mini starter click and no crank #29553
09/13/06 02:33 PM
09/13/06 02:33 PM
NW Indiana USA
727specialist Offline OP
NW Indiana USA
There was a post a couple months ago about this. The starter clicks and wont crank intermintley.
There are parts available to fix this. Someone had the part #s.
Re: mini starter click and no crank [Re: 727specialist] #29554
09/13/06 02:44 PM
09/13/06 02:44 PM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
Toyota dealer parts counter guy gave contacts to me, local starter repair shop sells them for $1 each, there are several configurations, take your old ones with you. Sorry, I don't have part #'s.
Re: mini starter click and no crank [Re: 727specialist] #29555
09/13/06 02:58 PM
09/13/06 02:58 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I posted the numbers in the general section about 3 months ago you might still be able to find them.I am on vacation this week so I can't get the numbers right now.Some Toyota parts guys will help you out and some are worthless but take your old contacts with you.The genuine Nipondenso contacts from Toyota are better than the El-cheapo stamped units.
Gus
64 Plymouth Savoy
Dana 60
Re: mini starter click and no crank [Re: fourgearsavoy] #29556
09/14/06 09:21 AM
09/14/06 09:21 AM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
You can thank fourgearsavoy for these numbers, he sent them to me some time ago. 28226-64370 and 28226-72010 Good Luck
Re: mini starter click and no crank [Re: Cuda_Mike] #29557
09/14/06 11:18 AM
09/14/06 11:18 AM
NW Indiana USA
NW Indiana USA
Thanks fourgearsavoy and cudamike for the help. Keith
Re: mini starter click and no crank [Re: 727specialist] #29558
09/14/06 11:53 AM
09/14/06 11:53 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Archive material
