Restrictor plate question #2954587
08/17/21 10:18 AM
08/17/21 10:18 AM
tboomer Online work OP
tboomer  Online Work OP
For you folk that have run one..Does this do any harm to the engine? If I don't get my car sold,I am going to try a plate and maybe the doc will let me drive. It is a very low 10 second car and I want to run low to mid 12.xxs thanks! Ted wave
Re: Restrictor plate question [Re: tboomer] #2954605
08/17/21 11:42 AM
08/17/21 11:42 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I have a couple buddies that run the removable plate type restrictor. They can change the size, to slow the car down accordingly. You could also try disconnecting the secondary's. Mike used to do that when his daughter started driving the car. It would kill 3/4 of a second off.
69 GTX 68 Road Runner
Re: Restrictor plate question [Re: JERICOGTX] #2954613
08/17/21 11:55 AM
08/17/21 11:55 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Easy enough to make a dead-consistent 12.80 car out of an 11.40s car by only running on the primaries.
Didn't hurt a thing - it's basically just a combustible-air pump.
Re: Restrictor plate question [Re: tboomer] #2954615
08/17/21 12:03 PM
08/17/21 12:03 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I bought the ET Genie this year to use on my car for index racing. I've only used it 3 times far and have been trying different things with it. My car typically is a 10.70s car and I slowed it down to 11.50s. The ET Genie has 24 turns of adjustment to restrict. At first I turned the resistor 18 turns and got close, but since it was closed significantly throttle response had a delay to it. I could mat the gas and than feel the car response (Kind of like the new cars with electronic throttles). The next week I unhooked the secondaries and closed the resistor 7 turns and the car ran the same ET and had much better throttle response. To slow a car down 2 seconds is a lot. For that much ET change I'd consider building a much milder engine or something to make it easier to get to your desired ET goal.
Re: Restrictor plate question [Re: DusterKid] #2954743
08/17/21 04:31 PM
08/17/21 04:31 PM
Thanks everyone! Jeff...Is Mike and Becky coming down this weekend? wave
Re: Restrictor plate question [Re: tboomer] #2954934
08/18/21 06:10 AM
08/18/21 06:10 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Nope.
Re: Restrictor plate question [Re: JERICOGTX] #2954938
08/18/21 07:20 AM
08/18/21 07:20 AM
Thanks Jeff! up
Re: Restrictor plate question [Re: tboomer] #2954948
08/18/21 08:15 AM
08/18/21 08:15 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If you want to slow down 2 seconds put me in it. boogie
Re: Restrictor plate question [Re: slantzilla] #2954949
08/18/21 08:19 AM
08/18/21 08:19 AM
Lol!! Funny guy Dennis! wave
Re: Restrictor plate question [Re: tboomer] #2954957
08/18/21 09:03 AM
08/18/21 09:03 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Be careful of vour WOT vacuum, if it gets too high the PV won't open.
Boffin Emeritus
Re: Restrictor plate question [Re: polyspheric] #2954967
08/18/21 09:35 AM
08/18/21 09:35 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have been slowing my Dart down from 10.70s to 11.50s for 12 years now I use a modified Moroso bolt system To change settings I just turn the bolt in or out. My secondaries are barely opening. I tried the Willys adjustable plate system as well as the E T Genie with different plates and couldn’t get the car to react as well as the bolt system I already use. My engine builder ran dyno tests on a customers engine using a plate system to see the results and found no strange reversion or fuel distribution problems.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Restrictor plate question [Re: polyspheric] #2954970
08/18/21 09:48 AM
08/18/21 09:48 AM
Race only engine...No pvs...
Re: Restrictor plate question [Re: tboomer] #2954972
08/18/21 09:59 AM
08/18/21 09:59 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Have you considered using a 650 carb and launching in 2nd gear? Running off the primaries is just like running a 2 bbl carb. I've had that combo on a few stock eliminator cars and its tough running the number when the weather is off.
