Tuner Studio
#2956389
08/22/21 05:50 PM
08/22/21 05:50 PM
Posts: 1,546 Michigan
Kiddart
I need some advise on this software, if anyone is local to me in the metro Detroit area(Macomb Township area) that would be able to give me some tips on this software i would appreciate it.
Problems i am having Map sensor program, does not respond to any changes Fans will not turn on and are wired according to the directions if i look at you tube videos and make the changes the fuel pump will cycle three times on key on when i change the fan settings.
Can not get to idle smooth.(sounds like its loaded up and missing)
I am just struggling with this, its hot and i am running thin on patience.
if you can help PM i will respond.
Thank you Kiddart
Re: Tuner Studio
[Re: Kiddart]
#2956443
08/22/21 11:04 PM
08/22/21 11:04 PM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
are you getting a settings mismatch error or anything when the ECU powers up? Usually when the fuel pump cycles on and off there is something setup wrong, like two functions assigned to one thing. Usually TunerStudio feeds you this info right in the middle of the screen so I am guessing that isn't the problem.
What output do you have your fan assigned to?
I am no expert, my car has a Megasquirt and has for several years, I also do most of the tuning on a friends mustang with an MS3 but I am no pro.
If you want send me the tune file either the one you have named or Currenttune.msg to my email Clamb12 at gmail and I can take a look at it and see if I can spot anything. In the email include how you have things like fans and anything extra wired to the ECU.
68 Barracuda Formula S 340
Re: Tuner Studio
[Re: Bad340fish]
#2956487
08/23/21 09:00 AM
08/23/21 09:00 AM
Kiddart
I do get the message error. I will send you my tune. the fans are assigned to FIDLE as they are supposed to, at least thats what i have read they should be.
thank you
Thank you Kiddart
Re: Tuner Studio
[Re: Kiddart]
#2956821
08/24/21 06:14 AM
08/24/21 06:14 AM
Bad340fish
Tulsa OK
I haven't seen anything in my email? If possible screen shot that error message.
Re: Tuner Studio
[Re: Bad340fish]
#2957524
08/26/21 06:54 AM
08/26/21 06:54 AM
Bad340fish
Tulsa OK
I'm guessing you figured it out?
