Truck just quits running at a stop
#2958463
08/28/21 08:03 PM
08/28/21 08:03 PM
Posts: 27,028 Shopping @ HoBo Fright
340SIX
I have not looked at it is my wife's aunt's truck. 1992 or 93 318 magnum auto LE. Leaning towards it being a 1993, if that matters. An old lady drove back and forth to a close school as she was a teacher, now retired. So goes to food store once every 2 weeks and church on Sunday. Garaged super clean no rust as we live in the south. I have 1st dibs if she ever gets rid of it. Said on phone last night runs 100% as it should but when you stop at a red light/stop sign motor turns off. Starts right back up and runs fine. Last week she had to really drive it to get someones, kids, at school and did not do it the 2 days she used it. Thoughts on what it could be? Anything common problems with these years and drive lines that go bad?
Re: Truck just quits running at a stop
[Re: NITROUSN]
#2958477
08/28/21 08:31 PM
08/28/21 08:31 PM
340SIX
Battery. Most likely cranks slow and dumps the memory on the first start. If it runs ok with no stalling after 20 minutes I would lean on the battery. Thanks, I will ask her. It will sit a week before she goes to start it again on the norm. She is presently hiding out at someone else's home to ride the hurricane out.
[Re: Moparite]
#2958591
08/29/21 08:17 AM
08/29/21 08:17 AM
Posts: 1,960 USA
Suregrip391
USA
That's an LA motor not a magnum, The idle motors wear out and start to fail. If you can still keep it running with your foot on the gas that's the problem. I had 90 that had 60k on the clock when i got it, Had over 200 when i sold it. No major issues other than the trans that had to be rebuilt. Had the same issue with my 98, I drove it to work trying to keep the idle up by putting my foot on the gas even when braking, was not fun…. Changed the battery and all was good. Let us know how it turns out…..
[Re: 360view]
#2958809
08/29/21 06:54 PM
08/29/21 06:54 PM
Posts: 1,518 West Palm Beach, Florida
Copper Dart
If the pintle of the EGR valve is corroded away so that some exhaust gas keeps flowing when it should not, the 1992-1995 Magnum V8 engine will stall at stops, then restart. This make so much more sense than a bad battery. If the battery was bad, how come it starts fine and restarts just fine after stalling guys? Bad battery would need a jump right? Just sayn'
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#2958999
08/30/21 11:25 AM
08/30/21 11:25 AM
Posts: 17,303 north of coder
moparx
If the pintle of the EGR valve is corroded away so that some exhaust gas keeps flowing when it should not, the 1992-1995 Magnum V8 engine will stall at stops, then restart. This make so much more sense than a bad battery. If the battery was bad, how come it starts fine and restarts just fine after stalling guys? Bad battery would need a jump right? Just sayn' my one minivan would start fine, but would stall after pulling out of the driveway, then start fine again. sometimes it would light the check engine light, sometimes not. when scanned, the trouble codes were always goofy things that had nothing to do with driveability. that battery always started that thing, but it was 7-8yrs old. just for the heck of it, i bought a new battery, put the new battery in the wife's car, and put her 4yr old battery in the "bus". no more stalling, no more check engine lights, nothing goofy thereafter. the battery obviously was the culprit.
[Re: Copper Dart]
#2959035
08/30/21 01:15 PM
08/30/21 01:15 PM
Posts: 7,082 USA
360view
USA
If the pintle of the EGR valve is corroded away so that some exhaust gas keeps flowing when it should not, the 1992-1995 Magnum V8 engine will stall at stops, then restart. This make so much more sense than a bad battery. If the battery was bad, how come it starts fine and restarts just fine after stalling guys? Bad battery would need a jump right? Just sayn' I also agree that a bad battery can make Magnum V8 OBD-I systems act “weird” yet the bad battery will start the engine.
[Re: Copper Dart]
#2959305
08/31/21 06:39 AM
08/31/21 06:39 AM
Posts: 16,250 Between Houston & Galveston TX
Satilite73
If the pintle of the EGR valve is corroded away so that some exhaust gas keeps flowing when it should not, the 1992-1995 Magnum V8 engine will stall at stops, then restart. This make so much more sense than a bad battery. If the battery was bad, how come it starts fine and restarts just fine after stalling guys? Bad battery would need a jump right? Just sayn' Not necessarily. Late '90's, early 2000's I worked at a Used Car lot. With the Dodge trucks, people would be in and out of them all day, playing with the accessories, starting them, but not running them long enough to charge, and eventually the battery would be low enough that it would still start just fine, but it would stall as soon as put into gear. Charging the battery or swapping in a fresh battery fixed it every time.
John
Imagine a '73 Satellite Wagon picture here. 😁
[Re: 360view]
#2959672
08/31/21 07:21 PM
08/31/21 07:21 PM
340SIX
If the pintle of the EGR valve is corroded away so that some exhaust gas keeps flowing when it should not, the 1992-1995 Magnum V8 engine will stall at stops, then restart. This make so much more sense than a bad battery. If the battery was bad, how come it starts fine and restarts just fine after stalling guys? Bad battery would need a jump right? Just sayn' I also agree that a bad battery can make Magnum V8 OBD-I systems act “weird” yet the bad battery will start the engine. In this case starts right back up and runs fine right away. But mat stop running when truck stops. If so starts right back up. It will stay in the garage as her,aera was hit very, very hard by Hurracane Ida. Thanks for the imput.
