What type of carb entry and screen do you run? #295779
04/21/09 09:38 PM
04/21/09 09:38 PM
Mopar Lane,Mississippi
67HEMI Offline OP
67HEMI  Offline OP
I had some intake port work done and I also added a 1 inch Wilson 4 hole tapered spacer. With a 9375 domintor I have no room for an air filter with a WO factory height scoop. What type of carb entry screens are available? Show pics if you have them please. I have about 2 1/4 inches from flange to the scoop. Thanks!!
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: What type of carb entry and screen do you run? [Re: 67HEMI] #295780
04/22/09 08:56 AM
04/22/09 08:56 AM
67HEMI Offline OP
67HEMI  Offline OP
Bump...I know out of all the cars on here somebody is running a screen of some sort
Re: What type of carb entry and screen do you run? [Re: 67HEMI] #295781
04/22/09 09:02 AM
04/22/09 09:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Wedgeomatic has a nice looking set up for his dom but
I dont think your going to get anything to fit in a
2 1/4" opening.... I use what is called a ideal entry,
looks like a short velocity stack, I used them all
the time when I flowed carbs and air cleaners for
Chrysler
