Small diameter water pump pulley #2958829
08/29/21 08:46 PM
08/29/21 08:46 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
For big block, p/n 3698907, this is a single groove pulley, about 5-7/8 OD.
The pulley groove sits pretty far forward, it's "2 belt groove widths" farther forward than my 6-7/8 pulley.
Is this about the smallest diameter W/P pulley there is ?
Is there a pulley that is only sits one groove width forward ?
Or maybe a small diameter double groove pulley ?
Re: Small diameter water pump pulley [Re: hemienvy] #2958985
08/30/21 12:01 PM
08/30/21 12:01 PM
moparx Offline
moparx  Offline
i have a 76 400 from my wife's newport sitting on the shelf that had a small diameter, single groove water pump pulley.
i took it off for some reason, but i just looked, and can't find it. i know it's out "there somewhere", because when i took it off, i was after some bracketry for the power steering pump. i then stashed it so "i would know where it was" when i needed it in the future, and of course "now i can't find it". mad
i'm also thinking there is a small [just a tick over 5" or a tick under 5"] single groove pulley used on some ac small block applications, but i can't confirm. i'm just remembering something from the past, so that may, or may not, be correct.
hopefully, others can provide a correct answer for you.
anyway, consider this a bump.
beer
Re: Small diameter water pump pulley [Re: hemienvy] #2958987
08/30/21 12:08 PM
08/30/21 12:08 PM
Locomotion Offline
Locomotion  Offline
I hope I'm figuring this correctly, but based on another post of yours about 7,000 rpm operation, wouldn't you need a bigger water pump pulley to slow down the water pump? Or use a smaller crank pulley? (But that would slow down the alternator too.)
Re: Small diameter water pump pulley [Re: Locomotion] #2958993
08/30/21 12:16 PM
08/30/21 12:16 PM
moparx Offline
moparx  Offline
yes, a bigger water pump and alternator pulley diameter will slow those accessories down at high rpm, as well as using a smaller than stock diameter crank pulley with the factory water pump and alternator pulleys.
beer
Re: Small diameter water pump pulley [Re: Locomotion] #2959002
08/30/21 12:34 PM
08/30/21 12:34 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Yes for this one motor project I want my cake and eat it too, 7000 RPM capability
with no chance of overheating or alternator undercharging at idle/cruise.
But it would not be prolonged high RPM, no cannonball runs.
Everyone worries about the internal engine components, but I started thinking
about the water pump and alternator RPM too, and the V-belts.
I had a buddy long ago that had a Z-28 302 car, he said he would routinely
take the motor to 8500. Perhaps there is more details to those stories then he let on ?
Re: Small diameter water pump pulley [Re: hemienvy] #2959008
08/30/21 12:45 PM
08/30/21 12:45 PM
moparx Offline
moparx  Offline
i have seen fabricated belt "retainers" made from [approximately] 1/2" round stock with a flat strap welded to the back that bolted to the water pump/alternator to keep the belt in place at high rpm.
when the belt would rise up out of the groove, the round stock "retainer" would rub on the top side of the belt, keeping it in place. these were placed approximately 1/8"[or a tad closer] above the pulley[s] after the belt was installed and properly tensioned.
beer
Re: Small diameter water pump pulley [Re: moparx] #2959340
08/31/21 09:27 AM
08/31/21 09:27 AM
VA
dragon slayer Offline
VA
You need to pay attention to your WP impeller. Faster speed if it results in cavitation does not result in better cooling. Plus your clutch fan rotation. Chapter 7 I believe gives you many of the specs including ratios and impeller size. If you go with a normal RB balance you have more pulley selection options then the hemi balancer.
Re: Small diameter water pump pulley [Re: dragon slayer] #2959686
08/31/21 08:41 PM
08/31/21 08:41 PM
In addition I would tack an anticav plate on the vanes
Re: Small diameter water pump pulley [Re: RapidRobert] #2960555
09/03/21 09:41 AM
09/03/21 09:41 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
I have a couple of those smaller water pump pulleys. Not sure what they came off of ...they've been in my parts stash forever.
The smallest one is 5 1/16" across, 1" from face to center of belt groove.
The other is 5 3/4" wide, and 15/16" deep.
maybe the same as the small one in these pics.?.?... but i have no clue on its original application
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
