Re: Lifter oiling an Indy Maxx
[Re: sasquatch]
#2955907
08/21/21 09:41 AM
08/21/21 09:41 AM
Posts: 4,699 On the parachute mount
n20mstr
drill and tap each lifter bore (1/8 pipe) then use -3 fittings. get your self 2 1 in 8 out or 1 i 16 out dist block . drill and tap rear china wall to oil passage. Plumb the china wall to the dist block(s) . I used 3/16 brake line and -3 fittings throughout. I use a nitrous jet holder at the inlet of the block to regulate the oil. I use a .050 nitrous jet. Works pretty well and you have to be a good tube bender to fit it all neatly, but it can be done. I have nitrous direct port install experience so it was easy for me. You can buy all the parts you need from induction solutions.
....BAD A$$ STREET CAR.....
[Re: Bill_T]
#2956501
08/23/21 09:41 AM
08/23/21 09:41 AM
Posts: 2,009 Apollo, PA.
B1MAXX
Apollo, PA.
I am just thinking out loud here, but you won't be able to drill down on the Bridgeport, there is not enough space. So, can you turn it and use the table travel, no enough room that way either. So the only way I see it possible, is to turn the ram parallel with the table and rotate the head 90* so that its pointing at you and use the y axis + quill to feed . you will need at least a few length 1/4 drill bits and changing them would be a little tricky, I probably would turn the ram 45*, once I got to longer bits I would drive them with a collet, so that you could change with the drawbar removed.
[Re: sc4400]
#2957036
08/24/21 07:21 PM
08/24/21 07:21 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I would not suggest this. I am with Todd Marsh. I had this exact situation, and I would not attempt it. I asked one of the best in the business to do it, Weston Machine, and they wouldnt either. It went back to Indy. This can go bad very quickly.
RIP Monte Smith
[Re: CompWedgeEngines]
#2957649
08/26/21 02:54 PM
08/26/21 02:54 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I would not suggest this. I am with Todd Marsh. I had this exact situation, and I would not attempt it. I asked one of the best in the business to do it, Weston Machine, and they wouldnt either. It went back to Indy. This can go bad very quickly. 1000%
Brian Hafliger
[Re: hemienvy]
#2957797
08/26/21 10:14 PM
08/26/21 10:14 PM
Posts: 6,150 Melbourne , Australia
LA360
Yes, the long series drill wanders and breaks through the casting, or doesn't properly intersect with the other side, or the drill breaks inside the hole. Then there are all the possibilities of operator error.
Alan Jones
