Re: High RPM and V-belts
[Re: moparx]
#2959059
08/30/21 03:21 PM
08/30/21 03:21 PM
Posts: 5,159 CT
GTX MATT
CT
Run the shortest, skinniest belt you can.
[Re: lewtot184]
#2959082
08/30/21 04:37 PM
08/30/21 04:37 PM
Posts: 1,030 ohio
67mprfan
ohio
Following this topic because I'm actually having a issue with mine flying off,
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 4mopower]
#2959101
08/30/21 05:48 PM
08/30/21 05:48 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
i use March pulleys . Similar to Lew i have idler pulleys on the upper belt run , no drag and keep a slight tension as it helps wrap a little more on the alt/waterpump pulleys
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2959110
08/30/21 06:07 PM
08/30/21 06:07 PM
Posts: 9,096 Rogue River, OR
Jeremiah
Rogue River, OR
That is one thing that has never given me trouble. Running a quality alternator and water pump helps with bearing longevity because they do need to be a little on the toghter side.
I have had good luck with Tuff Stuff and Powermaster alternators.
Milodon used to be my go to water pump however the last batch I ordered were GMB inside of a Milodon box. I find it annoying that you cannot source a high quality as-cast water pump. It is almost easier to run an electric water pump. I look at the mechanical fan as a safety issue when working on an engine.
[Re: hemienvy]
#2959135
08/30/21 06:57 PM
08/30/21 06:57 PM
Jeremiah
Rogue River, OR
I have stuff that shifts from 5800 to 7200.
I use CVR 55 gpm electric pumps for a stock style replacement however my preference is an AR Engineering motor plate/water pimp adapters and a remote pump.
[Re: AndyF]
#2959240
08/30/21 10:27 PM
08/30/21 10:27 PM
Posts: 1,030 ohio
67mprfan
ohio
Andy I have that kit but still having issues with belt coming off. But I'm running the stock alternator
[Re: 4mopower]
#2959322
08/31/21 08:42 AM
08/31/21 08:42 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I just talked to Powermaster the other day about this for my own project, he said make sure it's straight and tight. ^^This^^ My small block has a 5" pulley on the crank and has a Powermaster GM CS121 alternator. I've turned it 7800 and didn't throw the belt. I took a lot of time to ensure everything lined up well when I made the spacer for the crank pulley and the alternator brackets.
[Re: 67mprfan]
#2959325
08/31/21 08:42 AM
08/31/21 08:42 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
I've run a few different configurations w/ V belts consisting of stock size pulleys and smaller underdrive pulleys. All over 7k rpm and never had any issues w/ belts coming off. I think the biggest issue is making sure it's all aligned properly.
[Re: lewtot184]
#2959337
08/31/21 09:21 AM
08/31/21 09:21 AM
Posts: 1,020 Andrews,In. U.S.of A.
67_Satellite
i've used this idea for decades. Made one of these for the Satellite. I lowered the alt. 10'' for packaging reasons, and this stopped the belt throwing. Quick. cheap& reliable. Saw an episode of Graveyard Cars where they had an underhood go-pro camera mounted, and even the factory system showed lots of "whip" in the belts.
[Re: 67_Satellite]
#2959486
08/31/21 01:22 PM
08/31/21 01:22 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
Keep the belt as short as possible and as stuff as you can and you wont have any issues. Low mount kits are great for that. The only belt i ever have an issue with the is AC belt on my Camaro but it is a MILE long and dont like anything over 7400
[Re: 67_Satellite]
#2959518
08/31/21 02:25 PM
08/31/21 02:25 PM
Posts: 3,916 usa
lewtot184
usa
i've used this idea for decades. Made one of these for the Satellite. I lowered the alt. 10'' for packaging reasons, and this stopped the belt throwing. Quick. cheap& reliable. Saw an episode of Graveyard Cars where they had an underhood go-pro camera mounted, and even the factory system showed lots of "whip" in the belts. i had an old drag racer show me that "gadget" about 1969. i ran a 4spd car and it would be unreliable belt wise approaching 6000rpm. been using them since. there's a reason the super stock wedges and hemis had deep groove pulleys.
[Re: lewtot184]
#2959875
09/01/21 12:22 PM
09/01/21 12:22 PM
Posts: 19,307 north of coder
moparx
i've used this idea for decades. Made one of these for the Satellite. I lowered the alt. 10'' for packaging reasons, and this stopped the belt throwing. Quick. cheap& reliable. Saw an episode of Graveyard Cars where they had an underhood go-pro camera mounted, and even the factory system showed lots of "whip" in the belts. i had an old drag racer show me that "gadget" about 1969. i ran a 4spd car and it would be unreliable belt wise approaching 6000rpm. been using them since. there's a reason the super stock wedges and hemis had deep groove pulleys. that was exactly the idea i tried to explain. thanks for posting that picture Lew !
