High RPM alternator #2958996
08/30/21 12:23 PM
08/30/21 12:23 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Is there a consensus on how fast the alternator should be allowed to spin ?
I know there are larger pulleys for the alternator.
Anyone ever have an alternator balanced ????
Re: High RPM alternator [Re: hemienvy] #2959019
08/30/21 01:23 PM
08/30/21 01:23 PM
AndyF Offline
AndyF  Offline
Powermaster racing alternators are rated to 21,000 rpm
Re: High RPM alternator [Re: AndyF] #2959039
08/30/21 02:27 PM
08/30/21 02:27 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Only needs to spin fast enough to maintain 13.5 - 14V or so. Why use the power and tear it up by zinging it up?
We used stock pulleys on the alternator with a small pulley on the crank. Worked fine. 13+ volts at less than 3K.
Re: High RPM alternator [Re: CMcAllister] #2959121
08/30/21 06:36 PM
08/30/21 06:36 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Andy thanks much for bringing that Powermaster to my attention.
I might be slowly putting a new plan together.
McAllister, I need to read more about this, I suspect there is some kind of
trade-off for the useful RPM range of the alternator. While I'm planning
I should get to know what kind of electrical loads I'll realistically need.
Re: High RPM alternator [Re: hemienvy] #2959209
08/30/21 09:38 PM
08/30/21 09:38 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Race car I assume.
We ran two batteries. Car was light to begin with, had mounts for two, just made sense. Not having to charge the batteries at the track (usually) was a nice side benefit to running an alternator. I did charge them up to 100% between weekends.
The main reason I ran an alternator was to keep the voltage consistent run to run, hoping that anything with a wire attached to it would also be consistent - ignition, timers, solenoids, etc.. Wasn't concerned about whether it was 13.7 or 14.7, just that it was the same every pass.
Re: High RPM alternator [Re: CMcAllister] #2959315
08/31/21 08:21 AM
08/31/21 08:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If its a small alternator you'll need to spin it to get any kind of charging at low rpm. My East Coast mini is at nearly 3-1 pulley ratio. The motor goes thru thru the lights at 7200-7300. Still struggles with both fans on driving in the pits.
Doug
Re: High RPM alternator [Re: dvw] #2959477
08/31/21 01:09 PM
08/31/21 01:09 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I used a one wire Delcotron. Not small, bit it worked. Carried parts for it and fixed it at the track as well on the rare occasion a diode trio or something failed.
I like stuff that works and is servicable in the field.
Re: High RPM alternator [Re: CMcAllister] #2959481
08/31/21 01:16 PM
08/31/21 01:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We have a GM style one wire onthe Vette and the engine sees 10,000 plus rpm every pass. We use a serpentine belt for the Alt and Vaccum pump
Re: High RPM alternator [Re: Al_Alguire] #2959511
08/31/21 02:15 PM
08/31/21 02:15 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Couple nutdrivers and a straw from a can of Brakleen and you can rebuild the whole thing at the track. shruggy
