Re: Restrictor plate question
[Re: tboomer]
#2954605
08/17/21 11:42 AM
08/17/21 11:42 AM
Posts: 10,020 MN
JERICOGTX
MN
I have a couple buddies that run the removable plate type restrictor. They can change the size, to slow the car down accordingly. You could also try disconnecting the secondary's. Mike used to do that when his daughter started driving the car. It would kill 3/4 of a second off.
69 GTX
68 Road Runner
[Re: tboomer]
#2954934
08/18/21 06:10 AM
08/18/21 06:10 AM
Posts: 10,020 MN
JERICOGTX
MN
Thanks everyone! Jeff...Is Mike and Becky coming down this weekend? Nope.
69 GTX
68 Road Runner
[Re: tboomer]
#2954957
08/18/21 09:03 AM
08/18/21 09:03 AM
Posts: 4,206 New York
polyspheric
New York
Be careful of vour WOT vacuum, if it gets too high the PV won't open.
Boffin Emeritus
[Re: polyspheric]
#2954967
08/18/21 09:35 AM
08/18/21 09:35 AM
Posts: 4,974 new jersey usa
11secdart
new jersey usa
I have been slowing my Dart down from 10.70s to 11.50s for 12 years now I use a modified Moroso bolt system To change settings I just turn the bolt in or out. My secondaries are barely opening. I tried the Willys adjustable plate system as well as the E T Genie with different plates and couldn’t get the car to react as well as the bolt system I already use. My engine builder ran dyno tests on a customers engine using a plate system to see the results and found no strange reversion or fuel distribution problems.
