Re: Power steering pump
[Re: hudsonhornet7x]
#2959013
08/30/21 01:13 PM
08/30/21 01:13 PM
Posts: 4,707 Florida
BDW
Thx HH! That's great info, looks like we can easily replace the pressure valve and use the original steering box.
[Re: 70gtx1]
#2959535
08/31/21 02:45 PM
08/31/21 02:45 PM
BDW
For what its worth, I run the stock hellcat PS pump with a Borgeson Steering box unit. No pressure reducing mods. Works great!! Borgeson would definitely be smaller, but I'm having a hard time justifying the $1000 cost. Plan is to stick with to stock box, if at all possible. This Gen3 swap is looking like its going to cost $10-12k min, my car is only worth $20k
[Re: BDW]
#2959696
08/31/21 08:55 PM
08/31/21 08:55 PM
Posts: 2,255 IL
furious70
IL
like anything - if you have a completely functional setup the cutover costs really add up. If you don't have a working setup and you're buying stuff either way, it's not so bad. That's a reason I'm going 5.7 turbo in my Coronet now but stuck with the 383 architecture to do a small upgrade rather than have to rebuild the turbo setup on my Fury. Too much time and cost at the moment for a car that just needed a new shortblock.
70 Sport Fury 68 Charger 69 Coronet 72 RR
