Ladder bar. Or caltrac #2953549
08/13/21 07:18 PM
08/13/21 07:18 PM
florida dade
cesar perez Offline OP
florida dade
Ladderbar or caltrac
Re: Ladder bar. Or caltrac [Re: cesar perez] #2953555
08/13/21 07:49 PM
08/13/21 07:49 PM
gregsdart Online content
gregsdart  Online Content
A ladderbar is dirt simple and light. Depending on your power level , hard to beat. They do need good shocks but so would caltracs I would assume.
Re: Ladder bar. Or caltrac [Re: cesar perez] #2953562
08/13/21 08:35 PM
08/13/21 08:35 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
CalTrac's are bolt in. Ladder bar is not. Can you do the welding and fab work?
Coming soon!!!!
Re: Ladder bar. Or caltrac [Re: Mr.Yuck] #2953572
08/13/21 09:04 PM
08/13/21 09:04 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
If your on a budget ladder bars Both work great
Re: Ladder bar. Or caltrac [Re: scottb] #2953591
08/13/21 10:08 PM
08/13/21 10:08 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
It really depends on how you use the car.
We do a lot of street driving and race some events where stock style suspension is required so we went with Cal-Tracs.
If your car is more geared towards being a drag car, I would recommend going with a ladder bar for simplicity and weight savings.
'63 Dodge 330
11.19 @ 121 mph
Re: Ladder bar. Or caltrac [Re: GY3] #2953639
08/14/21 06:29 AM
08/14/21 06:29 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Wondering what's the weight difference between ladder bars and cal-trac's?
Re: Ladder bar. Or caltrac [Re: cesar perez] #2953644
08/14/21 07:07 AM
08/14/21 07:07 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I have used Super Stock springs with cars high 10s and slower with no issues. My current car is a backhalved ladderbar and runs mid 10s. It has a big tire and has no issues hooking in hot/cold or non perfect track prep. It really comes down to the intended purpose and ET of the car IMO.
Street/strip car - mid to high 10s and slower use Super Stock springs
Street/strip car mid 10s or faster or a drag car that you don't want to cut up use Caltracs
Strictly race car that you want to put a big tire on or or don't care to keep stock - Ladderbars
Re: Ladder bar. Or caltrac [Re: cesar perez] #2953702
08/14/21 12:57 PM
08/14/21 12:57 PM
Do you want to be able to hook the car in a mud puddle in a rain storm?
If so use ladder bars with a good set of double adjustable coil over shocks twocents scope
Re: Ladder bar. Or caltrac [Re: Cab_Burge] #2953714
08/14/21 01:39 PM
08/14/21 01:39 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
But with Caltracs, you can drive around corners (or mud puddles) without binding up your rear suspension and twisting the body... work
Re: Ladder bar. Or caltrac [Re: DrCharles] #2953740
08/14/21 02:42 PM
08/14/21 02:42 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Go with Ladder bars, Caltracs are just too good grin
Re: Ladder bar. Or caltrac [Re: DrCharles] #2953778
08/14/21 04:37 PM
08/14/21 04:37 PM
????, mine didn't shruggy
Re: Ladder bar. Or caltrac [Re: cesar perez] #2953823
08/14/21 07:12 PM
08/14/21 07:12 PM
AndyF Offline
AndyF  Offline
I had Caltracs and split mono leafs on my Duster with Caltrack shocks and that car would hook great on the street. I've never driven a car that would just hook and go like that. It never spun the tires, just took off. I gave a lot of guys rides in that car and had lots of people tell me that it left harder than their bracket cars. That was my first time working with that combination of parts but it really worked. For a dedicated drag race car I'd probably go with ladder bars but the Caltrac setup sure worked great for a street car. (The 60 lbs of ballast tucked inside the rear bumper probably helped with the launch)
Re: Ladder bar. Or caltrac [Re: AndyF] #2953931
08/15/21 08:05 AM
08/15/21 08:05 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Street use, Cal tracks. No street use ladder bars. Ladder bars bind in cornering, Caltracks do not. Ladder bars are less prone to high wheel stands. Ladder bars will work with standard style wheelie bars if you need them. Ladder bars are cheaper when you add in the cost of springs. Ladder bars are lighter.
Doug
Re: Ladder bar. Or caltrac [Re: dvw] #2954064
08/15/21 05:22 PM
08/15/21 05:22 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
I have been using Ladder Bars with Strange single adjustable shocks for years on my car. Sees a lot of street time and has never been in a bind up situation. I never tried CalTracks before so I can't give a comparison . All I can say is My Ladder bar setup works and has worked well for years. Fairly Low 60' times with a lot of tire under the car. Like Cab Said it will hook in the mud.
6.50 @105.26
Re: Ladder bar. Or caltrac [Re: Kindafast] #2954074
08/15/21 06:24 PM
08/15/21 06:24 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You may not have noticed. But the only way you will get any roll in the rear while cornering is if you have flex. Ladder bars act as a very large rear sway bar. So the front suspenion will have roll, not the rear. Not good in a quick corner. Put a heck of a load on front heims ans housing welds.
Doug
Re: Ladder bar. Or caltrac [Re: AndyF] #2954119
08/15/21 09:29 PM
08/15/21 09:29 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I'll admit, Ive never been able to launch from 1st on the street but can easily hook leaving in 2nd gear. Maybe with some more shock tuning...
A 20 mph roll from first and even hitting it.with a 250 shot makes it squirt ahead in a religious experience! No spinning, no sliding just straight ahead and no drama.
When you do the math, the car is going 0-60 mph in 2.0 seconds at the track! Crazy for a small tired street car.
'63 Dodge 330
11.19 @ 121 mph
Re: Ladder bar. Or caltrac [Re: GY3] #2954128
08/15/21 10:15 PM
08/15/21 10:15 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have Cal-Tracs on my street/strip 69 Dart, pump gas 434" small block and have been 1.34 60'. It gets driven quiet a bit on the street. If I ever step up I'll go to a four link.
Re: Ladder bar. Or caltrac [Re: cesar perez] #2954182
08/16/21 08:41 AM
08/16/21 08:41 AM
an8sec70cuda Offline
The cost is about the same either way. If you don't have any issues (class rules, etc.) running non-stock style suspension, then go w/ ladder bars. For racing, they're just better.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Ladder bar. Or caltrac [Re: an8sec70cuda] #2954256
08/16/21 12:19 PM
08/16/21 12:19 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
j Just saying...... there are cars running mid to low 4's on Cal tracs
It really is a toss up. Both need "good" shocks . Both work well , the ladder bar may be limited in its IC adjustability, but there are complex ladder bars now that do offer a little more adjustability. It really matters if you get a weight break for the stock suspension. The Cal tracs are bolt on, but up to a certain point they do benefit from fabrication mounting. It really matters what your goals/needs are
....BAD A$$ STREET CAR.....
Re: Ladder bar. Or caltrac [Re: n20mstr] #2954283
08/16/21 01:33 PM
08/16/21 01:33 PM
For the average guy on an average track on any given weekend, the ladder bar has the advantage.
CHIP
