 PM
md
mopars4ever Offline OP
md
I was also trying to find out the difference between these 2 double ended studs for the heat shield between 6509863AA and 6510141AA. The are both double ended studs for the heat shield. What locations do each of those part numbers belong? They are almost exactly the same length. I can`t imagine the length would even matter? I did notice that the nut portion of the stud looks more rounded off than the other one which has more sharp edges to the nut.
Re: ram - crap bolts and ex manifold warpage [Re: stumpy] #2959651
08/31/21 07:12 PM
08/31/21 07:12 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Originally Posted by stumpy
I had the same problem on two of my 5.7 trucks. I cured it by going to shorty headers.
I was going to write; it's a sign. time for headers grin
Facts are stubborn things.
Re: ram - crap bolts and ex manifold warpage [Re: larrymopar360] #2960140
09/01/21 09:55 PM
09/01/21 09:55 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
For those of you that installed headers, what brand did you go with? I found these listed on E-bay but never heard of them before. The price seems too good to be true. This is cheaper than 2 replacement manifolds on RockAuto. I've got 41k on my 14 Ram and so far so good. If it's going to cost significantly more money to extract broken studs when they break, it might be a good idea to put headers on it now.
https://www.ebay.com/itm/193066963098?
Re: ram - crap bolts and ex manifold warpage [Re: burdar] #2960161
09/01/21 10:55 PM
09/01/21 10:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Thats what I used and they worked fine. Sealed up with no leaks and were bolt up to the stock exhaust.
Re: ram - crap bolts and ex manifold warpage [Re: stumpy] #2960225
09/02/21 08:32 AM
09/02/21 08:32 AM
md
md
Ok, I found out a little more about those bolts that broke. Those two bolts were stainless while the rest were steel. I checked with a magnet. I`m now wondering if it would have been better to replace the stainless with the steel bolts.
